Hello, so I replaced a soc SRK08 (i3-1115G4) on a hp 14-dq because the 1.8v power supply was shorted and the pch was gone and I installed a SRK05 (i5-1135G7) that I had at hand. And I was wondering if a clean me region is needed after replacing the chip, I usually do this on laptops with separated pch, but with a soc (cpu and pch together) I have no idea. Normally I wouldn't ask this, but I have only the motherboard, no screen nor the adapter, and after I fix this I have to send it to another region so if someone knows about this, some help would be apreciated.
Note: After doing all mentioned above and having no shorts and all the measurments normal I tried to trick the adp_id (using a 100 ohm resistor between the id pin and 19v) and turn it on, but got nothing, no 5v, no 3v, the 3v ldo is 4.8v for some reason, so probably I need the adapter and wouldn't be able to test it properly (I don't know the exact value of the resistor either), so if someone has done this before and can share his experience it would be great.
Thanks.
Thanks.
