hp DV6, turn offf after 2sec. no CPU power, only 0,5V ECPWROK signal
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3581
    • slovakia
    Hello.
    Have one DV6 taht power off after 2sec. and have no cpu power. i noticed that ECPWROK signal that drives max8774 is low, only 0.5V.
    any idea? do u thing that MCP is bad?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3581
    • slovakia
    Re: hp DV6, turn offf after 2sec. no CPU power, only 0,5V ECPWROK signal
    i do "SI MODIFY 1219", by moving part D34 > D50, Q44 > Q73, R557 > R830 and add D33
    now signals is good but have only 5.3V on CPU_CORE from MAX8774
    do i have to manualy modify CPU_VID0-5 to have 1.05V ?
    • highpulse
      i hate HP
      • May 2013
      • 1488
      • portugal
      Hey KTM good morning ,
      well cheking what have you wrote , and for my experience on does bloody DV6000 little bastard , not having the PMW temp control will not help in your case , its seems more a MCP problem that anything ,
      but what do you read on KBC controler on S3 states ?
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3581
        • slovakia
        I can do other "SI MODIFY 1219" to make pwm temp working
        but what signals do u mean?
        • highpulse
          i hate HP
          • May 2013
          • 1488
          • portugal
          well but this is like if you are driving you car and you almost have no gas on it , and sudently you put only 5 bucks of gas , you wont expect making much kilometers with 5 bucks , perhaps if you put 30 bucks well then you'lll drive for longer time , think i made myself clear !
          I still think its a MCP problem but for that you must gives us the S3 states reading and also s5 once you press the on off
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3581
            • slovakia
            please be clear. what signals du u need.
            i make manual modify and now have 0.99V on processor, but still no image
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3581
              • slovakia
              its nvidia 8600 graphic so refflow maybe help
              • highpulse
                i hate HP
                • May 2013
                • 1488
                • portugal
                ok you now got at least a decent vcore , but my question is does the cpu get hot ?
                when i mean S3 states , i mean the states send or received by the KBC , if KBC detect something not normal on S3 or S5 , then it will ask for shudown the machine for security .
                So usually on dv6000 series laptop , shutoff problem , are caused by many problems , depending on each board model
                MCP version
                nf6150
                and older northbdrige board are common fault .
                but once again , wich is first your KB revision on board ?
                3926 or 3920 ?
                DNBSWON#1
                VRON
                NBSWON
                RSMRST
                LID_EC (here you must have the powerboard attached !!
                MAINON
                SUSON
                This you find on KBC pins , tell me values with pressing on ,, and then give me values of what happen to each signal once you press the ON button , chek carefully since some will only send a signal and will not stay always present .
                another thing i advise , make a very carefully look out to the board , specially to QFN and small transistors .
                let me know for we can carry on forward
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3581
                  • slovakia
                  i have 3926. All signals and voltages r ok. but still no picture.
                  • highpulse
                    i hate HP
                    • May 2013
                    • 1488
                    • portugal
                    tell me values for all coils = S0
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3581
                      • slovakia
                      all ok
                      • dycc
                        Vision
                        • Nov 2011
                        • 625
                        • Côte d'Ivoire
                        0.99v low for this kind of processor . caps lock must blink indicating a bad cpu .
                        without modification , have you really found why ECPWROK was in low state ??????????
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3581
                          • slovakia
                          no. affter modification all ok but that low voltage on cpu.
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3581
                            • slovakia
                            finaly i fire it up. i put sempron processor 1 core in it and it works. can somebody check for me the voltage of some 2 core processor like TL60, QL60, RM70.
                            • dycc
                              Vision
                              • Nov 2011
                              • 625
                              • Côte d'Ivoire
                              for modification , why don't you just remove D7 diode(page 30) to get ECPWROK in high state ???????
                              • dycc
                                Vision
                                • Nov 2011
                                • 625
                                • Côte d'Ivoire
                                http://en.wikipedia.org/wiki/List_of...icroprocessors
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3581
                                  • slovakia
                                  i dont wanna make this kind of selfrepair. that modification is recomended by HP so i think it will be better idea than removing D7.
                                  its weird that in your list is voltages 0.9-1.1V so my other processors must work but didnt.
                                  • ktmmotocross
                                    Boardkiller
                                    • Feb 2014
                                    • 3581
                                    • slovakia
                                    i have something weird. the core voltage changes even with one processor. i think i have something bad in CPU_VID signals
                                    i changed max8774 and nothing changed
                                    • highpulse
                                      i hate HP
                                      • May 2013
                                      • 1488
                                      • portugal
                                      i agree with dycc i forgot you got AMD CPU so core voltage is bit low , but not working with the original cpu and outhers and only a semprom shows a bad bus to me between cpu and mcp , sceecially once you got a PWRGOOD block insyde the MCP .
                                      • ktmmotocross
                                        Boardkiller
                                        • Feb 2014
                                        • 3581
                                        • slovakia
                                        i think i found it. i have some loose contact in CPU socket. the CPU_VID signals have no conponents in it so it must be in socket, because CPU_VID signal especially CPU_VID5 have floating voltage. i give him/socket/ a little reflow and it looks like it work again.
                                        I put TK57 processor and have 1.12V and work.
                                        Now i give processor little load to see its temperatures.
                                        • AstutePauciloquent
                                          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                                          by AstutePauciloquent
                                          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                                          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                                          11-23-2023, 11:02 PM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • JayPoorJay
                                          Converting +/- 5v to a Usable Hz Signal
                                          by JayPoorJay
                                          Good morning.
                                          I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
                                          This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
                                          The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
                                          08-07-2022, 08:35 AM
                                        • Scruit
                                          What is a normal composite signal range for a C64?
                                          by Scruit
                                          Hello all,
                                          Working on my first C64 / Breadbin / 250407. Purchased as non-working. Getting black screen.
                                          More detail below, but for those that want to get right to the question.... Here are a few waveforms comparing the Pin15 output on the VIC chip (luma/sync) to the pin 4 on the AV socket (composite signal).
                                          https://imgur.com/gallery/PpqcqPY
                                          My question is: Is the composite waveform range of 0.1v-1v too low for a c64?
                                          More detail:
                                          Symptoms are that that I get...
                                          04-28-2022, 05:33 AM
                                        • supravit2000
                                          PS4 fat has inconsistent signal after HDMI replacement
                                          by supravit2000
                                          Hi, guys!
                                          I am not a professional, all I can do is solder stuff on the boards, so I would really appreciate it if someone with knowledge shares his experience/thoughts on a problem I have with a PS4 console.
                                          My friend gave me an original fat PS4, board model SAB-001, with WLOD, that has been previously opened. I changed the HDMI port, couple of pads on the board were ripped, which I connected to the corresponding caps/resistors? Just did so as in a shown diagram (one of the ground pads I ripped off and left it not connected). However, there was still no signal, so...
                                          12-19-2022, 08:08 PM
