DA0U92MB6D0 REV:D NO POWER
  • NConstantinou
    • May 2017
    • 356
    • Cyprus
    Dear all,
    i have the above board and on PQ21(M3016D) i have input but no output. Therefore i have no input on PR7.
    i do not have similar transistor to substitute. how can i overcome this!
  • mon2
    • Dec 2019
    • 14995
    Remove all power. Meter in resistance mode. Measure the resistance to ground on pin #3 = PR7 = main power rail. What is the exact resistance? If it is too low, there is a fault on the main power rail.
    Connect the power adapter. Measure the voltage to ground on the gate pin # 1 on PQ21. Checking the gate voltage for this mosfet which should be higher than the voltage being passed between source / drain pins to fully enable. Gate pin should be ~25v to enable.
    If not, confirm the voltage to ground of REGN pin # 16 which should be ~6v.
    • NConstantinou
      • May 2017
      • 356
      • Cyprus
      The resistance of PR7 to ground is 45 OHMS. Pin 1 of PQ21 has 19v. the gate of PQ21 has 0v.
      i do not get any voltage on REGN pin # 16. i replace the ic with BQ25A from another USED board board but i do not know if it is good.
      is anything i can do to test the ic!
      By checking the coils i found that the 3.3v coil has also 45 Ohms resistance
      • mon2
        • Dec 2019
        • 14995
        Yes, something is wrong with the main power rail.
        With no power to the board, measure the resistance from PR7 to the 3v3 coil where you measured 45R ohms to ground. What is the resistance?
        • NConstantinou
          • May 2017
          • 356
          • Cyprus
          The resistance I measured was on PR7 45 ohms
          Before I have changed pq34 which was short and then I focus on ic charger as my first step.
          at this moment I went back to check pa34 again and I found it short again.
          I changed it and now the resistance on PR7 is .5 which is normal, but 0v on PR7 which means problem with charger ic.
          • mon2
            • Dec 2019
            • 14995
            What is the resistance to ground of PR7?
            • NConstantinou
              • May 2017
              • 356
              • Cyprus
              Thr resistance on PR7 now is 43K
              • NConstantinou
                • May 2017
                • 356
                • Cyprus
                Doing more testing i found on PU 2 ic pin #4 is connected with 2 100k resistors. Those where having wrong value and i change them.
                After that i got PR7 19V but not 3.3 and 5v.
                time for that step now
                • NConstantinou
                  • May 2017
                  • 356
                  • Cyprus
                  PU12. I do have +VIN 19v, pin #3 ref 2v, pin 17 VREG5 1.5v, pin 8 VREG3 0.09v, pin 13 EN0 2.5v.
                  what is the order of power sequence of G5608Dr51U 9PU12) ic!
                  IF +5VPCU WHICH IS MISSING FROM IC COMES FROM PQ7!
                  ON PQ7 PIN 1 AND 3 I GET 1.5V AND ON PIN 2 12V
                  • NConstantinou
                    • May 2017
                    • 356
                    • Cyprus
                    I managed to get 19v rail working.
                    No 3/5v rail.
                    PL5 coil which is battery coil i get only 1.1v without battery connected.
                    i cheched PQ15 which is the high side on Drain i have 19v but on G i have 1.2v. it should be higher.
                    measuring the resistance of mosfet i found the following
                    S-D 57k
                    S-G 90K
                    D-G 0.27M
                    i substituted BQ28 with BQ25
                    please someone advice
                    • mon2
                      • Dec 2019
                      • 14995
                      Replace this mosfet. The resistance values are too low.
                      • NConstantinou
                        • May 2017
                        • 356
                        • Cyprus
                        what the values suppost to be
                        • mon2
                          • Dec 2019
                          • 14995
                          On a good mosfet, hundreds of k ohms or higher.
                          • NConstantinou
                            • May 2017
                            • 356
                            • Cyprus
                            ok thanks.
                            changing the mosfet i got 2.85v on PL5. is that normal!
                            • NConstantinou
                              • May 2017
                              • 356
                              • Cyprus
                              changing PU12 3/5v ic i have the following voltages
                              Pin 16 Vin 19v
                              Pin 8 Vreg 1.23v
                              Pin 17 Vreg 5 5v
                              Pin 3Vref 2v
                              Pin 13 En0 15.28v
                              Pin17 5v
                              Pin4 5v
                              Pin 9 5v
                              Pin 12 5v
                              Vreg3 and Ugate1,2 0v
                              pls advice
                              • mon2
                                • Dec 2019
                                • 14995
                                Remove all power, measure the resistance to ground of Vreg3. What is the resistance in ohms? There could be a shorted part on this rail.
                                • NConstantinou
                                  • May 2017
                                  • 356
                                  • Cyprus
                                  The resistance to ground of Vreg3 is 35HOMS.
                                  if it is slow do you apply voltage!
                                  • NConstantinou
                                    • May 2017
                                    • 356
                                    • Cyprus
                                    can i substitute ic G5608DR51U with TPS51125!
                                    thanks
                                    • cind12
                                      GTX 1080 TI Gigabyte Aorus low resistance on vmem
                                      by cind12
                                      Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                                      Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                                      The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                                      Resistance on 12V 4K ohms (Power present when on)
                                      Resistance on 12V PEX 4K ohms...
                                      12-08-2023, 09:09 AM
                                    • Nagy Daniel
                                      Lowest possible resistance on laptop motherboard rail - Guide Table request
                                      by Nagy Daniel
                                      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                      So, I generated a table with AI so I can...
                                      03-04-2025, 08:24 AM
                                    • Jane
                                      How do you test MOSFET in laptops ?
                                      by Jane
                                      I tried to use this method:
                                      Testing an N-channel MOSFET:
                                      Step 1: Discharge the Gate (turn off the MOSFET)
                                      Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                      Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                      Step 2: Charge the Gate (turn on the MOSFET)
                                      Now, place the red probe on the Gate (G) and the black probe on the
                                      09-27-2024, 03:31 AM
                                    • tofik
                                      MOSFET equivalent K8A60DA
                                      by tofik
                                      Hello guys,
                                      I have a shorted MOSFET K8A60DA with the following characteristics:
                                      Type Designator: TK8A60DA
                                      Marking Code: K8A60DA
                                      Type of Transistor: MOSFET
                                      Type of Control Channel: N -Channel
                                      Maximum Power Dissipation (Pd): 45 W
                                      Maximum Drain-Source Voltage |Vds|: 600 V
                                      Maximum Gate-Source Voltage |Vgs|: 30 V
                                      Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
                                      Maximum Drain Current |Id|: 7.5 A
                                      Maximum Junction Temperature (Tj): 150 °C
                                      Total Gate Charge (Qg): 20 nC
                                      Rise Time (tr): 25 nS
                                      Drain-Source
                                      07-19-2023, 05:18 AM
                                    • novice1
                                      Acer Aspire E5-574G - Not Powering On
                                      by novice1
                                      Laptop name Acer Aspire E5-574G. Processor = i7-6500u. GPU = NVIDIA GEFORCE 940M. Motherboard Model = DA0ZRWMB6G0
                                      This laptop was not powering on at all so I started investigating. The blue light would come on for a second, and then disappear. Fan would sometimes turn on for a second and then shut off immediately, and at other times would not turn on at all.
                                      To start with, about 3 months ago I had no clue about soldering, motherboard schematics, board view, and then I stumbled about this forum and other stuff online. I have never done any of those before. But to ask...
                                      11-03-2023, 05:53 PM
