Dell Latitude 5420 wont turn on when charger is connected
  • nikolayu
    • Feb 2021
    • 40
    I have Latitude 5420 that it's working fine on battery but when it's plugged on USB C charger it wont turn on.
    Battery is charging fine. Also, if I connect the charger while laptop is on, everything is fine, it will charge.
    The same thing if I connect to other USB C port.
    Charger is OEM
  • mon2
    • 14834
    Remove all power. Meter in resistance scale. Check the resistance across DCin PQ49 mosfet as follows:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    Post each measurement. No power during these resistance checks. If the resistance is low, the mosfet may be shorted.
    • nikolayu
      • Feb 2021
      • 40
      There is no DCin. It charges only via USB C
      • mon2
        • 14834
        Do you have a link to the schematic for this unit?
        Which charger IC is onboard? Post pics of the charger IC. Nearby the charger IC will be the DCin mosfets. They will be used to accept the power adapter voltage (USB Type C for your case) and it will be passed onto the main power rail. You need to review the 2nd DCin mosfet in this power path.
        • BTubbs200
          Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
          by BTubbs200
          Dell Latitude 5420 P137G
          Board: LA-K491P REV A01
          I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
          Board seems to have no shorts, all power rails are fine and show high resistance.
          When charger is plugged in, voltage is present in 3.3V rail but absent in others....
          01-24-2025, 08:15 PM
          DELL Latitude 5420 Notebook 5000 Specification for Upgrade or Repair
          This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
          09-07-2024, 06:31 AM
          09-07-2024, 03:40 AM
