Lenovo Thinkpad T410 no power
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    DEVICE: Laptop
    Model: lenovo thiinkpad t410
    Board Id: 09A33-3 48.4FZ09.031
    NZM1H-8
    ISSUE: NO POWER
    From the first mosfet 20v is not passing through, pin 4 has 19.5v and the first mosfet is a P-CHANNEL mosfet (SI7121DN) i think the pin 4 should be lower to active the 1st mosfet to allow the 20v to pass to second mosfet ive check all for shorting in the board , i did;nt find in rails, so ive check the schematic and im suspecting that, my Q61 is faulty due to its pin 1 is 0.47ohms? im not pretty sure, hope someone can help me figure out this issue.
    Q61 pin 1 is connected to DISCHARGE2
    Q107 - DTA114EEA -
    PIN1-19.62
    PIN2-19.58
    PIN3-19.24
    Q61-2SK3541
    PIN1-0V
    PIN2-0V
    PIN3-19.62
    Q51-DTC115EE
    PIN1-18.37
    PIN2-18.72
    PIN3-19.11
    Q78-2SK3541
    PIN1-0V
    PIN2-0V
    PIN3-18.72
    Q79-2SK3541
    PIN1-0V
    PIN2-0V
    PIN3-18.37
    Q107 PIN 2 IS CONNECTTED TO Q61 PIN 3
    my Q61 (2SK3541) pin 1 has 0.47ohms to gnd and its connected DISCHARGE2
    Q61-2SK3541
    PIN1-0V
    PIN2-0V
    PIN3-19.62
    and my Q107 - DTA114EEA -
    PIN1-19.62
    PIN2-19.58
    PIN3-19.24​
  • mon2
    • Dec 2019
    • 14677
    Post the schematics in the schematics forum and link it here.
    The gate pin of the Q61 mosfet should not be shorted to ground. Be sure you are in resistance mode and with no power to the board.
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      https://www.badcaps.net/forum/troubl...ematics-please
      here is the schematic and boardview ive used
      q61 without no power and cmos it measure 0.47ohms even ive swap my probes
      • mon2
        • Dec 2019
        • 14677
        Remove all power. Meter in resistance mode. Flux and remove Q61 off the board with care. Then measure the resistance of the gate pad again. Is it still low? BRB later.
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          remove the q61 done still having low resistance on Gate, tried to trace R229 and remove the DISCHARGE line is where the low resistance was coming from and tried to locate it to a R891 that is pulled by gnd?
          i think R891 is a pull-down resistor for the DISCHARGE line.?
          • mon2
            • Dec 2019
            • 14677
            We are reviewing DISCHARGE2 netname. See attached.
            Flux and remove Q44 and keep it separate from the othe removed part. After removal, is the resistance to ground on DISCHARGE2 line still a low resistance?
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              Q14 and Q44 and R228 is not present on board ONLY the R229 and C210
              • mon2
                • Dec 2019
                • 14677
                Post a pic of the meter face while measuring this short condition.
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  DISCHARGE2 -has 45.3 ohms but if I remove the R229 im having 45.3 ohms in DISCHARGE line. Click image for larger version
                  • mon2
                    • Dec 2019
                    • 14677
                    According to the schematics, R229 is marked with 'NO ASM' so it is not stuffed. Measure the resistance across this part you suspect to be R229.
                    • kalilinux25
                      • Mar 2018
                      • 2089
                      • ZAMBOANGA SIBUGAY
                      it measure 0hms if i measure resistance to gnd im having 0.45 ohms also
                      • kalilinux25
                        • Mar 2018
                        • 2089
                        • ZAMBOANGA SIBUGAY
                        i thi the boardview has some missing parts also like there is no GPU chip present on the board view and the schematic is for NZM1H-0 not NZM1H-8
                        • kalilinux25
                          • Mar 2018
                          • 2089
                          • ZAMBOANGA SIBUGAY
ID:	3682061Ill just upload it here
                          • mon2
                            • Dec 2019
                            • 14677
                            Is there a Q78 onboard? If yes, flux and remove it and measure again.
                            • kalilinux25
                              • Mar 2018
                              • 2089
                              • ZAMBOANGA SIBUGAY
                              Yes there is Q78 after removing it checking the resistance to ground to the DISCHARGE it still gives me 45.3 ohmsClick image for larger version
                              • kalilinux25
                                • Mar 2018
                                • 2089
                                • ZAMBOANGA SIBUGAY
                                Also I noticed ACDC_ID has 0v after testing the middle pin of the charger there is no voltage in the middle charger pin , i take apart the charger it only have 2 wires , showing its just a replacement charger , will this affect our cheking? also i noticed that VCC3M as low resisance to gnd around 1.1ohms to gnd, tried pumping voltage 1v 1amp didnt do anything no heating , possible its just normally low reistance.
                                • mon2
                                  • Dec 2019
                                  • 14677
                                  Not a good thing. This rail is also linked to the PCH / CPU. Is it possible that the heatsink is hiding who is heating up?
                                  • kalilinux25
                                    • Mar 2018
                                    • 2089
                                    • ZAMBOANGA SIBUGAY
                                    removing the CPU it didnt change the value , i pump 3v on the line it just consume 260ma. No short on VCC3M — the rail is likely healthy or in standby load condition.
                                    After pumping voltage the resistance to gnd changes to 18 ohms to gnd resistance
                                    • kalilinux25
                                      • Mar 2018
                                      • 2089
                                      • ZAMBOANGA SIBUGAY
                                      • Adapter source (Q9 Source)20 V present
                                      • Q9 Gate → ~19 V (only 1 V lower than source → MOSFET OFF)
                                      • Q9 Drain → 0 V (no pass-through)
                                      • Q9 body diode test → GOOD
                                        • RED on Drain → BLACK on Source = 0.510 V
                                        • Reverse = OL
                                      • Q9 Drain NOT shorted → ~341 kΩ to GND
                                      • After removing Q61 & lifting R229 → still 0 V at Q9 drain (confirmed there’s a second MOSFET in series).
                                      • mon2
                                        • Dec 2019
                                        • 14677
                                        Ok. Continue to confirm the DCin mosfets but use resistance mode checking.
                                        Test resistance across:
                                        source / drain
                                        source / gate
                                        gate / drain
                                        Post each measurement for each DCin mosfets.
                                        • Jane
                                          How do you test MOSFET in laptops ?
                                          by Jane
                                          I tried to use this method:
                                          Testing an N-channel MOSFET:
                                          Step 1: Discharge the Gate (turn off the MOSFET)
                                          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                          Step 2: Charge the Gate (turn on the MOSFET)
                                          Now, place the red probe on the Gate (G) and the black probe on the
                                          09-27-2024, 03:31 AM
                                        • Nooy
                                          VGA MOSfet permanently shorted and loss of MOSfet pad
                                          by Nooy
                                          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                          02-14-2024, 02:26 AM
                                        • redbaron1007
                                          Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                                          by redbaron1007
                                          I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                                          Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                                          09-09-2025, 11:10 AM
                                        • AppleLover123
                                          Asus X712EA 3 volts after the first mosfet
                                          by AppleLover123
                                          Hey guys,
                                          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                                          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                                          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                                          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                                          Now i thought something...
                                          12-15-2024, 07:49 AM
                                        • MicroSMD Lab
                                          ASUS ROG Zephyrus GPU Mosfet repeat failure
                                          by MicroSMD Lab
                                          The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                                          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                                          01-10-2024, 06:36 AM
