Toshiba C660 no power
  • diif
    • Feb 2014
    • 6978
    • England
    Hello, i have a Toshiba C660 with motherboard LA-6842P.
    There's no lights or fan when i power with my bench supply.
    No voltage at the power switch, but i have tested it is working.
    I can find 18.90v around the charging section but no 3v or 5v.
    18.9v is also present at PQ21 and PQ22 but there are no other voltages.
    Is that suggesting PU6 ?
    Any other suggestions ?
    Thanks.
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: Toshiba C660 no power
    First check the rails for shorts to ground. PU6 could be faulty or many other things around it. Download it's data PDF to discover things to check.
    pin13 needs to see 2.4v or higher.
    Also check for any movement on the rails as you apply power. I had a fault in a Samsung that was causing the ALW5v to go higher than 5v at power on, then drop back to 0v, all in a few milliseconds. Need a CRO to catch this.
    • diif
      • Feb 2014
      • 6978
      • England
      Thanks rievax, i only get 1.7v on pin 13 of PU6.
      • rievax_60
        • May 2012
        • 897
        • australia
        There could be a fault with the resistor divider. Also check for 19v on VIN pin16. avoid measuring this directly at the IC pin. If your probe shorts to an adjacent pin, you will have more trouble.
        • diif
          • Feb 2014
          • 6978
          • England
          Yes, there is 18.9v on pin 16.
          • diif
            • Feb 2014
            • 6978
            • England
            Can you advise me where to check for 3v and 5v ? I am unsure which component/s convert the 19v down to the lower voltages.
            • rievax_60
              • May 2012
              • 897
              • australia
              Did you see the data PDF for the UP6182? There are 2 sets of regulators, linear 3.3v and 5v, and SMPS 3.3v and 5v. When power is applied and before the power button is pressed, the 2 linear regulators, pin8 and pin17 should be up. When the power button is pressed, the 2 SMPS rails are supposed to come up. These can be found at the 2 coils, PL4 and PL5.
              pin13 EN needs to see 2.4v or more before anything else can work.
              • diif
                • Feb 2014
                • 6978
                • England
                Thanks rievax, i'm fairly new to diagnosing and reading diagrams.
                I have downloaded the pdf and now understand a little better.
                I only have 1.7v on pin 13 can you tell me where that feed comes from ?
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3641
                  • slovakia
                  check resistance and voltage on both pins of PR87
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    Well, I cleaned up the area around PU6 with some ipa and have measured again. I am now getting 3.14v and the power LED.
                    I have connected up the screen and it's booting. I shall reassemble and report back.
                    Thanks again for your help.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      Hello again, i'm back with this one.
                      It seems that it has has some liquid enter at some point judging by the stain on the back of the keyboard.
                      All is working well apart from sound. The device is installed and shows in Windows. The sound driver installs ok, however there is a pop sound on turning on the laptop and then again as the screen goes black before the windows desktop.
                      I've tried headphones and alternative speakers and still the same pop
                      I'm not sure what to look for but i have checked some voltages on the ALC259Q chip.
                      Pin1 3.3v
                      Pin25 5.15v
                      Pin38 5.15v
                      As always your knowledge is gratefully received. What do i need to check ?
                      • reaper57
                        • Sep 2014
                        • 216
                        • Norway
                        If it's popping it's trying to do something, but there seems to be something stopping it from outputting sound. Do you have sound with external speakers? And what happens when you unplug the build in ones and plug in only external ones or headphones?
                        Keyboard not detected, press F1 to continue...
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          No sound with any combination of speakers or headphones.
                          Nothing happens when i unplug the built in speakers, or plug them back in.
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            Any ideas what i can check please ?
                            • dj_ricoh
                              • 2073
                              you need a scope on the chip.
                              you can check the output
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                Would a simple scope like a DS201 be suitable ricoh ?
                                • dj_ricoh
                                  • 2073
                                  yeee
                                  i got this ! i fix headphones, all types of audio ports;
                                  i had a asus that non of the out work i check on the chip; nothing show but when i inserted a jack in front the internal speakers power up check on the chip , there was a short with the jacks so i left the short in jack to activate the internal speakers. the guys was happy me happy moved on.
                                  it will do the trick!
                                  the main thing i use it for is to see if BIOS chips active before power button press
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    Cheers, i shall work out how to work this thing and i'll test to see if i get any ouputs from the chip.
                                    • diif
                                      • Feb 2014
                                      • 6978
                                      • England
                                      I bought an identical faulty board to swap components from to try and fix this.
                                      On power PU6 gets red hot instantly so i was going to replace.
                                      It is marked 51125A although the schematic indicates a UP6182.
                                      I've done a search on here, that indicates they are compatible, is one better than the other ?
                                      • meritosari
                                        • Oct 2010
                                        • 774
                                        • Indonesia
                                        yes you can change with that. i think its same quality
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          09-06-2024, 05:27 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
