Macbook Wine Spill! Is it worth it ?
  • magneh
    • Apr 2014
    • 589
    • Portugal
    Hello!
    A friend of mine asked me to take a look on his Mac Pro that had a wine spill.
    He said it wasnt much, but damaged the mobo anyway.
    Well I got the laptop yesterday and I found some serious damage.
    The LVDS connector had 2 pads that are black! the are gone.
    The LCD cable has also the the respective pads eaten
    I saw a zone with some corrosion , but what seems worse is that a zone near the DC IN has the copper lifted up!
    Here are some pictures of the damages.
    Just wanted to know from more experienced people in these situations, if it is worthy to loose some time and make some mesurements on this mobo, or is it just a waste of time?
    Seeing the connector , the LCD could be damaged right?
    Thanks for any inputs!
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    Re: Macbook Wine Spill! Is it worth it ?
    looks like it's a 820-2327 board and from the picture looks like it can be repaired, but much work to do and depend on your time and spare parts as probably ull need some...
    edit: is that a full layer hole near dc in ? if yes probably mainboard is fully shorted and not repairable
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3597
      • slovakia
      have same here with same problem. im waiting for new lvds connector from ebay.
      its worth it. lvds - 5$, lcd flex - 15$
      • magneh
        • Apr 2014
        • 589
        • Portugal
        Yes !
        It's a full hole layer :/
        Havent took it to my office, but I'll do some mesurements when I get there with the machine...
        Doesnt look good to me but I'll see...
        But even If it's repairable, I would need a similar board to get components or it will be impossible I think... and I Dont!
        Think I'm gonna tell the owner that I cant do much about it ... :/
        • dellxps15
          • Feb 2014
          • 1588
          • italy
          u should check if that hole is shorting some ppv bus, as g3hot , main power and so on. and if u find a short in a lane, u could try to locate the problem on some bad caps, but at the end it can be that hole... and lcd flex, for changing that u have to unglue the screen, and if u are not good in it a new glass will cost a bit.
          check for short however in main white fuse, on that 47omh resistor u see in ur picture, on the ner little coil and all other coil too for short, so u can make an idea of the damage.
          if i remember good, macbook board have almost 12 layers
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            One of the problems you may have is the key board contacts, they will have to be clean well. I think you will find where the copper contacts have vanished it is because a direct short on the contacts themselves. I would think when the liquid connected these two places together it blew them out. If the short was in the board it would have blown that out the same way. One quick way to test for a short on the board is use power supply with current protection and see if the supply shuts down. That way you not only ohm test it but you voltage test it to see if you actually put the operating voltage on it what will happen. Before I did any of this I would clean everything with isopropyl alcohol. It will leave a little residue but nothing like what is on there now. In the old days one would use trichlorethylene or it cousin trichloroethane which would leave virtually no residue. The isopropyl will evaporate almost immediately. Good-Luck!
            • envym
              MacBook Pro 2018 with Activation Lock
              by envym
              Hi everyone!
              I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
              I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
              06-27-2025, 08:54 AM
            • tobeend
              Bypass mdm macbook m2 ventura
              by tobeend
              1. RESET MACOS WITH IPSW
              a. Power off MacBook, press and hold the power button to enter Recovery
              b. Open Disk Utility, remove Macintosh HD
              c. Reboot, connect to the network to Activate Mac.
              d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
              d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
              e. Release the other keys, but keep holding the Power key for another 10 seconds
              f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
              05-26-2023, 07:18 AM
            • SarcasticOP
              General question about MacBook power rails for repair.
              by SarcasticOP
              I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
              • PPBUS_G3H (12.6V-12.8V)
                • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
              • PP3V42_G3H (3.42V)
                • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
              • PPVRTC_G3H (3.3V)
                • This
              12-12-2024, 05:50 PM
            • obelix24
              A2941 Macbook air 15” - 5V 0a
              by obelix24
              I’m working on one macbook air 15” m2 that was water damaged.
              keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
              i’ve put macbook in shelf and order new screen so i can fully repair it.
              Now i got the screen and macbook stays at 5v 0a.
              i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
              i don’t have schematics so i don’t know where to start can someone help me?...
              03-27-2025, 01:19 PM
            • Kush679
              MacBook Pro M1 Activate Mac
              by Kush679
              Sorry,I'm using my phone right now and couldn't find any search bar to search on the topic of macbooks.
              Few weeks back(mid may),I had bought a MacBook pro m1 A2338. It belonged to my friend's younger brother who was a graphic designer,he gave me this MacBook without any icloud account linked to it and I had so much work during that times that I only used it for storage while traveling for shoots (I'm a photographer). So long story short,his brother got involved in a bad accident and was in coma and then fairly recently they pulled out his life support. I mistakenly did an erase Mac and...
              06-20-2025, 09:43 AM
