Macbook Air A1237 Power Issues
  • xalu
    • Mar 2015
    • 37
    I am looking for a little help figuring out exactly how to find the problem for this Macbook Air 2008 core 2 duo 1.6Ghz 2gb 13 inch laptop I just bought off ebay. The seller described it as needing a hard drive, but otherwise worked great. That doesnt seem the case now, and I would rather fix it if I can then return it. Maybe work out a partial refund since I already invested money in it (besides the unit itself).
    The issue:
    So when I got it the battery was completely dead. I bought a charger for it and tried starting it. It was doing a startup loop. It would try to start, screen went grey for a few seconds, then it would power down and attempt to start up but just fail. I figured it might need a decent charge to start (which seemed far fetched but ok whatever). I charged it and the charger went from amber to green so I thought well at least its charging!. I tried to start it. This time it seemed to be working. It got to the apple logo for the first time.. then shut off and repeated what it was doing the night before.
    I tried a few things. I tried with the charger and no battery. I tried with charger and battery. I tried without the broken hard drive (no hd), then with the new hd (that I pulled from my old ipod).. and same thing basically. If I reset the power by removing all power sources and pressing the power button so it clears, then it would start up like the first time where it would get to the grey screen and shut down. While running only on the battery it got to the logo/
    folder with `?`. I even had it stay like that for an extended period of time (an hour or so), but if I moved the computer just a smidge it would shut off.
    I am 90% sure its the logic board but I want to be 100% sure before I return it. If its a bad component I am not opposed to replacing them on the board.
    Does anyone have any experience with this type of issue with a macbook? Or any advice on how to nail down where the failure is occurring. I feel like its something that could be loose, or have a bad connections, but I cant find anything so far.
    Thanks for any help you might have to offer
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: Macbook Air A1237 Power Issues
    check voltage on secondary main fuse if it's stable (around 8.5 volt) before power it on and after you power it on and while loading os, and see when it shut down if it go too low.
    • xalu
      • Mar 2015
      • 37
      Thanks Dell,
      I think I found the fuses. They are on the top of the board near the power connectors with the green tops and R020? Which one is the secondary (the one closer to the battery)?
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        yes the one near battery is the secondary
        • xalu
          • Mar 2015
          • 37
          Okay. The voltage came out to around 8.3, Here is a look at what I had while trying to start up. (Note: the meter I am using is not perfectly calibrated so its about .1 higher than it says below)
          8.19
          8.08
          7.86
          7.81
          7.86
          7.81
          7.86
          7.86
          7.86
          7.86
          7.76
          7.92
          7.92
          7.97
          7.97
          7.92
          7.92
          7.97
          7.97
          7.76
          7.76
          7.76
          7.70
          7.70
          7.81
          7.76
          7.76
          7.76
          7.76
          7.81
          7.70
          7.81
          7.76
          7.76
          7.76
          7.76
          7.86
          7.70
          7.76
          7.70
          7.70
          7.70
          7.70
          7.76
          7.70
          7.70
          7.70
          7.70
          7.76
          7.70
          7.70
          7.70
          7.76
          7.76
          7.70
          7.76
          7.70
          7.70
          7.70
          7.70
          7.70
          7.70
          7.81
          7.70
          7.70
          7.70
          7.65
          7.76
          7.70
          7.70
          7.70
          7.70
          7.70
          7.70
          7.70
          7.70
          7.70
          7.70
          7.70
          7.70
          7.65
          7.76
          7.70
          7.70
          7.70
          7.70
          7.70
          7.65
          7.76
          7.70
          7.65
          7.70
          7.65
          7.70
          7.65
          7.70
          7.65
          7.70
          7.65
          7.70
          7.76
          7.65
          7.65
          7.65
          7.65
          7.65
          7.65
          7.76
          7.65
          7.65
          7.65
          7.65
          7.70
          7.65
          7.70
          7.65
          7.65
          7.65
          7.65
          7.70
          7.65
          7.65
          7.65
          7.70
          7.65
          7.65
          7.65
          7.65
          7.65
          7.65
          7.65
          7.60
          7.60
          7.65
          7.65
          7.70
          7.65
          7.60
          7.65
          7.65
          7.70
          7.65
          7.70
          7.65
          7.65
          7.60
          7.65
          7.70
          7.65
          7.65
          7.65
          7.60
          7.65
          7.65
          7.70
          7.60
          7.49
          7.65
          7.65
          7.6
          This eventually just shut off it seemed to be due to moving it around but not sure. Seems if I leave it still it shuts off sometimes, sometimes not (mostly does). Then when it does stay on (gets to ? folder) if I move it then it will shut down.
          The above was with just the battery. When I plugged it in this is all I got.
          8.19
          8.24
          back and forth between those two
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            voltage are ok. thermal paste is ok ?
            start macbook in verbose mode and record log file and see when it shut down.
            • dj_ricoh
              • 2073
              The issue:
              mine works like this!
              if I keep it normal the ventilator goes NUTS
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                You've got a leaky heatpipe.
                A working TV? How boring!
                • dj_ricoh
                  • 2073
                  what? o.O
                  i wanted to cook the board!
                  • xalu
                    • Mar 2015
                    • 37
                    Well I tried reapplying the thermal paste and now it wont start at all when I push the power button. There is voltage across the fuse. Did I fry something?
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      Reseat any cables and make sure you haven't missed any
                      • xalu
                        • Mar 2015
                        • 37
                        Thanks, Gave it a whirl but didnt work.
                        I am worried that the Artic cleaner I was using might have gotten on the board and shorted something. I thought I got it all off and I let it sit for a good 30 minutes (probably more) after finishing up.
                        • dellxps15
                          • Feb 2014
                          • 1598
                          • italy
                          if you touch the heatpipe, is it very warm or just cold? if cold reapply thermal paste. if still cold, change heatpipe.
