Dell N5110 short
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 343
    • India
    Dell N5110 short
    As power applied by adapter ,adapter led turns off.did't find any short
    power rail at Gpu shows a 3.6 ohms at coil PL9201 .
    is this is correct or not.
    I also want to open coil and give some other kind of load &chek voltage across coil pl9201.
    Did any one did it.
    Thanks.
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: Dell N5110 short
    I was thinking you should check pu4002 and pu4003, as well as any high drive mosfet in each regulator first.
    do not forget dc connector should also be checked
    • ravi_1617
      YY Solutions
      • Jan 2012
      • 343
      • India
      i have tested all mosfet. how much ohms should it show.is mine correct or abnormal
      • ravi_1617
        YY Solutions
        • Jan 2012
        • 343
        • India
        I have disconnected gpu coil & given some load & found full board is on all coil showing power at the gpu coil showing around 18-19 volts & main board stays on .how can 18 volts come here.
        • dspok
          • Jan 2014
          • 553
          • Nepal
          I generally solve shorting with the help of desktop power supply injecting low voltage high amper. The shorted part gets too hot or smokes.
          • ravi_1617
            YY Solutions
            • Jan 2012
            • 343
            • India
            i my case where is the short gpu side or gpu power side
            • fddizon
              • Sep 2011
              • 555
              • Philippines
              too high... maybe shorted upper fets
              • ravi_1617
                YY Solutions
                • Jan 2012
                • 343
                • India
                Fddizon you are correct. Thanks
                both the fets defective .
                but i am unable to get same type & no fets
                so replaced with black fets.(FDS6676)
                which are working fine and display also comming .They are not heating also
                Is it advisable to use them .also attaching images of both sides.
                • fddizon
                  • Sep 2011
                  • 555
                  • Philippines
                  i think they will work the same. if you can fit them without shorting that is fine...
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3578
                    • slovakia
                    NO THAT IS NOT FINE! IT LOOKS LIKE SHIT!
                    Hate this "gluers". Why dont u put in some other mosfet. its normal N-channel 30V 12A mosfet. IT IS IN EVERY NOTEBOOK w DDR2.
                    • fddizon
                      • Sep 2011
                      • 555
                      • Philippines
                      lol
                      • ravi_1617
                        YY Solutions
                        • Jan 2012
                        • 343
                        • India
                        '' Lol '' ktmmotocross
                        This i have just done for testing . how much it is heating.display comming or not.
                        If you dont like it why are u saying to use other mosfet from ram area DDR2 coz that will also be glued.
                        LOL
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3578
                          • slovakia
                          fot testing ok, not for using.
                          ddr2 ram area dont have that high current mosfets. its in cpu, vga or main power area
                          but when i give a closer look, i see that you have other package than regular mosfet
                          • ravi_1617
                            YY Solutions
                            • Jan 2012
                            • 343
                            • India
                            Hi !
                            Finally I go same component metal FETs replaced it was working
                            Fine. Every thing was fine kept in my rack. 2weeks Not yet delivered .
                            AGAIN .
                            for same set same problem .occurred adapter led turn off after inserting in laptop
                            Only one doubt is that .
                            The adapter power is varing for 19 to17volts slowly and again 19volts
                            will this cause short
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3578
                              • slovakia
                              yes
                              • ravi_1617
                                YY Solutions
                                • Jan 2012
                                • 343
                                • India
                                Thanks for quick respons & answer
                                • raajkumar
                                  • Mar 2015
                                  • 354
                                  • Srilanka
                                  I have a problem with my Dell N5110. this worked with External monitor fine. But Led working backlight only not any display on the screen. i checked LCD_VDD and is shown Power 0V. I found U4901 is faulty on this MB. Thereafter i tested with a jumber to pin 3 with pin 4. Display worked fine. i shut down the notebook. But unfortunately this jumber wire has touched with PR4002 ( DCBat out 18V ) after shut down the notebook. Now i changed blown fuse on the led screen and this notebook is giving 8 beep sounds ( Says No display attached. I try with the external also but same ). any one having idea ?
                                  • swapnil1996
                                    • Aug 2017
                                    • 5
                                    • India
                                    Re: Dell N5110 sometime power on sometime not
                                    I have dell inspiron n5110 which is working good yesterday but today morning when switched on it's not turning on when i pressed again it's on for 5 min then automatically off , at the evening again its on for 3 hrs then i shut down. After 30min when i switched on again it's not power on. So what's the problem with my laptop plz help.
                                    • Geeker007
                                      9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                                      by Geeker007
                                      Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                                      I am new to electronics repair, so my queries could be naive but I am ready to learn.
                                      So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                                      01-28-2025, 03:31 PM
                                    • Bowline
                                      by Bowline
                                      06-11-2025, 10:13 AM
                                    • aaronkatrini
                                      DELL Nvidia GTX 750Ti Mosfet goes short after a few minutes
                                      by aaronkatrini
                                      I have recently picked up this Dell OEM Nvidia GTX 750Ti 2GB Video card. Its an old card I know but still wanted to get it working if possible. The problem is the following:
                                      - Put the card in my testing motherboard and start running Heaven benchmark
                                      - Benchmarks seems to run smoothly up until half way then the motherboard completely shuts off immediately
                                      - Try to start it again and I get a slight move from the PSU fan - a clear short
                                      - A little troubleshooting later I find one shorted Mosfet - Replace them both - short is gone
                                      - Put the...
                                      05-18-2025, 04:18 PM
                                    • playit
                                      laptop 19v short circuit dell vostro 1400 motherboard ,need help in repair .
                                      by playit
                                      the comon problem they say , the charger will shut off power once plugged to laptop , i dont have battery, its long gone ago , i use it for backup with adapter and vga port to external monitor(yes no screen lcd) in case my desktop needs fix . one thing for sure i could say the clr resistor - r010 beeps ,short at both sides , the checked all the coils , the 3 coils together gives all of them beeps short along with their respective capacitors . i dont have voltage ampere injection dc machine as in videos i have seen they see where its getting hot and they remove the short and replace components...
                                      02-25-2025, 08:15 AM
                                    • usyusy
                                      Dell E6430 19v line short
                                      by usyusy
                                      Dell E6430 19v line short,
                                      (QAL80 LA-7781P)
                                      19v rail, output side was showing a short (checked after removing CLR), a polar capacitor (PC1074-processor decoupling) in the core section was getting heat, when replaced that cap, the short gone, but when power on the machine, again that cap was heating (even had removed the processor already). so not understanding even no processor attached why this cap was getting shorted again and again
                                      any guidance please.
                                      Schematic:
                                      https://www.badcaps.net/forum/attachment.php?attachmentid=239428&d
                                      08-23-2023, 12:01 AM
