k40in not charging
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    k40in not charging
    Well received this board , sayng it was not charging they had changed few times system charger since they had some used ones .. until they damaged the Core line for bath making 19volts line fucked up , fix the 19 volts line , and i've got in back alive again .
    So i got for pin 1 and 2 12.95v . pin 3 and 4 GND , 5 and 6 - 3.30volts . pin 7 i got 0.17 volts online . all the outher are GND ..
    i've been trying to follow schematic but ... unfortunetly there is no ID on board to follow easy , shouldn't pin 7 higher ?
    i'm gonna add here the schematic , page 60 is for bat terminal ..
    any taughts will be welcome
    cheers
  • cyberhack
    • Feb 2013
    • 466
    • Uk
    Re: k40in not charging
    Post pictures pcb
    • highpulse
      i hate HP
      • May 2013
      • 1488
      • portugal
      ops forgot the schematic . tomorrow once i arrive to work i will add the schematic and pictures of both sizes of the PCB .
      thk in advance guys
      • highpulse
        i hate HP
        • May 2013
        • 1488
        • portugal
        well like promised here it is the pictures and schematic ,
        • cyberhack
          • Feb 2013
          • 466
          • Uk
          Where are checking the voltages page?
          • highpulse
            i hate HP
            • May 2013
            • 1488
            • portugal
            cheking pages 60 for pinout on battery
            page 85 to chek main bat charge .
            and the values i gave you are mentioned on the first post
            • highpulse
              i hate HP
              • May 2013
              • 1488
              • portugal
              there are a few zinner and a main bridge but all values are ok on pin 5 6 and 7 without battery , when battery is inserted pin 7 drop to a very low value . this voltage come from KBC
              • highpulse
                i hate HP
                • May 2013
                • 1488
                • portugal
                fixed , there was a problem, on small component on the main voltage rail
                • shijeesh
                  • Mar 2011
                  • 65
                  Sir which component fail.
                  • highpulse
                    i hate HP
                    • May 2013
                    • 1488
                    • portugal
                    one of the 2 fets on the main charger system , they are 2 near a tantalum capacitor and near the coil . you can see on the pictures i've posted
                    • highpulse
                      i hate HP
                      • May 2013
                      • 1488
                      • portugal
                      and also , system charger was replaced by another and system charger ic also replaced since was getting a bit hot.
                      • cyberhack
                        • Feb 2013
                        • 466
                        • Uk
                        PIN 5/7 = BUS LINE
                        Pin 7
                        BAT1_IN_OC#=Low  Battery absence
                        BAT1_IN_OC#=High Battery IN
                        It is possible that D6005 faulty but not had one yet
                        • highpulse
                          i hate HP
                          • May 2013
                          • 1488
                          • portugal
                          i tough could be that bridge , but was ok after testing it . in the end there was a leak on the mosfet for charger line , and also system charger was getting more hot that usual , a possible fault caused to the outher store , replaced and have done something with the board since it was in total short when came to my store . but working and charging now thk anyway guys
                          • highpulse
                            i hate HP
                            • May 2013
                            • 1488
                            • portugal
                            cyberhack and it was diferente , BAT_IN_OC , was total oposite , high value without bat and low value with bat
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1488
                              • portugal
                              but also would be not easy fiding does components since this board have no ID at all , ad not seenabl were the trace goes frmo the bus lines to see where were the Diode and bridge section
                              • flat-earther
                                ASUS X54H laptop thinks it's always charging even with charger unplugged
                                by flat-earther
                                The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                Windows also shows ''Plugged in'' when charger is not connected.
                                This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                If I let battery run out and say it has 3% Windows will...
                                06-24-2025, 09:32 AM
                              • Thomasraud
                                Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                                by Thomasraud
                                i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                                QUOTED
                                -It works on charger (without battery connected-only charger)
                                -It works on battery (without charger connected-only battery)
                                -& it also works when plugged in battery & charger, but it's not charging the battery
                                //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                                and..
                                QUOTE
                                The IC cannot maintain the input current level
                                06-28-2022, 06:47 PM
                              • Scoff
                                HP Probook 470 G4 - Power and Charging Problem
                                by Scoff
                                Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                                Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                                07-03-2023, 09:28 AM
                              • SluggerB
                                Help with trying to fix phone that is not charging (Pics inside)
                                by SluggerB
                                I have two TCL A30 phones.
                                Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                                New Phone: Works fine, bought as a donor board to try and repair Old Phone
                                My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                                08-12-2024, 08:11 AM
                              • Julian Bailey
                                HP ProBook 445 G8 Battery not charging
                                by Julian Bailey
                                Hi all
                                We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                                The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                                I have gone around the board with a MM and cant find anything
                                Windows shows the battery fine,...
                                10-11-2024, 10:34 AM
