hp g6 shutdown when connected to charger.
+ More Options
Posts
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    if it runs on battery work normal , once i insert dc charge it will shutdown ,
    it have a bq738 , replaced with a 728 but the same issue happen , so i think not a charging ic problem.
    only with dcjack , without battery does the same issue ,start to enter in windows then shutdown.
    resuming it will only shutoff with dcjack on .
    anyone had this kind of issues ?
  • dj_ricoh
    • 2073
    • uk
    Re: hp g6 shutdown when connected to charger.
    what board you got?
    schematic? nothing?
    come on highpulse!
    • MDY
      • Jan 2014
      • 75
      • Spain
      shutdown immediately or after some time?
      • Francisco.s
        • 686
        • Spain
        It seems that motherboard is a QUANTA R33, and BQ738 is PU9. (BQ24738)
        Check value of esr of +VCC_CORE, there is many tantalum capacitors in this line.
        Note that there isn't any NEC-TOKIN capacitor.
        • dj_ricoh
          • 2073
          • uk
          A few days ago i found 2 diodes connected to ground go bad and a fet that was used to discharge.
          Do a fast check and see if you got any short near dc jack.
          • highpulse
            i hate HP
            • May 2013
            • 1488
            • portugal
            KBC bios upgraded and fully working now , thk guys
            • dj_ricoh
              • 2073
              • uk
              Can you put the file?
              What model of g6 you got?
              • highpulse
                i hate HP
                • May 2013
                • 1488
                • portugal
                pff not even remeber but the board was a
                da0r33mb6e0
                the bios file is on the attachment
                • gitsfarmaz
                  Professnal tech
                  • Apr 2017
                  • 30
                  • Kenya
                  yes i have the same probleM with my DA0R33MB6E0 REV e INTEL CORE I3 WITH NO DEDICATED GRAPHICS CARD...HOW DID YOU GUYS SOLVE THIS PROBLEM
                  • Cyrielle
                    • Sep 2018
                    • 17
                    • France
                    Newbie question: what is KBC bios and how do you flash it?
                    Thank you
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3590
                      • slovakia
                      • Techtiger
                        • Oct 2014
                        • 1602
                        • france
                        Thank you
                        BIOS (basic input/output system) chip on a computer's Mob that recognizes and controls various devices on the Mob ,EC/KBC stands for "Embedded Controller/Keyboard Controller & to flash BIOS you need bios chip programmer tool kit (Ebay)
                        • master_haze86
                          820-01958-A no power sys led = white when charger is connected.
                          by master_haze86
                          Hi everyone.
                          First, let me preface by saying that I do not have much experience with diagnosing damages in motherboards other than visual inspection and checking simple short to ground faults.
                          But I do learn quickly, and really want to learn how to properly diagnose motherboard faults. If someone could have the patience to go over this board with me, it would be greatly appreciated.
                          A customer came into my shop with a A2179 MacBook with an 820-01958-A logic board. The reason for bringing the laptop in is that the laptop stopped turning on.
                          First thing...
                          02-15-2024, 05:30 PM
                        • motormayhem
                          Lenovo T460 Only Charges on One Charger
                          by motormayhem
                          Laptop Question
                          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                          05-12-2023, 01:46 PM
                        • nikolayu
                          Dell Latitude 5420 wont turn on when charger is connected
                          by nikolayu
                          I have Latitude 5420 that it's working fine on battery but when it's plugged on USB C charger it wont turn on.
                          Battery is charging fine. Also, if I connect the charger while laptop is on, everything is fine, it will charge.
                          The same thing if I connect to other USB C port.
                          Charger is OEM
                          03-13-2024, 12:34 PM
                          NVDC charger configuration...
                          11-05-2024, 03:28 PM
                        • rutgerv
                          Acer Swift 3 SF314-42 not powering up
                          by rutgerv
                          Dear all,
                          For a friend I'm trying to repair an Acer Swift 3 laptop (SF314-42). I'm not a professional, but have some experience (both as amateur and professional) in working with electronic design and repair of musical instruments.
                          The issue with the Acer laptop is the following:
                          It was bought new and used (not heavily) at home for about three years. After normal use, it was put to sleep, connected to charger and left over night (just like any other day). The next morning, the laptop would not wake up from sleep. Instead, when pressing the power button, the power...
                          08-02-2024, 06:59 AM
