Lenovo Thinkpad T410 no power
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    1ST MOSFET Q9
    source / drain- 98.2K
    source / gate-141K
    gate / drain- 412K
    Q36
    source / drain - 1.3M
    source / gate- 947K
    gate / drain-954K
    remove U41 (tps51222) cool down the board for 5 mins . Check resistance to ground, red prove to gnd and lack probe to coil, L3- has 1.0k same , and L4- has 23.ohms.
    • mon2
      • 14659
      Replace the first dcin mosfet.
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        replaced with Si7121dn to TPCC8067-H MOSFET check gate to source -101k gate to drain 415k source to drain-185k still having 19v on gate but it pass the 19v now still unit doesn't have 5v as 3v I'll post the charger ic pin voltages
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          1 - CE -0V 2 - ACN -18.69 3 - ACP-18.69 4 - LPMOD# -0V 5 - ACDET -2.5 6 - ACSET - 0V 7 - LPREF -0V 8 - TRICKL -0V 9 - AGND - 0V 10 - VREF -3.3V 11 - VADC -0V 12 - VADJ - 0V 13 - EXTPWR# -0V 14 - VDAC -1V 15 - FSET -0V 16 - IADAPT -0V 17 - ISET -0V 18 - BAT - 0V 19 - CSN - 20 - CSP - 21 - CELLS - 22 - DPMDET# 23 - PGND 24 - LODRV 25 - REGN - 0V 26 - SW 27 - HIDRV -0V 28 - BTST PAD - (Power GND – must be connected to board ground)
          ✅ 4. Injected 3.3V into VCC3M rail
          Done using a lab power supply with current limit
          ✅ LPMOD# rose to 3.1V, indicating charger came out of sleep
          CONFIRMED: Charger logic was blocked due to missing 3.3V
          ✅ 5. Checked REGN (pin 25)
          Voltage: Still 0V ❌
          Resistance to GND: 164kΩ → ✅ No short, load is normal
          ✅ REGN capacitor and components appear OK
          ❌ REGN internal LDO not turning on
          EN pin (IS-PWRSHUTDOWN) = 0V → ❌ TPS51221 not generating VCC3M/VCC5M
          BQ24741 is not generating REGN, even when all enable conditions are met​​
          • mon2
            • 14659
            Si7121dn Was replaced with TPCC8067-H mosfet?
            These are not the same type of mosfets.
            Original is a P-channel type; replaced is N-channel type.
            Enter the same details for advice on Grok while I work on my beauty sleep. I think chatgpt is making an error on this alternate mosfet.
            Also confirm the pin voltage of pin 28 on the charger IC.
            https://www.mouser.com/ds/2/408/TPCC...zIZffPzM_h0Nkw
            • Jane
              How do you test MOSFET in laptops ?
              by Jane
              I tried to use this method:
              Testing an N-channel MOSFET:
              Step 1: Discharge the Gate (turn off the MOSFET)
              Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
              Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
              Step 2: Charge the Gate (turn on the MOSFET)
              Now, place the red probe on the Gate (G) and the black probe on the
              09-27-2024, 03:31 AM
            • Nooy
              VGA MOSfet permanently shorted and loss of MOSfet pad
              by Nooy
              Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
              I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
              02-14-2024, 02:26 AM
            • redbaron1007
              Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
              by redbaron1007
              I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
              Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
              09-09-2025, 11:10 AM
            • AppleLover123
              Asus X712EA 3 volts after the first mosfet
              by AppleLover123
              Hey guys,
              i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
              I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
              Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
              I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
              Now i thought something...
              12-15-2024, 07:49 AM
            • MicroSMD Lab
              by MicroSMD Lab
              I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
              01-10-2024, 06:36 AM
