Hi, I've been working on an Advent Monza Red (I believe it's an S100, but the only labels on the unit say "Red") with broken screen brackets. Made sure it was disconnected, battery was out, grounded myself, and set to work. Only had to disassemble the base to attach the new hinges, in and out of there in 10 minutes. Everything is connected up properly, reassembled, and now - dead.
On A/C there are no lights, no response from power switch. Removed the battery, still nothing. Tried with battery only, nothing.
I've tried removing the battery and A/C and holding the power button for 2 minutes, I checked the CMOS battery, found it to be almost dead, and replaced it, still nothing.
The A/C adaptor seems to be good, checked it for voltage, all good. Tried another known good charger, just in case, still no good. Tried leaving it for 5 days untouched in case of a build up of static that needed to dissipate. Put it back together today, still dead.
I've pulled it apart again, tested the switch itself for continuity, disconnected everything and tried again. Ive checked for voltage from the DC jack along a few components, but without a schematic (or any real experience using them), I'm now at a loss.
The motherboard seems to have 3 different stickers with part numbers on, the only thing connecting the 3 is J141M
I'm assured that it was working when given to me (I really wish I'd checked it first - schoolboy error). The symptoms were a cracking sound when opening/closing the lid. As the plastic bezel around the screen was cracked at the points the hinges were broken, I assumed it was this. I suppose the cracking *could* have been the screen cable being damaged by the sharp broken edges of the screen brackets and sparking, although I see no sign of external damage to the cable.
Photos of the mobo attached. Any help would be much appreciated
