Sony PCG-61714m no power
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3636
    • slovakia
    Hello.
    Have this laptop with no power. power to gate of first mosfet is slowly rising and falling from 2 to 8 volts. And again charger ic is BQ24725.
    this time i dont have acok signal from him.
    laptop start only on battery. after inject 19v to base of first mosfet the system can start but only without battery. again bad charger ic?
    have acin, acdet and vcc voltages.
    anybody have schematic?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3636
    • slovakia
    Re: Sony PCG-61714m no power
    i order some of charget ics because 5times in a row have ddr3 laptop with this ic and same symproms.
    • Claudio Silva
      • Feb 2013
      • 94
      • Portugal
      You don´t need the first pq to activate because the internal diode is in reverse mode, there´s no barrier.
      Hope that helps
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3636
        • slovakia
        u have bad scheme. in my board the internal diode is in reverse
        • Claudio Silva
          • Feb 2013
          • 94
          • Portugal
          I know rsrsrsr it´s not the right schematic, it was only to demonstrate rsrsrsrrs.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • PopsCaps
            Sony Bravia KDL-40V2500 that will not power on
            by PopsCaps
            I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
            I do not hear any sound and I cannot see any backlight.
            I have tried disconnecting every cable on each board one at a time to see if anything changes.
            The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
            My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
            03-25-2025, 11:23 AM
          • Mita99
            Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
            by Mita99
            Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
            Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
            Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
            04-27-2025, 07:20 PM
