Dell XPS 15z does not charge
  • hazardus
    • Apr 2014
    • 105
    I got another Dell XPS motherboard with charging problem.
    When I measure 3.3V and 5V these are not present when the charger plugged.
    Anyway the laptop turns on if you press the power button. I believe this is why it's not charging. What could be the problem? Bios?
  • angel-boy
    • 550
    Re: Dell XPS 15z does not charge
    Hy , you can try a dump bios, but i`m not sure will resolve the charging problem.
    I think that the C.l. charging is the problme, possibly a voltage source.
    • hazardus
      • Apr 2014
      • 105
      I changed the charger IC it's charging but really slowly.
      PL10 shows 15.3V without charger. With charger 15.8V. It should be above 16V I believe because the battery almost fully charged but anyway after an 1 hour charge it went from 91% to 95%. I checked everything around the charger circuit but I didn't find anything suspicious. Anyone?
      • hazardus
        • Apr 2014
        • 105
        I checked the PL10 with scope and looks like both side is straight 15.7V. So PWM doesn't work. I replaced the chip again but I got the same result. I attached a pdf. The highlighted components are checked and those looks fine. What should I check? What could be the problem?
        • dellxps15
          • Feb 2014
          • 1591
          • italy
          how old is the battery? do a dell diagnostic cd.
          • hazardus
            • Apr 2014
            • 105
            I've two different batteries and both are in working condition.
            • albertooo
              • Jul 2016
              • 26
              • china
              I have the same problem,,how did you solve it
