Samsung N150Plus no screen at boot
  • Scootie
    • Feb 2014
    • 133
    Im trying to see what's the problem with this netbook.
    It starts but no screen on main screen or external. I wanted to start with a bios updated but cant find a bios dump anywhere. I have it checked already, electronicly has no issues.
    Motherboard model: PONTIAC-R, Rev: PR1.0(100415)-4
    Laptop Model: NP-N150-JP01AT
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Samsung N150Plus no screen at boot
    What - nobody - My interest is that I have a N250+ with same symptoms.
    oddly I think it may have the same board BA2-06885A.
    This board usually only gets mentioned as being in a N250+ or the N145+ so finding one in a 150+ is new.
    Have you tried resetting the bios/cmos - see here
    http://www.sammynetbook.com/forum/th...he-ram-at-N150
    I thought I had tried it but not sure I got it right - I will have another go.
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      backup old bios before all
      here are the dumps
      1 dump from working laptop sub-model jp02ru
      2 extracted from web update
      3 extracted from web, different version
      hope it helps
      Im Back... sort of...
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Well Scootie how did it go? could you load the bios?
        What number is your board?
        • kenkaniff
          HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
          by kenkaniff
          Product Name: HP Pro x360 Fortis 11-inch G9
          System BIOS: U94 Ver.01.08.00 10/06/2023
          Serial Number: 5CG31946F5
          SKU Number: 85W05EC#AK8
          Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
          This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
          I needed to remove bios password...
          10-01-2025, 04:32 AM
        • arbitarytwist
          Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
          by arbitarytwist
          Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
          Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
          03-01-2025, 01:16 PM
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • claws77
          FX553VE-DM318T(FX553v) not POSTING
          by claws77
          Cpu i7-7700hq Ram - 8gb samsung, 32 gb sk hynix
          Gpu - nvidia geforce 1050ti
          Ssd orion o700
          Hdd hgst721010A9e630
          See images
          What's not working right?
          The system does not even POST, display is black,
          LEDs on - power led, aiplane mode, capslock fpr few seconds in the start(when connected to ac power) only.
          When did the problem happen?
          My laptop had dual boot setup, ubuntu and windows 10.
          It already had a moklist error, that would occur when i tried to boot ubuntu.
          05-17-2025, 04:09 PM
