sasmsung problem charging
  • reizal
    • Oct 2014
    • 111
    • aceh
    please help, samsung np300v3a plugin fully battery charger, unplug the charger immediately die, note "the new battery
    Hidup yang benar2 membosankan.. hek that bak mita peng
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    Re: sasmsung problem charging
    hi,
    i think the battery mosfet is bad try to change it, and try to swap the two mosfet if you are unable to buy a new one.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3575
      • slovakia
      even new battery can be totally dead not chargable. seen it many times.
      but i suggest u to check charger ic pins
      • pertican
        • Nov 2014
        • 10
        • iran
        Change Or check Power adapter ,(using bench power supply Instead of adapter )
        Download Schematic And check Charger IC And Components (Mosfets , Caps , Fuse ,...)
        Check Voltage On Charger IC
        • reizal
          • Oct 2014
          • 111
          • aceh
          thank U all for your respect, I'll try to replace the first mosfet,
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3575
            • slovakia
            why replace? u must check if is bad. do u want to replacing all parts on board until u find one bad?
            • polytek
              • Dec 2013
              • 496
              • TUNISIA
              it's easy to change one mosfet, but it's difficult to change charging ic, my answer was based on my proper experience, because i have repaired two laptop with the same problem (platform scal 2 and scala 3)
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3575
                • slovakia
                its easiest than check it for error?
                • pertican
                  • Nov 2014
                  • 10
                  • iran
                  Your problem is one of the components
                  Regards
                  • reizal
                    • Oct 2014
                    • 111
                    • aceh
                    Regards
                    thank you this is very helpful, I replaced all like the ones in this picture and the problem is complete, hehe, I am still in the learning stage repair laptop world, so my knowledge is still very low on a more detailed examination of each of each component, with the help of the master here I say a thousand thanks
                    thank you all
                    • flat-earther
                      ASUS X54H laptop thinks it's always charging even with charger unplugged
                      by flat-earther
                      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                      Windows also shows ''Plugged in'' when charger is not connected.
                      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                      If I let battery run out and say it has 3% Windows will...
                      06-24-2025, 09:32 AM
                    • ahmarzo
                      Hp laptop charging problem
                      by ahmarzo
                      Have hp laptop motherboard part no opp 17 diner skl/kbl 15289-2 with charging problem.the laptop shows plug in charging but percentage doen not increases.the schematic or boardview is not available.
                      Charging ic is bq737 with voltages on pin no
                      1&2 -19v
                      34&5 -0v
                      6 -2.56 v
                      7- 0v
                      8&9 -3.15v
                      10 -0v
                      11 -0.18v
                      12 & 13 -13v
                      14&15 -0v
                      16 -6v
                      17;18&19 -13v
                      20 - 19v
                      Voltages on battery connector are
                      1&2. -13v
                      3&4 -3.14 v
                      5&6 -0v
                      8&9 are ground...
                      03-20-2025, 05:13 AM
                    • Thomasraud
                      Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                      by Thomasraud
                      i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                      QUOTED
                      -It works on charger (without battery connected-only charger)
                      -It works on battery (without charger connected-only battery)
                      -& it also works when plugged in battery & charger, but it's not charging the battery
                      //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                      and..
                      QUOTE
                      The IC cannot maintain the input current level
                      06-28-2022, 06:47 PM
                    • kity92
                      Edifier x3 Earbuds Blue Light Problem (Charging Problem)
                      by kity92
                      I ordered a Bluetooth earbud one and half year ago, and right earbud broke. The light that should have been red when you put it in the charging case started to turn blue continuously(which means earbud is not charging) and after 1 week the earbud completely died. I disassembled right earbud because the warranty finished. I diagnosed the battery was dead, so I charged it with TP4056 and revived the battery.
                      Right earbud is working now but I still didn't solve charging problem. I checked the charging box with a multimeter. There is 5V. I checked the headphone pins and they are working....
                      01-13-2022, 01:49 PM
                    • badboyzzz
                      A2229 ipad pro 12.9 4gen strange problem Logic Board related charging but no usb data
                      by badboyzzz
                      I have a strange problem with my iPad Pro 12.9 4Gen / A2229. When I start the device, it stays on the Apple logo, but when I heat the back of the device with a hair dryer, the device boots, but this time there is an interesting problem. The iPad is charging, but there is no USB data on the computer. The USB charging port has been changed and the chips seem normal, but I have given it to 2 different Apple services in Latvia, but the repair could not be done. Is there anyone who can help with this? Can someone support the repair by sending only the motherboard within Europe? Thank you.
                      12-28-2024, 02:11 PM
