Clicking/Ticking motherboard
  • p1muserfan
    • Apr 2014
    • 184
    My Acer M5-481 has a clicking/ticking sound coming from the motherboard with the charger plugged in until the board is started. After it starts, no more ticking. Board also won't start with both battery and charger connected. In fact, when board starts with adapter and then battery is connected, board cuts off. Guessing both problems related.
  • p1muserfan
    • Apr 2014
    • 184
    Re: Clicking/Ticking motherboard
    Trying to bump this to get some direction from somebody. Have done some more testing. PQ48 (battery fet) measures .47v in one direction in diode mode, open in the other direction (like I believe it should). However, I'm reading close to charger voltage (albeit fluctuating because of the ticking) at the positive battery terminals (with no battery connected of course). So is PQ48 the culprit here?
    • highpulse
      i hate HP
      • May 2013
      • 1490
      • portugal
      this is a clear sound of a leaky mosfet , chek does mosfet were you notice power on only one side and that on the outher side you got reduced voltage , chek on diode mode , and chek between D and S and S to D obviously depending on P channel or N channel , so depending on the channel type you will have value only on one side menawhile the other should give you 1 (infinite)
      let us know your readings
      • p1muserfan
        • Apr 2014
        • 184
        PL13 (p. 31) turned out to be the source of the ticking, removed it and the noise is gone. How do I find another coil? The label on the schematic for PL13 appear to be just specs and the only marking on the part itself is 6R8. Apparently that is code for something?
        • p1muserfan
          • Apr 2014
          • 184
          Back at it with this board, got to figure out the problem. With PL13 removed and bench PSU set to 1V and 2A, I draw 2A and 1V on one pad (continuous current light goes on) and .96A and 1V on other pad (continuous voltage light stays on). Both PQ49 and 51 are heating up on the 2A 1V side pad. Removed both PQ49 and 51 and both pads showing 1V and 0A, so apparently those 2 are culprit (will need to order more chips). Or did something cause them to blow? Would a failing coil (PL13) make a clicking/ticking noise or could the problem still be a leaky mosfet as highpulse has suggested?
          • dj_ricoh
            • 2073
            • uk
            ok!
            good start there.
            so you have lifted pl13, pq49 and pq51
            pq49 1,2,3 = ground
            pq51 got 5-8 with some caps to ground
            pl13 short to mosfets or other side?
            • p1muserfan
              • Apr 2014
              • 184
              New chips for PQ49 and PQ51 but same result, board shorts immediately upon being plugged in. Reread above posts and per highpulse's suggestion (post #3), checked PQ48 in diode mode in circuit and after removing. Open both ways. Attached data sheet for fet (circuit configuration, p. 1), it should only have flow in one direction, correct? Would that explain why Pq49 and 51 are getting fried as soon as the board is plugged in if that fet is letting voltage by?
              • p1muserfan
                • Apr 2014
                • 184
                New PQ48, same result. Of course when the 3 chips are removed from the board , the short is gone. So something common to all 3 is taking them out. Would like to replace chips and remove charger chip but have read that's a really bad idea. Anybody with a good idea
                • dj_ricoh
                  • 2073
                  • uk
                  so you lifted PL13?
                  what side its shorted? to ic (left side ) or right side?
                  • p1muserfan
                    • Apr 2014
                    • 184
                    Originally posted by dj_ricoh
                    so you lifted PL13?
                    IC side of PL13 is shorted. When both fets and charging chip are removed from board, no short. Short only comes back when PQ49 is put back on the board by itself
                    • dj_ricoh
                      • 2073
                      • uk
                      so on the PQ49 PAD without the fet, what pins are shorted to ground?
                      ASIDE from 1,2,3 that are connected to ground.
                      • p1muserfan
                        • Apr 2014
                        • 184
                        That's the mystery about all of this, no pins on either PQ48,49,51 or PU6 are short except the ones that are suppose to be (1,2 and 3 of 49 and 14 of PU6). But something is killing 48,49, and 51 as soon as board is plugged in. There has to be a short somewhere else.
                        • p1muserfan
                          • Apr 2014
                          • 184
                          Changed BQ24707, board no longer shorts when plugged in. Getting there, I think. Next problem is 3,5V. Only have VIN, .4v at both Boot 1 and 2, and 1.5v at PGOOD (PU1 p. 32). Chip is good, came off other board. No lines with chip removed are shorted. Where to start?
                          • p1muserfan
                            • Apr 2014
                            • 184
                            Finally got this board started on my bench once with screen connected. Then put it in computer case and board won't start again. Back on bench, have 3v at bios chip, 3 and 5v from coils, 3v at power switch. But RSMRST missing. What else do I need to be checking for?
                            • Solvik
                              XFX XPS 650w 3XS PSU making Ticking/clicking sound
                              by Solvik
                              Hello
                              i have a older powersupply from XFX that makes this wierd electronic ticking /clicking noise. Its not the fan thats making the sound. See video below. Is anyone familiar with what component this sound can come from?
                              All voltages are normal....
                              02-13-2025, 02:43 PM
                            • motormayhem
                              Lenovo T460 Only Charges on One Charger
                              by motormayhem
                              Laptop Question
                              I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                              A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                              05-12-2023, 01:46 PM
                            • glovecaps
                              by glovecaps
                              11-25-2024, 04:23 PM
                              NVDC charger configuration...
                              11-05-2024, 03:28 PM
                            • flat-earther
                              how to prevent a connected charger from draining battery when not charging?
                              by flat-earther
                              I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                              So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                              but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                              So the battery is backfeeding the charger and being drained.
                              How can I prevent...
                              08-07-2025, 01:04 PM