                          if i remember good some macbookhave 2 wire on heatsink to check temperature.... but they are under the board, so you have to remove it....
                          try do a smc reset. (hold power botton for 10 sec without battery and ac).
                          • xalu
                            • Mar 2015
                            • 37
                            try do a smc reset. (hold power button for 10 sec without battery and ac).
                            Nope. Didnt do anything. Thanks for all the help though. Really appreciate it. The battery is charging (it went from amber to green). I tried holding it down several times with no power plugged battery in and tried it..then repeated a couple of times.
                            I took off the heatsink to see if anything was wet or looked wrong and it all looks ok. tripple checked connections. At a loss. I seemed to have gone backwards
                            Anything else I can try?
                            • xalu
                              • Mar 2015
                              • 37
                              Ok so I found a video with someone testing the logic board on their desk while its outside the MBA. When he plugged it in the board just powered on. I just tried this and my board powered on as well.
                              So its somewhere between the power button and ?
                              • xalu
                                • Mar 2015
                                • 37
                                First off thanks for the help. So I figured it out. Turns out the heat shield has been causing the problem all along. I cant figure out whats causing this to happen but I did figure out how to fix it.
                                Basically, once I realized the board worked outside of the case w/ nothing attached. I put it back in the case once screw ( and one connector) at a time and then tested to see if it would start.
                                When I redid the thermal paste it looked like someone may have already done it. There was a lot of paste present. Also, the screws showed signs of being played with. So I am not sure what was happening...if the paste was bad, or if they had a shaking short that would cause the issues I saw. Maybe it was just the thermal paste.
                                Now I just need to install a new hard drive and I am finished.
                                Thanks again.
                                • dj_ricoh
                                  • 2073
                                  Thanks again.
                                  OMG gray paste?
                                  maybe it was that crappy old silver BASE thermal compound.
                                  you remember AMD Duron and P3?
                                  whoooo whoooo
                                  • dellxps15
                                    • Feb 2014
                                    • 1598
                                    • italy
                                    Thanks again.
                                    well maybe it was put badly. if now macbook start always, you should be done, but if it doesnt could be also a damaged keyboard or something else. try with one cable at atime.
                                    plus see if it still power off.
                                    • newtothis
                                      • Mar 2013
                                      • 1556
                                      • england
                                      Well done on the fix
                                      My reasoning would of been a bad grounding screw, shake it and would switch off. If the screws had been previously removed it may not of been seated correctly. Simply removing then rebuilding could of sorted it out. Upon you working on it may of broken the connection completely hence no power.
                                      Its actually quite common of a repair to just rebuild something.
                                      • xalu
                                        • Mar 2015
                                        • 37
                                        OMG gray paste?
                                        whoooo whoooo
                                        Lol I dont know...maybe? I barely remember that crap...that was my preteen - early teen years haha..Whatever it was they had waaaaay too much. I dont know maybe I am just conservative with my paste. One pea sized ball
                                        Yeah its working great now. The battery sucks but cheap fix.
                                        Well when I rebuilt it (without doing a step by step power test), the power was completely dead. So I actually think there may be a screw shorting somewhere. I took out one screw and it was good. The one near the fan where the harddrive bracket screws in.
                                        I ordered a zif to msata adapter and then a 128gb msata ssd. Way cheaper than buying a zif ssd and I can upgrade it later if I want. (if I dont sell it for profit )
                                        I love fixing stuff
                                        • Flasman90
                                          Macbook Pro DFU Restore Issues
                                          by Flasman90
                                          I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                                          - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                                          - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                                          08-30-2025, 10:27 AM
                                        • cheebster
                                          Macbook Air 2020 A2179 Internet Recovery and Battery Issues
                                          by cheebster
                                          Hello, i have a batch of 10 Macbook Pros A2179 bought from a Costco return wholesaler.
                                          The 10 of them show the exact same behavior;
                                          They auto power on, to internet recovery spinning globe, fans to 100%.
                                          Power consumption on USB-C port is 0.43a, shuts down as soon as unplugged. Battery doesn't charge at all. However, it boots to 20V on the Ampmeter.
                                          Based on their iBridge versions (4.x and 5.x) these were shelfed for a long time.
                                          All of them power on the same way; 100% fans, shut down as soon as they are unplugged. Removing...
                                          10-09-2024, 06:23 AM
                                        • itzusman
                                          1708 EMC3164 macbook have power issues
                                          by itzusman
                                          Hi Masters.
                                          My 1708 EMC3164 macbook have power issues. First it was working fine but a bit slow in booting. Net day i turned it on and it didn't powered on. And i tested with usb meter it suddenly @ 20v it takes 2.6 ampares and cpu gets hot. Then i checked the baord and PPBUS_G3H was short to ground. I injected 1v to it it takes 350ma and cpu gets warm. After opening L7410/20/30 there was inly L7420 line was short then i injected 3v to PPBUS_G3H and it takes 2.5 amps and U7420 got hot and i desolder it. Now after that in the start it takes 0.580 amps and goes to 620-30 mili amps....
                                          07-13-2024, 06:19 AM
                                        • echothegamer
                                          Macbook A1466 dies when charger disconnected
                                          by echothegamer
                                          Hello all,
                                          Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
                                          Details:
                                          Macbook 13' A1466
                                          Board (820-3209-A)
                                          Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
                                          Pictures below of Boardview and schematic...
                                          I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
                                          It's an older model and it is very likely that battery has become...
                                          10-28-2023, 12:00 PM
                                        • envym
                                          MacBook Pro 2018 with Activation Lock
                                          by envym
                                          Hi everyone!
                                          I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                          I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                          06-27-2025, 08:54 AM
