Hi I have an msi cr620 that suddenly turned off completely and now will not power up. I have tried another fully charged battery and another power supply, but the computer still has no lights at all and no fan running. No lights. It is dead. I have stripped it down to bare bones and tested the memory, tried a new hdd still no joy. I have the shematic and will start to go through the circuits, but I wondered if anyone has any hints about where to start, has anyone had this before and cured it etc. Any guidance would be appreciated. Thanks.
ms-16811 no power
Re: ms-16811 no power
pictures and the schematic might helpPlease upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Here is the schematic. it is the right one. the mobo is ms-16811 ver 1.1Attached FilesComment
When you plug in the charger does the led stay on?
Can you post a close up picture of the area around the power plug - both sides.
No voltages anywhere on the mainboard? - coils are easy to test.Please upload pictures using attachment function when ask for help on the repair
Can you find this PQ16 P-AO4433 on the board - it is a soic8 and should have 19v on pins
1,2,3. see schem page 39Please upload pictures using attachment function when ask for help on the repair
The led on the charger stays on yes. No short there. There are no leds lit on the computer at all. I am away from home till Tuesday, but will post photos then. There is voltage on the board as far as pins 5,6,7 and 8 of PQ16 so DC_IN+ is present. that is as far as I got. I need to identify more components, but it will have to wait till Tuesday now. There is also no response with a freshly charged battery, so it has to be common to both voltage scources.Last edited by davegeer; 01-02-2015, 11:19 AM.Comment
Well as you have some power t the motherboard I would have a good look at and test the button board and ribbon and connector. I see a button board on ebay.
http://www.ebay.co.uk/itm/MSI-CR620-...item27e781f7d8Please upload pictures using attachment function when ask for help on the repair
Hi
Does anyone have a solution for this issue, as my dad has a msi A6200 laptop with this motherboard and exactly the same problem it wont turn on. No lights on the laptop and the light on the charger goes dim and flashes when connected to the laptop. I found the PQ16 chip on the board and tested to see how much voltage was going through and my dads multimeter was showing about 1/4 of a volt, that was through pins 4 and 8. All other pins on that chip showed no signs of power.Comment
Bro your main board have shorting any where first check it. Check capacitor near power IC and near battery connector they should not short.Comment
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by liquidzorchHello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
- Loading...
