Does anyone know if you can replace the battery connector on the 820-02918 logicboard from a 14 inch MacBook Pro M3 Pro?
Apple A2992 Battery connector
by mkdjHello everyone,
Mark and model: ASUS X571
Tests already made:
- I have removed... -
by ktmmotocrossHello. H
Have this apple A1990 and A1707 that goe slow after battery change. with old battery back it is normal. So battery is problem as it is aftermarket. what battery vendor except original can u recommend. so it work as it should... -
NVDC charger configuration...-
Channel: Common Parts Library - Datasheets
11-05-2024, 03:28 PM -
by ferah831208Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
- Loading...
