820-01958-A no power sys led = white when charger is connected.
  • master_haze86
    • Nov 2023
    • 14
    • Ecuador
    Hi everyone.
    First, let me preface by saying that I do not have much experience with diagnosing damages in motherboards other than visual inspection and checking simple short to ground faults.
    But I do learn quickly, and really want to learn how to properly diagnose motherboard faults. If someone could have the patience to go over this board with me, it would be greatly appreciated.
    A customer came into my shop with a A2179 MacBook with an 820-01958-A logic board. The reason for bringing the laptop in is that the laptop stopped turning on.
    First thing I did was check the charger, the charger is in good working condition. The second step was opening up the laptop, disconnecting the keyboard/trackpad and battery and connected the charger to see if that way it might turn on to discard problems with battery and/or keyboard/trackpad.
    The system led (D6959) turns on white when the charger is connected. The laptop is otherwise unresponsive, touch ID button won't turn it on, connecting charger won't turn it on, opening the lid won't turn it on either.
    Visually inspecting, I did not find any component with obvious signs of damage. (no cracks, no discoloration, no burn marks, no signs of extreme heat.)
    This leaves me with inspecting the board with my multimeter as the next step, but I don't know where to begin. (I have found the boardview and schematics pdf here on badcaps for this logic board)
    Sincerely,
    Rick.
  • flat-earther
    how to prevent a connected charger from draining battery when not charging?
    by flat-earther
    I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
    So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
    but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
    So the battery is backfeeding the charger and being drained.
    How can I prevent...
    08-07-2025, 01:04 PM
  • motormayhem
    Lenovo T460 Only Charges on One Charger
    by motormayhem
    Laptop Question
    I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
    A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
    05-12-2023, 01:46 PM
  • nikolayu
    Dell Latitude 5420 wont turn on when charger is connected
    by nikolayu
    I have Latitude 5420 that it's working fine on battery but when it's plugged on USB C charger it wont turn on.
    Battery is charging fine. Also, if I connect the charger while laptop is on, everything is fine, it will charge.
    The same thing if I connect to other USB C port.
    Charger is OEM
    03-13-2024, 12:34 PM
    MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
    This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
    09-06-2024, 07:46 AM
    MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
    This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
    09-06-2024, 07:29 AM
