Dell XPS 15Z 2beeps
  • hazardus
    • Apr 2014
    • 105
    Dell XPS 15Z 2beeps
    I've a Dell XPS 15z with two beeps and no screen issue. I tried a different RAM it didn't help.
    I replaced the SLJ4P chip with a new one but didn't help. What should I check?
    Thanks.
  • nazrul145
    • Jan 2014
    • 335
    • BD
    Re: Dell XPS 15Z 2beeps
    2 beep means ram not detected, you should clean ram slot. also you can change different cpu and flash bios.
    • dellxps15
      • Feb 2014
      • 1588
      • italy
      when u power on do you have 1.5volt on ram power coil?
      • hazardus
        • Apr 2014
        • 105
        Re: Dell XPS 15Z no backlight
        I changed the FETs and I got the 1.5V. Now it's turning on just no backlight. I checked KBC and on Pin47(LCD_BAK) I've nothing. I checked Pin70(PANEL_BKEN) and I've 3.3V there. What could be the problem? Why I don't have anything on Pin47?
        • dellxps15
          • Feb 2014
          • 1588
          • italy
          lcd_bakc could be 0 because it is setup to the maximum brightness.
          try other flat cable or lcd if u can as u have bk enable voltage.
          • hazardus
            • Apr 2014
            • 105
            I forgot to mention that I tried with another display and different cable but nothing.
            Edit: Also If you have time to take a look at the Page 27 you can see that the backlight enable pin name is LCD_BAK that's why I thought there should be something.
            • dellxps15
              • Feb 2014
              • 1588
              • italy
              edit:
              pin 36 lcd_bak is backlight enable
              u15 voltage on pin 120?
              PS: did u connect back the little board for lcd open close signal ?
              • hazardus
                • Apr 2014
                • 105
                I got another board plugged it in and it shows picture so I guess something is wrong with my motherboard. I'll check those pins but I believe U15 should show something on Pin47.
                • dellxps15
                  • Feb 2014
                  • 1588
                  • italy
                  compare u15 pin 120 voltage.
                  • hazardus
                    • Apr 2014
                    • 105
                    Yeah, you are right. On the working board I measured pin120 and it shows 0V and on the nonworking board I've 3.3V. Gosh.
                    • hazardus
                      • Apr 2014
                      • 105
                      Checked R260 shows 0.7K in circuit. I removed it but it's fine because out of the circuit it shows 10K. I never understood what does can pull down the resistance?
                      • hazardus
                        • Apr 2014
                        • 105
                        So I've 0V on pin120 on the working board. I removed R260 from the other board. Guess what? Still no backlight! That's not the right direction.
                        Edit: I need that 3.3V on LCD_BAK pin47 without it I won't have backlight.
                        • hazardus
                          • Apr 2014
                          • 105
                          It was the KBC. solved. Thank you!
                          • Bowline
                            by Bowline
                            06-11-2025, 10:13 AM
                          • cygron
                            Dell Latitude 3440 2 Beeps Problem
                            by cygron
                            Model: Dell Latitude 3440
                            Board id: DL340-HSW MB 13221-1 Rev: A00
                            Laptop produce 2 beeps. RAM is ok (replace and test). And i think RAM Slot is also ok. Board have 2 RAM Slots. All coils have voltage expect PL5101. DRAMRST has only 0.12V. BIOS flashing can't solve the problem. Need help.
                            PL4503 - 3.3V
                            PL4101 - 5V
                            PL4902 - 1.35V
                            PL4801 - 1V
                            PL4701 - 1.7V
                            PL4401 - 17V
                            PL5101 - 0V
                            PU5102 pins -
                            Pin 1 - not stable ( 0.5, 1.3, 5.9 etc ... )
                            Pin 2, 4 - 0V
                            Pin 3 - 0.95V
                            Pin 5 - 2.87V
                            Pin 6 -...
                            04-20-2025, 03:46 AM
                          • tech_guru
                            Dell Inspiron 5558 8 Beeps
                            by tech_guru
                            Hello.
                            If you can help with this one please...The laptop does 8 beeps at boot which as I see is LCD error. The laptop shows image to external monitor normally. New screen flex and screen does not change anything.
                            So I took measurements in the LCD socket (LCD1):
                            DCBATOUT_LCD 19V
                            LCDVDD_LCD 3.3V
                            DBC_EN_R 0V
                            EDP_HPD_CONN 3.2V
                            LCD_TST_C 0V
                            EDP_AUX 3V
                            EDP_AUX# 0V
                            EDP_TX0# 0V
                            EDP_TX0 0V
                            EDP_TX1# 0V
                            EDP_TX1 0V
                            LCD_BRIGHTNESS 0V
                            BLON_OUT_C 0V
                            PANEL_SIZE_ID_CONN 0V​
                            The ones that are 0v,...
                            02-18-2025, 02:13 AM
                          • tech_guru
                            Dell Alienware 17 R3 - LA-C912P Motherboard repair - 7 Beeps
                            by tech_guru
                            Hello.
                            I am having a disappointing motherboard repair with this laptop and I need your help.
                            This came in with water damage, doing absolutely nothing, and had almost all standby voltages shorted. I have already replaced all those shorted components:
                            -UE5 SIO KB9022QD - Programmed spare one, when replaced, 3.3v short got out
                            -PQ102 MDV1525URH
                            -U17 AOZ1331
                            -UE1 C8051F383-GQ
                            -PU800 SY8032ABC
                            -UI2 SY6288D20AAC
                            -PU508 RT6220AHGQUF 7P=
                            -PU100 TPS51225CRUKR
                            -PU300 TPS51212DSCR
                            Now, I get all the standby voltages, it turns...
                            02-16-2024, 09:40 AM
                          • F R 2568
                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                            by F R 2568
                            Hello all,
                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                            If the laptop is only connected to the AC adapter (battery removed):
                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                            The power/battery...
                            01-08-2025, 05:45 AM
