No 5V found in this Circuit, Please help me.
  • HarryPK
    • Mar 2014
    • 212
    • barabai
    #61
    Re: No 5V found in this Circuit, Please help me.
    marked up
    • satnik90
      • Aug 2012
      • india
      #62
      Originally posted by nazrul145
      Hi there, I have problem with this motherboard. This laptop have no power. I have check only 3.3v is present in P10 but 5V is no there in PL9. I check Pl9 to ground but no short found.
      So I have replaced uP6182 with TPS51125. But 3v present and no 5V.
      I also flash bios. But bad luck.
      So i specially need your help. Please Suggest me how can i find the problem.
      Schematic attached below.
      I wait for your help.
      Thanks advance
      pl replace PC61 (5V FEEDBACK CIRCUIT) OR CHECK 5V FEEDBACK CIRCUIT
      • samanthban
        • Feb 2014
        • 253
        • Sri lanka
        #63
        Originally posted by Compute
        Need voltage PQ67
        Drain
        Source
        Gate
        This gentleman is so helpful.help me too at Russian forum
        sigpic
        • javieromex
          Dell G15 5511 LA-K452P won't turn on
          by javieromex
          Hello, any help will be apprecited!
          • Model: Dell G15 5511
          • MB: LA-K452P
          • Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
          • Customer reported it was turned off and left plugged in during the night and thats it...
          • No signs of liquid damage or burned components.
          Link to Schematics -> https://www.badcaps.net/forum/troubl...la-k452p-gdp50
          I have checked so far:
          04-17-2025, 12:44 PM
        • master3112
          ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
          by master3112
          I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
          When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
          10-29-2024, 09:32 PM
        • Grouickman
          Hofmann geodyna 6300 Wheel balancer
          by Grouickman
          Hi there,
          First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
          Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
          I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
          I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
          03-31-2025, 05:29 AM
        • Astonished
          Fixing the Charge Circuit of the Batteries of the DC Motor
          by Astonished
          Hi friends of electronics
          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
          Please help me fix this circuit.
          (the datasheet of the IC: https://pdf.datasheet.live/28...
          01-28-2025, 06:24 AM
        • redbaron1007
          Liquid damaged macbook A1466 fan spins, but doesn't turn on.
          by redbaron1007
          I got a tricky one today in the form of a macbook air A1466 820-00165-A that will recognize the charger and turn the light green then back to orange and the fan will spin constantly, but the system won't power on. The screen never turns on, it doesn't make the bong noise it's supposed to, and pressing the power button doesn't do anything. When I took the board out to visibly inspect it I only found one spot of corrosion on the bios IC. I pulled the chip, cleaned it and the area with IPA and put fresh solder on both and put the bios chip back on, but when I went to test it again it still does the...
          10-24-2024, 05:45 PM
