First reset signal on computer, how to work !
  • highpulse
    LongLiveMankind
    • May 2013
    • 1509
    • portugal
    • electronics and music production
    FIRST RESET SIGNAL ON COMPUTER CIRCUIT
    RSMRST#
    When the Power,Bios,Ec are OK, the RSMRST# will go Hi. In the other word,this pin go Low only when the systemreset.If BIOSdata is error,RSMRST# won't go HI.
    When SIO(EC) get +V_RTC
    thecrystal will work.
    1. RTC have to be oscillating(32.768KHz).
    2. RTCRST# have to be high.
    3. RSMRST# have to be inactive (high).
    4. PWRBTN# have a trigger.
    5. LOW_BAT# have to be inactive (high).
    If this 5 present, then EC will issue SLP_S3# /SLP_S5, in the old ICH SLP_S3 and SLP_S5 will generate directly to ICH.
    When All+V?S/+V? powers are ready, PWR_GOOD will tie to high to turn on CPU powers(+VCCP and +VCC_CORE).
    SB/PCH Power good--->SB/PCH pwr_btn--->PCH RUN
    SUSB# from PCH toSIO pull up the signal SLP_S3# The signal is used to shut power off /on through logic gate transistor or IC
    SUSC# from PCH to SIO pull up the signal SLP_S5# The signal is used to shut power off /on through logic gate transistor or IC
    ICH/SB,MCH & CPU Signal Checking
    IMVP_PWRGD => CLK_ENABLE# => RESET_OUT#=> ICH_PWRGD => PLTRST# => PCI_RST=> H_PWRGOOD
    CPU generate the first cycle to read the BIOS code
    CPU bus DMI LPC SPI
    CPU ===> GMCH===> ICH===>SIO ===> BIOS
    CPU MASTER POWER
    VR_ON Enable--->+VCCORE 08VS to 1,5VS
    Memory +VTT and +V1.5VS (DDR3) is ok, the PGOOD VTT_PWRGD pull high to CPU first than ICH will tie H_PWRGD to high ,then NB will tie CPURST# to reset CPU.
    Crystal clock Oscilator CLOCK SUMMARY
    (1) 32.768KHz to SIO Required +V_RTC and to ICH(chipset) also Required +V_RTC
    (2) 49.152MHz to (audio controller) Required +V3S
    (3) 27MHz to Graphic chip (video controller )Required +V3S
    (4) 14.318MHz to (clock Generator) Required +V3S
    Make sure crystal is oscillating for EC(SIO),SB/ICH/PCH and VGA or it will no post
    Clock Generator
    Elementary required
    1) Power : +V3S
    (2) Crystal : 14.318MHz
    (3) Control : PCISTOP# , CPUSTOP#_ is HI
    When +VCC_CORE is ready, CLKEN#will go high to enable clock-Generator and turn all clock.
    PCI_STOP# and CPU_STOP# must beat high otherwise some clocks will be turned off.
    Clock out -->SIO(EC)-->PCH/SB-->NB-->CPU
    LPC_Frame-->SB output signal is high
    Note High signal can be identified by measuring 3.3V available
    Power by experiences of adiedkhaz
  • shijeesh
    • Mar 2011
    • 65
    Re: First reset signal on computer, how to work !
    Highpulse thanks . It is very useful to all. Please upload other topic
    • highpulse
      LongLiveMankind
      • May 2013
      • 1509
      • portugal
      always i got a nice subject i usually post ,
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        ty im a noob at this stuff.. nice guide, tnx
        Im Back... sort of...
        • highpulse
          LongLiveMankind
          • May 2013
          • 1509
          • portugal
          sure mate , we are for help , this is not from myself , credits goes to the name below the following infos.
          • Ramee
            • Jul 2014
            • 218
            • Israel
            Here is the link, found it.
            http://adiedkhazbook.blogspot.com
            • Siddig
              • Jun 2017
              • 275
              • Sudan
              • electronic repairing (hardware laptop) ,Reader, history and Politic
              Good. Thanks
              • Techtiger
                • Oct 2014
                • 1602
                • france
                • Lapy
                  • Dec 2018
                  • 15
                  • algeria
                  • Electronics maintenance
                  Many thanks
                  • charafmak77
                    • Oct 2017
                    • 85
                    • jijel
                    thanks
                    • gmacz
                      • Jun 2018
                      • 43
                      • Sri Lanka
                      Thank you very much Sir.
