hp g62 restart
  • borbooroski
    • Mar 2014
    • 177
    • Ghana
    hp g62 restart
    i greet you all folks please i have this hp g62 which on but cant display and restart please can someone help me fixed it.
    Thank you
  • dellxps15
    • Feb 2014
    • 1596
    • italy
    Re: hp g62 restart
    how many blinking caps lock u have?
    • dj_ricoh
      • 2073
      • uk
      Re: hp g62 restart
      no!
      think G62.
      power up the notebook and cover the ventilation output and input air and let
      it run for 15-20 min then power off and on again;fast
      • shouri
        Dell latitude e5490 auto restart
        by shouri
        Hi guys, can someone help me?
        I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
        Board model is dm70 la-f401p rev:1.0 2017-09-20.
        At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
        After a few days test, is seems ok.
        Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
        12-10-2024, 09:27 PM
      • howardc64
        Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
        by howardc64
        TV was fixed just after removing Samsung's rear snap cover.
        This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
        Maybe PSU->backlight connector didn't have a good contact?...
        07-23-2025, 12:34 AM
      • alex26
        Samsung Qled QE58Q60 restart
        by alex26
        Hello. I have a Samsung qled model QE58Q60TAU.
        The TV restarts continuously and without an image. If I disconnect either half, the TV does not restart, but in both situations I have absolutely nothing on the display, only the backlight is on. I checked the CKv signals and the rest VGH, VSS etc. I measured them against the ground and between them and found between VGH and VSS a resistance of 106 ohms on the B side of the screen (right). I isolated all the signals on the right side and covered them with scotch tape and absolutely nothing has changed, it doesn't restart but I have no picture...
        12-29-2024, 03:12 AM
      • canhnguyen777mc
        THINKPAD T460S auto restart after shutting down???
        by canhnguyen777mc
        I'm having problems with my Lenovo thinkpad T460s laptop.
        It will automatically restart when shutdown.(uses battery)/
        Using the adapter + battery is ok. But when the adapter disconnected it will automatically restart.
        I tried reinstalling the operating system and testing in the PE environment but nothing changed.
        I think the problem is in BIOS SETUP.
        Can someone help me?​
        11-02-2024, 09:01 PM
      • Sokha Vitou
        Surface Laptop 3 Model 1873 AMD randomly restart
        by Sokha Vitou
        hello everyone. please help i have a surface laptop 3 AMD model 1873 that randomly restart. i don't think it has bad CPU, because when tried to stress test by CPU-z it not restart or has anything wrong, it just randomly restart when normal use ( browser, or watch video....). i tried to replace U6701 and U6702 but don't see any thing change.
        I'm tried to fine any glue on internet but no luck. I'm looking for any advice from you guy please....
        07-03-2023, 08:43 AM
