HP DV6-2064CA will only power up if its off for about 5 to 10 minutes
  • lmcancu
    • Oct 2009
    • 158
    Hi I have a HP DV6-2064CA laptop. My son had dropped it a few months ago, and the fan needed to be replaced. I replaced the fan and put in new thermal pastes, SSD drive, etc. He does alot of gaming on it, and reached CPU temperatures over 80. recently. It stated freezing on him, and the hard disk crashed. The problem is that it will boot up ok, but if you power it down and then try to boot it up again it will shut down automatically. So I took it apart, re-applied the thermal paste, checked for any obvious issues or burns. Put it back together without the SSD drive. It will boot up into BIOS fine, I can run tests and it can reach 80 degrees no problem. But if I power it down, and power it back it will automatically shut down and not even go into the BIOS screen. I tested it more, and it looks not even to be heat related. If I power it up for a few seconds, then power it down. Power it back up immediately, it will power down automatically. If I wait a few minutes and power it back up it runs fine until I power it down again. Where do I start looking? CPU? Motherboard? Power button? I tried this on both battery and power brick.
    Thanks for any help
  • lmcancu
    • Oct 2009
    • 158
    Re: HP DV6-2064CA will only power up if its off for about 5 to 10 minutes
    Just performed some burn-in tests booted from a parted magic CD and reached temperatures of 86 C. The system is still up with no issues. So its ok once it boots up. The problem is I guess a "warm" boot. Power button issue?
    This is the part? Could this cause the weird behavior? How would I troubleshoot this part?
    http://www.ebay.com/itm/HP-DV6-1000-...item3cc8695be1
    • dj_ricoh
      • 2073
      • uk
      nee!
      thats not the problem the problem is cold joint ~
      when he drop it down(i dont think its true; rage ) was hot and maybe something move inside.
      cook the board!
      • lmcancu
        • Oct 2009
        • 158
        Not sure its a cold joint. This happens even if I shutdown the laptop if its been on only for a few seconds. i.e. turn on the laptop, goes into BIOS, wait 3 seconds, shut down. If I now turn it on it powers down right away. If I remove the power, remove the power button piece, press it a few times, and them reconnect, and power up again it comes back up 8 times out of 10. I'm thinking the power button logic is in a funny state. I think the power button circuit has some very small caps in it, so maybe there is some memory that's not cleared properly.
        • dj_ricoh
          • 2073
          • uk
          power it up with a tweezer or a resistor direct on the connector!
          • lmcancu
            • Oct 2009
            • 158
            Does anyone have a schematic for a HP DV6-2064CA laptop with AMD chipset? It's a DV6-2000 series
            • ala_borbe
              aka Donald
              • 1625
              • Malta
              need full motherboard code
              Im Back... sort of...
              • lmcancu
                • Oct 2009
                • 158
                Thanks the motherboard code is DAUT1AMB6E0 Rev. E. I also found this link which suggests a solution for the same symptoms I have. Does anyone know where PQ41 is?
                http://www.elvikom.pl/hp-dv6-motherb...ff-t32036.html
                • lmcancu
                  • Oct 2009
                  • 158
                  I found Pq41 on the motherboard. It gets very hot at startup " can't leave finger on it for more than a couple of seconds. Does anyone know if this is normal. Anyway to test to see if the mosfet is ok?
                  • ala_borbe
                    aka Donald
                    • 1625
                    • Malta
                    it should be one of those UT1/2 - UT12
                    • reaper57
                      • Sep 2014
                      • 216
                      • Norway
                      You should be able to test the diode with a multimeter (see attachment). Unless you have a scope that's pretty much it. You could test it for a short, but that requires you to desolder it from the board, and if you desolder it you might as well just replace it.
                      FDS6690AS should be the part number. You should be able to get it cheap at a local store or online and it's probably the problem.
                      P.S. Can you post pics of the board and the PQ41 mosfet?
                      Keyboard not detected, press F1 to continue...
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3582
                        • slovakia
                        its 10A n-channel mosfet, part of stepdown convetrer for 1,2V rail. dont forget to chceck for short pq42
                        • lmcancu
                          • Oct 2009
                          • 158
                          Do I have to remove PQ42 to check for the short
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3582
                            • slovakia
                            just check for cross-short on it
                            • lmcancu
                              • Oct 2009
                              • 158
                              sorry I'm new to mosfets. I've changed a few capacitors. What is a cross-short? Would I use the continuity test, diode test, or resistance check on it? That's sends current through it. Would I damage anything? Do I do the test with the motherboard off?
                              • reaper57
                                • Sep 2014
                                • 216
                                • Norway
                                Continuity or resistance test should both get the job done, use which one you prefer. One probe on pin 4 one probe on 5. There should be no short. To test the diode positive probe on 1 and negative on 5. Then put the probe that was on 5 (negative) on 1 and the probe that was on 1 (positive) on 5. The fist should give you a short the second should give you no short.
                                Same should go for pq42
                                Board should be off.
                                No you are safe nothing will be damaged.
                                P.S. I'll let some one else tell you how to test the input and the output of the mosfet as I am very bad at reading schematics and I wasn't able to figure out the values you should get.
                                • lmcancu
                                  • Oct 2009
                                  • 158
                                  Thank you, I'll let you know what I find. Attached are some pictures. Let me know if you need closeups of any area? I found pq42 but was unable to find pq41?
                                  • lmcancu
                                    • Oct 2009
                                    • 158
                                    "Continuity or resistance test should both get the job done, use which one you prefer. One probe on pin 4 one probe on 5. There should be no short. "
                                    -- no short, meter reads open
                                    "To test the diode positive probe on 1 and negative on 5. Then put the probe that was on 5 (negative) on 1 and the probe that was on 1 (positive) on 5. The fist should give you a short the second should give you no short."
                                    Using continuity I get a short beep in each case and then the meter reads open. I measured the resistance for 1 and 5: --> 92 ohms, and 5 to 1 --> 142 ohms. Are these normal?
                                    • cyberhack
                                      • Feb 2013
                                      • 466
                                      • Uk
                                      Here this will help
                                      • lmcancu
                                        • Oct 2009
                                        • 158
                                        Thanks Cyber. I checked PQ59 and PQ54 which also use FDS6690AS. The diode test seems fine: ~ 167 ohms from 1 to 5, and open between 5 and 1. Can I safely assume that PQ41 is bad? i.e. the diode protection is shot? I still can't find PQ42? This is a caspian board and not Griffin maybe the schematic is a little different?
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • meraklinetx
                                          Asus Z97-a power cycle, no boot no cpu voltage
                                          by meraklinetx
                                          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                          05-10-2023, 06:08 AM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • dicky96
                                          Bang & Olufsen (HP) Omen Laptop power light flashes once but no boot
                                          by dicky96
                                          Hi guys
                                          I have a B&O Omen laptop here. It has very specific fault symptoms, hopefully someone can give me some guidance
                                          If I plug in a known good 180W third party charger the little LED next to the power jack on the laptop flashes red once, but the laptop will not start. It will not flash red again unless you unplug and reconnect the power.
                                          If I remove the main battery (I can't see a cmos battery) then the led by the jack does not flash when I plug in the adapter, but if I press the power on button with adapter attached it flashes once white every time...
                                          03-24-2023, 06:33 AM
