Dell XPS 15Z 2beeps
  • hazardus
    • Apr 2014
    • 105
    Dell XPS 15Z 2beeps
    I've a Dell XPS 15z with two beeps and no screen issue. I tried a different RAM it didn't help.
    I replaced the SLJ4P chip with a new one but didn't help. What should I check?
    Thanks.
  • nazrul145
    • Jan 2014
    • 337
    • BD
    Re: Dell XPS 15Z 2beeps
    2 beep means ram not detected, you should clean ram slot. also you can change different cpu and flash bios.
    • dellxps15
      • Feb 2014
      • 1598
      • italy
      when u power on do you have 1.5volt on ram power coil?
      • hazardus
        • Apr 2014
        • 105
        Re: Dell XPS 15Z no backlight
        I changed the FETs and I got the 1.5V. Now it's turning on just no backlight. I checked KBC and on Pin47(LCD_BAK) I've nothing. I checked Pin70(PANEL_BKEN) and I've 3.3V there. What could be the problem? Why I don't have anything on Pin47?
        • dellxps15
          • Feb 2014
          • 1598
          • italy
          lcd_bakc could be 0 because it is setup to the maximum brightness.
          try other flat cable or lcd if u can as u have bk enable voltage.
          • hazardus
            • Apr 2014
            • 105
            I forgot to mention that I tried with another display and different cable but nothing.
            Edit: Also If you have time to take a look at the Page 27 you can see that the backlight enable pin name is LCD_BAK that's why I thought there should be something.
            • dellxps15
              • Feb 2014
              • 1598
              • italy
              edit:
              pin 36 lcd_bak is backlight enable
              u15 voltage on pin 120?
              PS: did u connect back the little board for lcd open close signal ?
              • hazardus
                • Apr 2014
                • 105
                I got another board plugged it in and it shows picture so I guess something is wrong with my motherboard. I'll check those pins but I believe U15 should show something on Pin47.
                • dellxps15
                  • Feb 2014
                  • 1598
                  • italy
                  compare u15 pin 120 voltage.
                  • hazardus
                    • Apr 2014
                    • 105
                    Yeah, you are right. On the working board I measured pin120 and it shows 0V and on the nonworking board I've 3.3V. Gosh.
                    • hazardus
                      • Apr 2014
                      • 105
                      Checked R260 shows 0.7K in circuit. I removed it but it's fine because out of the circuit it shows 10K. I never understood what does can pull down the resistance?
                      • hazardus
                        • Apr 2014
                        • 105
                        So I've 0V on pin120 on the working board. I removed R260 from the other board. Guess what? Still no backlight! That's not the right direction.
                        Edit: I need that 3.3V on LCD_BAK pin47 without it I won't have backlight.
                        • hazardus
                          • Apr 2014
                          • 105
                          It was the KBC. solved. Thank you!
                          • Bowline
                            by Bowline
                            06-11-2025, 10:13 AM
                          • cygron
                            Dell Latitude 3440 2 Beeps Problem
                            by cygron
                            Model: Dell Latitude 3440
                            Board id: DL340-HSW MB 13221-1 Rev: A00
                            Laptop produce 2 beeps. RAM is ok (replace and test). And i think RAM Slot is also ok. Board have 2 RAM Slots. All coils have voltage expect PL5101. DRAMRST has only 0.12V. BIOS flashing can't solve the problem. Need help.
                            PL4503 - 3.3V
                            PL4101 - 5V
                            PL4902 - 1.35V
                            PL4801 - 1V
                            PL4701 - 1.7V
                            PL4401 - 17V
                            PL5101 - 0V
                            PU5102 pins -
                            Pin 1 - not stable ( 0.5, 1.3, 5.9 etc ... )
                            Pin 2, 4 - 0V
                            Pin 3 - 0.95V
                            Pin 5 - 2.87V
                            Pin 6 -...
                            04-20-2025, 03:46 AM
                          • Akhlz001
                            by Akhlz001
                            09-20-2025, 07:15 PM
                          • mohamed mm
                            Dell inspiron 5520, 7 beeps problem
                            by mohamed mm
                            I've an Inspiron laptop model 5520, board name, la 8241p, with a 7-beep problem.
                            exist voltage:
                            PL 200:3.3v
                            PL 201:5v
                            ram volt PL300: 1.5v
                            PL600: 0.9v
                            PL500: 1.0V
                            PL 202: 19V
                            Processor section:
                            PL701: 1.2V
                            PL702:1.2V
                            but PL704: 0.0V
                            and PQ705 / PQ706 are zeros on gate/drain and source.
                            PC724/PC712 : 19V.
                            bios volts:
                            EN25QH16 / EN25Q32B: 3.3v.
                            I tried to program a (W25Q32B) BIOS chip with an (EN25Q32B) BIOS dump from the internet, but during verification, it says
                            08-22-2025, 07:13 AM
                          • master3112
                            by master3112
                            07-29-2025, 01:55 PM
