toshiba satellite c660d-13h no power problem
  • chriscute42
    • Oct 2009
    • 13
    hi
    i have toshiba c660d-13h laptop with PWWBE LA-6849P rev2 motherboard.
    no power problem.
    when i attach the charger, the green led wont turn on.
    please help!
    thanks.
  • Agent24
    I see dead caps
    • Oct 2007
    • 4959
    • New Zealand
    Re: toshiba satellite c660d-13h no power problem
    Potentially silly question, but I assume the charger is known to be good?
    -David VanHorn
    • chriscute42
      • Oct 2009
      • 13
      yes, the charger is working and have supply to motherboard!..
      • chriscute42
        • Oct 2009
        • 13
        Before this laptop got no power, it’s always hang so I try to reformat the operating system and have same problem. Then I try to clean ram and replace new, have same problem. Then I try to reheat the video ic, when I put it back the motherboard have no response. Plz, help.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4959
          • New Zealand
          I can't see a schematic for this board anywhere easily, do you have one? How much experience do you have in repairing laptop boards?
          Also, can you post photos of the board?
          -David VanHorn
          • chriscute42
            • Oct 2009
            • 13
            Here is the sample picture of motherboard, sir.
            • chriscute42
              • Oct 2009
              • 13
              I have a little bit experience in repairing laptop board.
              plz help, sir.
              • xxxvirus1987xxx
                unlegendary
                • Sep 2014
                • 24
                • philippines
                i think the mother board has no problem before
                it always hang because maybe yuor hardisc have a bad sector you can fixed it using hdd regenerator..
                since their no response any more
                firts step reset cables...reset bios or try to hang the cmos battery atleast 10 seconds then power on again..
                maybe the motherboard also han loose solder since you reheat gpu.
                • chriscute42
                  • Oct 2009
                  • 13
                  No problem on hdd, sir. Because I already replace hdd before I reheat the video ic. When I install the driver of video and restart the system its hang on the logo of windows 7, so I decide to reheat the ic.
                  • chriscute42
                    • Oct 2009
                    • 13
                    I try to test the diode and fuse of the motherboard its works ok and there is a supply came from the charger going to the pin of motherboard.
                    • xxxvirus1987xxx
                      unlegendary
                      • Sep 2014
                      • 24
                      • philippines
                      i think we need scheamtic for this to trace the line correctly wher is goes....
                      if the voltages are correct waiting for others to help....tanx
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3599
                        • slovakia
                        chceck pins of mosfets right behind the ffuse or on the other side of board right to the fuse
                        • chriscute42
                          • Oct 2009
                          • 13
                          sir ktmmotocross, Can you help me how to test if the mosfet is working or not? I don’t know how to test it using a tester.
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3599
                            • slovakia
                            just chceck voltage on its pins
                            • xxxvirus1987xxx
                              unlegendary
                              • Sep 2014
                              • 24
                              • philippines
                              if the mosfet has three legs it is very easy...
                              find firts the pin
                              gate
                              source
                              drain
                              Connect the 'Source' of the MosFet to the meter's negative (-) lead.
                              1) Hold the MosFet by the case or the tab but don't touch the metal parts of the test probes with any of the other MosFet's terminals until needed.
                              2) First, touch the meter positive lead onto the MosFet's 'Gate'.
                              3) Now move the positive probe to the 'Drain'. You should get a 'low' reading. The MosFet's internal capacitance on the gate has now been charged up by the meter and the device is 'turned-on'.
                              4) With the meter positive still connected to the drain, touch a finger between source and gate (and drain if you like, it does not matter at this stage). The gate will be discharged through your finger and the meter reading should go high, indicating a non-conductive device.
                              Such a simple test is not 100% -- but is useful and usually adequate.
                              When MOSFETS fail they often go short-circuit drain-to-gate. This can put the drain voltage back onto the gate where of course it feeds (via the gate resistors) into the drive circuitry, possibly blowing that section. It will also get to any other paralleled MosFet gates, blowing them also.
                              So, if the MosFets are deceased, check the drivers as well! This fact is probably the best reason for adding a source-gate zener diode; zeners fail short circuit and a properly connected zener can limit the damage in a failure! You can also add subminiature gate resistors -- which tend to fail open-circuit (like a fuse) under this overload, disconnecting the dud MosFet's gate.
                              • smali
                                • Sep 2014
                                • 287
                                • Pakistan
                                Check voltage on PQ204
                                • polytek
                                  • Dec 2013
                                  • 496
                                  • TUNISIA
                                  hi,
                                  it hppend to me with two laptop, and there is no power problem , just check the resistantce of the graphic chip that you have reflowed if you find 000 OHM you have to try to heat the chip carefully to take out the short, but if there is no short, just clean the flux under the chip and it will work,
                                  good luck, hope i will help you to repair this borad;
                                  • xxxvirus1987xxx
                                    unlegendary
                                    • Sep 2014
                                    • 24
                                    • philippines
                                    i agrre to mabroukmedal you need to reheat again the video chips maybe their is a lose connection or short you must inusure it @ 100% good contact before you start trouble shooting....the mobo.
                                    • chriscute42
                                      • Oct 2009
                                      • 13
                                      thanks, i try it.
                                      • hansie55
                                        • Dec 2013
                                        • 254
                                        • Netherlands
                                        This is what I could find in archive
                                        • ju123
                                          Toshiba Satellite C50-A won't power down
                                          by ju123
                                          Hi guys,
                                          So, I've been racking my brains on this one.
                                          I have a Satellite C50-A which I'm repairing for a friend.
                                          I recently replaced the main board due to failure.
                                          Following this, absolutely everything works perfectly, except for the fact it won't power down.
                                          Initially, shutting down via Windows would shut the OS down, screen would turn off (noticed the lighter black go to what looks like the darker black powered off screen as though the backlights have powered off), however the laptop was still running internally with a spinning...
                                          01-07-2022, 04:40 PM
                                        • mazenkataya
                                          Toshiba satellite L55-B5294 POWER PROBLEM
                                          by mazenkataya
                                          this laptop has working power rails all voltages across coils observed but no display also after try many bios files still the same ,power on with power button light led on and no display cpu get little hot and consumption on power supply is 213 mili ampere any sugestion please
                                          01-15-2022, 07:09 AM
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • Duranitron
                                          Asus x512dk rev 2.1 power on problem
                                          by Duranitron
                                          When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                                          Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                                          11-26-2024, 10:22 PM
                                          Toshiba Satellite Pro A50-EC-16E Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A50-EC-16E Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A50-EC-16E boardview and A50-EC-16E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 04:40 PM
