mesi ex610 Critical Temperature when try to install system
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3610
    • slovakia
    Hello. Have this one MS-163D that showing critical temperature 169C!!!!,
    but work normal, except cannot install system due to temp fail.
    work normal on some ubuntu live cd.
    i dont have another athlon x2 processor to check. any clue?
    schematic will help.
  • dj_ricoh
    • 2073
    • uk
    Re: mesi ex610 Critical Temperature when try to install system
    how is the thermal compound? it was ok when you open it for the first time?
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3610
      • slovakia
      as always it was hard and dry. i always replace it with acrctic x2
      • Compgeke
        • Feb 2014
        • 524
        How about the heatsink\fan? I notice that one has a fairly large heatsink but if it's not making contact or the fan isn't working you'll have issues.
        It's also worth checking to see if the GPU or chipset originally had a thermal pad and whether or not it still exists or if someone replaced it with thermal paste but didn't use a shim.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3610
          • slovakia
          Every thing works good in some ubuntu live, without problems.
          system tells me that it have 191C so something must be bad. dont know if the processor or something on the board because dont have schematic to check it.
          • japlytic
            DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
            by japlytic
            In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
            Tried (only with keyboard/mouse connected):
            • BIOS + database update
            • Using latest Windows 11 image built with official image creation tool
            • Previous setup version for Windows 11 installer
            • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
            • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
            • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
            06-19-2025, 04:59 PM
          • CapLeaker
            AcuRite 5 in 1 temperature sensor replacement repair
            by CapLeaker
            Got a new victim:
            AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
            A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
            B: stuck at some temperature and maybe updating once in 12 hrs or so.
            Easy solution is to go to AcuRite website and purchase the sensor. Right?...
            04-15-2025, 01:32 PM
          • iMuhtaseb
            A1706 2017 critical update
            by iMuhtaseb
            this board suffered from a bad trackpad and bad keyboard after liquid damage; board was turning on no issues..
            we've replaced the bad trackpad and bad keyboard no issues whatsoever.. during 2nd final checkup we booted to an external macOS and there started the critical update issue; it boots externally but to the internal SSD it shows critical update; tried Wi-Fi tried Ethernet tried Hotspot same thing..
            One weird symptom is it takes too long to power on and show the Apple logo for some reason..
            I've taken a look into the MLB and noticed tiny liquid around Q3100.. its...
            08-13-2024, 08:41 AM
          • 24gsm
            MacBook Pro A1708 install macos fail
            by 24gsm
            hi to all
            i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
            after enter to recovery and format hdd 1to .
            after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
            can help please
            Serial Number: FVFXP0U0HV2J
            Config Code: HV2J
            Find My Mac: OFF
            04-16-2025, 03:57 AM
          • duwane
            A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
            by duwane
            Hi All.
            Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
            The issue:
            Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
            10-26-2022, 07:02 AM
