DA0U92MB6D0 REV:D NO POWER
  • NConstantinou
    • May 2017
    • 344
    • Cyprus
    Dear all,
    i have the above board and on PQ21(M3016D) i have input but no output. Therefore i have no input on PR7.
    i do not have similar transistor to substitute. how can i overcome this!
  • mon2
    • Dec 2019
    • 14434
    Remove all power. Meter in resistance mode. Measure the resistance to ground on pin #3 = PR7 = main power rail. What is the exact resistance? If it is too low, there is a fault on the main power rail.
    Connect the power adapter. Measure the voltage to ground on the gate pin # 1 on PQ21. Checking the gate voltage for this mosfet which should be higher than the voltage being passed between source / drain pins to fully enable. Gate pin should be ~25v to enable.
    If not, confirm the voltage to ground of REGN pin # 16 which should be ~6v.
    • NConstantinou
      • May 2017
      • 344
      • Cyprus
      The resistance of PR7 to ground is 45 OHMS. Pin 1 of PQ21 has 19v. the gate of PQ21 has 0v.
      i do not get any voltage on REGN pin # 16. i replace the ic with BQ25A from another USED board board but i do not know if it is good.
      is anything i can do to test the ic!
      By checking the coils i found that the 3.3v coil has also 45 Ohms resistance
      • mon2
        • Dec 2019
        • 14434
        Yes, something is wrong with the main power rail.
        With no power to the board, measure the resistance from PR7 to the 3v3 coil where you measured 45R ohms to ground. What is the resistance?
        • NConstantinou
          • May 2017
          • 344
          • Cyprus
          The resistance I measured was on PR7 45 ohms
          Before I have changed pq34 which was short and then I focus on ic charger as my first step.
          at this moment I went back to check pa34 again and I found it short again.
          I changed it and now the resistance on PR7 is .5 which is normal, but 0v on PR7 which means problem with charger ic.
          • mon2
            • Dec 2019
            • 14434
            What is the resistance to ground of PR7?
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
              by sam_sam_sam
              03-31-2024, 02:12 PM
              09-06-2024, 05:59 AM
