da0r75mb6cd0 REV: C problem.
  • raileanu
    • Sep 2015
    • 127
    • United Kingdom
    #61
    Re: da0r75mb6cd0 REV: C problem.
    Give 3.3V to pin 5 of the eeprom not pin 3
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      #62
      here are both bios for that model
      virgin files, dmi needs to bi fixed, but it will tun on for sure
      Im Back... sort of...
      • motormayhem
        Lenovo T460 Only Charges on One Charger
        by motormayhem
        Laptop Question
        I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
        A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
        05-12-2023, 01:46 PM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
      • Johndill
        Dell Inspiron 7567 LA-D993P odd charger issue
        by Johndill
        Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
        There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
        I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
        Here are the tested scenarios:
        1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
        2. With the laptop off, plug in charger (LED says on) & the front charging...
        11-16-2022, 10:55 PM
        ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
        Highly Integrated Narrow VDC Battery Charger for Notebook Computers
        The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
        for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
        Narrow VDC applications where the system power source is
        either the battery pack or the regulated output of the charger.
        This makes the max voltage to the system equal to the max
        battery voltage instead of the max adapter voltage. Operating
        at lower system voltage can improve...
        11-05-2024, 04:43 PM
