Apple A1990 and A1707 after battery change low speed
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3622
    • slovakia
    Hello. H
    Have this apple A1990 and A1707 that goe slow after battery change. with old battery back it is normal. So battery is problem as it is aftermarket. what battery vendor except original can u recommend. so it work as it should
  • mon2
    • 14634
    Try your luck with another vendor from Amazon. Have had good luck with Mobile Sentrix - they now have an office in the UK / Europe.
    • ugamazing
      • Jun 2013
      • 171
      • usa
      A1990 and A1707 batteries not cross-compatible. Just mentioning that because you mentioned them both as if they might be.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • mkdj
        by mkdj
        Mark and model: ASUS X571
        Tests already made:
        - I have removed...
        07-14-2025, 09:16 AM
      • techfreak9356
        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
        by techfreak9356
        09-14-2023, 11:10 PM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
      • ferah831208
        by ferah831208
        03-18-2025, 01:18 AM