                      • Gau_saha
                        • Feb 2020
                        • 37
                        • India
                        • listening music ,watching epl ,cricket
                        Thanks Sir ��
                        • bhaskar
                          • Nov 2015
                          • 13
                          • India
                          what about slp s3 and slp s5
                          • danro
                            • Aug 2011
                            • 56
                            • Serbia
                            very interesting and useful post
                            thank you!
                            • aaabddoo
                              • Nov 2021
                              • 17
                              • egypt
                              • read - learn -travel
                              thank you
                              • mitu_sharma
                                • Jul 2015
                                • 182
                                • india
                                wow thanks
                                • mmccomputer
                                  • 78
                                  • France
                                  big thanks bro
                                  • kalilinux25
                                    • Mar 2018
                                    • 2097
                                    • ZAMBOANGA SIBUGAY
                                    • COMPUTER PROGRAMMING
                                    32.768KHz if missing what might it be the prolem?
                                    • Gau_saha
                                      • Feb 2020
                                      • 37
                                      • India
                                      Thanks Sir
                                      • kofe
                                        • Sep 2013
                                        • 32
                                        • Estonia
                                        Thank you very much!
                                        • ictc
                                          Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
                                          by ictc
                                          I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
                                          Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
                                          The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
                                          02-25-2025, 12:15 PM
                                        • jhbgjhvbjh
                                          Lenovo V330-15IKB 81AX / Wistron LV315KB no POST, no DDR clock, SM_DRAMRST# stuck low
                                          by jhbgjhvbjh
                                          I’m troubleshooting a Lenovo V330-15IKB.
                                          Machine identification:
                                          - Model: Lenovo V330-15IKB
                                          - Type / MTM: 81AX001HMB
                                          - S/N: R90S9D0E
                                          - MO: R9N0B8B09010
                                          - Motherboard: Wistron LV315KB / 17807-3M
                                          - RAM: onboard soldered Samsung RAM, no SO-DIMM installed
                                          - GPU: UMA / no dedicated GPU expected
                                          History:
                                          The board came after a previous repair attempt. The BIOS area had visible physical damage / signs of probing or rework. BIOS content was suspected wrong/corrupt.
                                          Current behavior:
                                          07-08-2026, 07:59 PM
                                        • Enlightened-Elf
                                          VF6900 Sat Finder - Signal Jumps Wildly
                                          by Enlightened-Elf
                                          Device Model: FindSat VF6900 Satellite Finder Main PCB Version: VF6900_MB_V1.8 Flash Memory: 64-Megabit / 8MB (25Q64JVSIQ)
                                          The Issue: The signal strength and quality readings jump around wildly (e.g., 5% → 60% → 16%) when fully assembled. When a live satellite coax cable is connected, the unit fails to lock onto or detect any transponders properly, acting "blind" to the incoming RF signal.
                                          I (should) have all tools for repair. The satfinder charges, turns on, buttons all work properly. My issue is when I connect a input signal, the signal either remains...
                                          06-15-2026, 03:48 AM
                                        • MobsterLobster
                                          PCIE / AGP Data Line Tester Repair
                                          by MobsterLobster
                                          Generic aliexpress PCIE data line tester sort of died, A channel barely ever works. Spent forever getting my head around how it works and then fixing it, and thought I'd share.
                                          When button is pressed, the 555 timer makes 93% duty cycle 56hz (the sort of the important part of this) signal at about ~3.6v, that is sent to the ground pins of the pcie slot. On the B channel LEDs that passes straight to each data line and to the anode of the 32 x B channel LEDs to turn each one on. The A channel is quite different as their is a capacitor on each data line (won't let that DC signal through)....
                                          07-02-2026, 10:37 PM
                                        • AstutePauciloquent
                                          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                                          by AstutePauciloquent
                                          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                                          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                                          11-23-2023, 11:02 PM
