I posted yesterday about this then the problem changed and I had to delete it. Well Here is what is going on. hp 830 G7 board 6050A3142001-MB-A01 Basically no power and at first the caps key blinked 7 times so I'm thinking bios corrupt so I redid the bios on both chips and nothing so I had help and redid it a few times and still nothing. I do have a power light when the cord is plugged in and had a thought to check for 3.3v at the bios so I did and I had nothing. I spend quite some time trying to figure out why and coud not but here is where the wierd part comes after putting it aside for a bit then going back to it suddenly no power light when plugged in and I tried a couple different power cords BUT now for some reason I do have 3.3v at the bios chip but still dead and no power light plugged in. I have no idea what changed. I really do not know what to look at next if anybody has a suggestion. TIA
Wierd problems with Hp 830 g7
Confirm the following RTC battery pack is present and ok on the voltage. Have serviced at least 3 units with a similar fault and the root cause was the RTC battery for the board not powering on.
https://www.ebay.com/itm/317217387980
by ShinjuHey All!
Long time forum member here with a problematic laptop issue!
I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
The laptop would not power on with the new battery installed without the power supply being plugged in.
When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows... -
on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
i don't understand the reasons of the white stripe at the bottom of the screen below the task... -
by HondamanRecently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
(I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...-
by zwectI have this Asus ROG laptop (the 1060 + 6700HQ variant) which lights up the power button's LED when i plug the charger in but does nothing else. Opening up there are no signs of any burnt or corroded components, i've checked the resistance of both CPU and GPU's cores on the caps underside them, the CPU's VCCCORE's caps read 1.2ohm and the GPU's NVVDD read about 0.5 to 0.6ohm. I then tried to check any voltages while the laptop is plugged in (without any of the removable parts) and the GPU's core voltage instantly goes to 0.8v when plugged then getting slowly warm, the PCH does so too (not so warm...
by catgirllauraHi everyone, I have an issue with an ASUS Laptop model K553E. It will power on when no charger is plugged in, but when the charger is pluged in and is in an off stte it wount turn on.
I tried another keyboard and it has the same problem ruled out the battery checked the voltages at the buck converters getting normal 5 v and 3.3V nothing is running hot. the machine runs perfectly. any ideas as to what might be causing this? - Loading...
