Samsung Qled QE58Q60 restart
  • alex26
    • Sep 2012
    • 37
    • ROMANIA
    Hello. I have a Samsung qled model QE58Q60TAU.
    The TV restarts continuously and without an image. If I disconnect either half, the TV does not restart, but in both situations I have absolutely nothing on the display, only the backlight is on. I checked the CKv signals and the rest VGH, VSS etc. I measured them against the ground and between them and found between VGH and VSS a resistance of 106 ohms on the B side of the screen (right). I isolated all the signals on the right side and covered them with scotch tape and absolutely nothing has changed, it doesn't restart but I have no picture at all. I also isolated the signals on the other side of the screen but nothing changed. The thing is that I don't have VGH and VSS at all, even if I have those routes covered, basically the screen blocks the voltages on the tcon. I checked if I have any shorted capacitors and I don't. I checked the ESD protection diodes, and I even removed them and still to no avail. On side A I also have a smd 25q32 memory, I was thinking of seeing it too, although I wouldn't believe it. Seeing that I don't have VGH and VSS voltages, I borrowed an identical motherboard but in vain, it's not from here, it's from the display. I don't know what else to do?​ Thanks.
  • Diah
    • Feb 2013
    • 6565
    you have panel fault.. No picture because the T-CON on MB go to protection mode . to enable t-con again search on MB close the 2 LVDS socket 2 points FB_TRDY1 and FB_TRDY3 jumber them together then check which side make picture fault.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4539
      • Italy - Milan
      Have you removed all the tvs diodes on the panel, both sides? Try it..
      • Diah
        • Feb 2013
        • 6565
        wow.. even no words of test them if they are defect or leaked ... my GOD .... ... your hobby really killer.
        by the way did you received yours Samsung main boards which you promised other thread to do what you think on it...... or it was just joke / lie as usual from you
        2025 just 48 hours from now
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4539
          • Italy - Milan
          i tell things only to correct users and when i wish..
            Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook Specification for Upgrade or Repair
            This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
            09-07-2024, 12:10 AM
            09-07-2024, 05:50 AM
          • Kaar3l
            Samsung QLED QE65Q7FNAT only standby light
            by Kaar3l
            TV: Samsung QLED QE65Q7FNAT
            PSU: BN4400940A
            MB: BN94-12832K
            I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
            09-24-2024, 01:35 PM
          • Batata
            Samsung QLED GQ50Q67TGU turns on and off
            by Batata
            Hello everybody,
            my TV has a problem. It keeps turning on and off. The speakers are still working, and I hooked up the TV to my PC, and it recognizes it as a Samsung device. I am able to get a stable backlight when I disconnect the cable(I believe it is called the LVDS cable) that connects the left lower board (which is connected to the "main board") and the right lower board. I have tried a taping method I saw on YouTube, where the CLK cables are taped off. In fact, I proceeded to figure out which pin I have to tape off in order to get a stable backlight. It doesn't matter...
            10-14-2024, 03:45 AM
            Samsung 7 NP730XBE Notebook Specification for Upgrade or Repair
            This specification for the Samsung 7 NP730XBE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP730XBE boardview and NP730XBE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Samsung 7...
            09-06-2024, 11:29 AM
