Any ideas what kind of damage does a shorted processor do?
  • orientalsniper
    • Apr 2013
    • 461
    Got recently a new laptop motherboard, when I went to power it on after installing it, the motherboard would turn on and turns off immediately (restarting? power cycling?). Found out the processor was shorted.
    So I was wondering which rail should I check? Any chance it fried the northbridge/southbridge? I will start working with it starting tomorrow, so I haven't even checked for schematics yet (can't recall model either).
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    Re: Any ideas what kind of damage does a shorted processor do?
    please, post the platform code and the pc model or the schematic diagram,
    • orientalsniper
      • Apr 2013
      • 461
      Motherboard is 6050A2443401. I attached schematic.
      I'm still not sure what kind of damage a shorted processor would have done. There are 6 pages just for the processor (15-20) in the schematic.
      5V & 3V are present.
      Symptom: All lights turn on and fan running too (1-2 seconds), then all off, then on, keeps going forever like that.
      • reessi
        Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
        by reessi
        Hello:
        I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
        I started on the ACER:
        Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
        All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
        I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
        10-29-2024, 11:31 AM
      • Yanleb
        Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
        by Yanleb
        Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
        I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
        D608, good
        D618 RF101L4S, good (See warning 1 below)
        D619 RF101L4S, good (See warning 1 below)
        D865 RF101L4S, shorted (See warning 1 below)
        IC464 Inverter HA MC74HC1G14, shorted...
        03-09-2020, 12:00 AM
      • modtool
        HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
        by modtool
        Hi to all,
        the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
        I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
        I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
        04-01-2025, 08:22 AM
      • shlomim412
        Macbook Pro a2141 820-01700 - short on PPBUS
        by shlomim412
        Hello
        working on a dead a2141 logicboard - 820-01700
        no power, on usb c ampmeter it's on 5v drawing 0.01a
        visual inspection under the microscope - board look good, no liquid damage on any kind of damage.
        ppbus_g3h is 0.3v, and is shorted to ground showing around 50ohms (continuity beep) and climbing..
        i removed F7000 and F7001 and now getting 12v on PPBAT_G3H..
        also verified the short is on the system side (pin2 of F7000\1)..
        i tried to inject voltage, 1v to ppbus_g3h but it's only drawing...
        07-01-2023, 04:09 AM
      • JoelJ
        Ampeg PF-350 bass amplifier head repair
        by JoelJ
        Hello everyone!
        I recently bought a broken Ampeg Portaflex PF-350 bass amplifier head in unknown condition. As it turns out, it's completely dead. Tried powering it on with the dim bulb tester, dead short.
        I have attached the schematic below.
        What I found:
        TH1 is cracked visibly but measures 6 ohms. Will replace it but should be okay for testing for now.
        Either Q1 or Q2 was dead shorted. Don't remember which one but one of them. Both are FQPF12N60C. I replaced both with SiHP18N50C to test as I had these on hand. They are the same package, pinout, mosfet type....
        09-09-2025, 08:37 AM
