Hp Laptop DV7-1245DX turn off after 3 secs.
  • crdz66
    • Nov 2012
    • 242
    Hello Friends.
    I have a hp laptop dv7-1245dx with turn off after 3 secs after push turn on button.
    This laptop comes to me because has overheating past time.
    The laptop was working slow and don't let me reinstall a fresh copy of Windows Vista or Windows 7. (stop a middle of the job)
    So, I decide to do the reflow (20 times success before with another laptops) and now doesn't want keep on.
    My question is.
    Do I screw up the video chip?
    Processor comes badly?
    Any help can be appreciate.
    Thanks.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3602
    • slovakia
    Re: Hp Laptop DV7-1245DX turn off after 3 secs.
    yes u fried the chip.
    • crdz66
      • Nov 2012
      • 242
      ups.
      thanks
      • crdz66
        • Nov 2012
        • 242
        update.
        The indicator light charging is on
        When I push power button turn on even the fan and turn off after 3 secs.
        After that when I press the power button again doesn't do nothing.
        I have to disconnect the power adapter and try again for antoher 3 secs.
        I have the schematic but where do I need look for gpu fail.
        What do I need looking at?
        thanks
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3602
          • slovakia
          check for short on gpu power rails
          • crdz66
            • Nov 2012
            • 242
            Can you tell me with a picture where exactly is?
            Sorry for little knowledge
            • crdz66
              • Nov 2012
              • 242
              I think I find the problem.
              I guess.
              On some of components on the top gpu chip there is not continuity. (3)
              Maybe a shorted????
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3602
                • slovakia
                this ic is sensible to heat and easy can blow. just check resistance of top capacitors on chip. cannot get both side lower than 04ohm
                • crdz66
                  • Nov 2012
                  • 242
                  ok.
                  let me check
                  • crdz66
                    • Nov 2012
                    • 242
                    yeah.
                    the same 3 capacitor show higher resistance,
                    next step.
                    replace motherboard right?
                    • RdeveLabs
                      MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                      by RdeveLabs
                      To all the members here...
                      Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                      So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                      05-05-2025, 04:59 AM
                    • yomama07032
                      Microsoft Surface Laptop 3 (1868) won't turn on
                      by yomama07032
                      I have a Microsoft Surface Laptop 3 (1868) - 13.5 inch. It is the version with the i5, 8 GB of RAM, and 256 GB SSD. I believe the motherboard number is M1098028-008. It has been dead for a year and a half. I tried everything that is suggested on Microsoft's support website. I have the original power supply, and the white light on the power supply's connector turns on and stays on when it is connected to the laptop. Nothing happens when I try to turn on the laptop. The caps lock key's light does not turn on. There is absolutely no sign of life. I have also tried charging the laptop using the USB-C...
                      11-01-2024, 05:25 PM
                    • PacoGT
                      HELP!! Dell E6440 laptop with problem does not turn off and turn itself on help
                      by PacoGT
                      A few days ago my laptop gave me problems, when I wanted to turn it on to my surprise without charging so I did not put much importance on it, after that I turned it on with a charger, it turned on and charged the laptop, the problem with the laptop is that when it is turned off it turns to turn on after seconds, sometimes at 2 or sometimes at 8, other than that it works normally, I already checked many things, I changed a mosfet at the charge input to a pnp but it remained the same, after that I checked and I did not find anything outside Normally, before that, it had a failure where I changed...
                      07-11-2023, 09:31 PM
                      Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                      This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                      09-06-2024, 09:30 PM
                      Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                      This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-06-2024, 08:47 AM
