DA0U92MB6D0 REV:D NO POWER
  • NConstantinou
    • May 2017
    • 342
    • Cyprus
    Dear all,
    i have the above board and on PQ21(M3016D) i have input but no output. Therefore i have no input on PR7.
    i do not have similar transistor to substitute. how can i overcome this!
  • mon2
    • 14424
    Remove all power. Meter in resistance mode. Measure the resistance to ground on pin #3 = PR7 = main power rail. What is the exact resistance? If it is too low, there is a fault on the main power rail.
    Connect the power adapter. Measure the voltage to ground on the gate pin # 1 on PQ21. Checking the gate voltage for this mosfet which should be higher than the voltage being passed between source / drain pins to fully enable. Gate pin should be ~25v to enable.
    If not, confirm the voltage to ground of REGN pin # 16 which should be ~6v.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
      03-31-2024, 02:12 PM
      09-06-2024, 05:59 AM
