HP G7 Series No Power Question
  • electrobe
    • Sep 2012
    • 70
    • usa
    Model: HP g7-1310US
    Motherboard Model: DAOR13MB6EO (I included a schematic of the board)
    I sure could use some help with this no power problem. There is no life in this laptop & I couldn't try the laptop battery because it is dead. I need to know what the ohms value & part number for the sensing resistor in the yellow box provided below. Also I have included another picture of the tested points & what voltages I have found. I do not know what could be preventing the +3v & +5v to even come up. Please I beg of you of any help. I am by far no expert & this is a learning experience for me. I just want to fix my own stuff & not send it to the landfill.
  • JaroTech
    • Mar 2015
    • 351
    Re: HP G7 Series No Power Question
    Hi, it's difficult to answer your questions, I don't see any pictures you included.
    • TVRepairNoobie
      • Feb 2015
      • 158
      Original post: https://www.badcaps.net/forum/showthread.php?t=44483
      • electrobe
        • Sep 2012
        • 70
        • usa
        Here are the pictures
        • khaahk
          • Dec 2013
          • 812
          • Estonia
          If you have 19V on PQ23 pins 1-3 then you have +VAD 19V also.
          And as you have no voltage on pin 20 on PU2, then check resistor PR12, is it 22 ohms?
          • electrobe
            • Sep 2012
            • 70
            • usa
            I will check & will get back to you.
            • electrobe
              • Sep 2012
              • 70
              • usa
              The reading on PR12 is 193.9 ohms
              • khaahk
                • Dec 2013
                • 812
                • Estonia
                If you measured across PR12, then it should not show so much. Replace with correct one.
                • electrobe
                  • Sep 2012
                  • 70
                  • usa
                  ok I will change it out & let you know the results.
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • reessi
                    HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
                    by reessi
                    I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
                    It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
                    What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
                    I have checked these lines in diode mode and they seam normal -> 600.
                    I have checked to see if they come on for even a fraction of a second...
                    07-15-2025, 09:14 AM
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
