ibm/lenovo t410 board nzm1i-8 schematics please
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    hello
    does anyone happen to have schematics for
    i have no backlight, only 3 volts instead of 19
    i found schematics for nzm1h-1 and its similar but not the same
    please help if you can
    Im Back... sort of...
  • anshad
    • Nov 2010
    • 249
    Re: ibm/lenovo t410 board nzm1i-8 schematics please
    Try this. I am not sure if its the correct one
      • 21934
      Boardview .
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        thank you so very much guys
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          thank you once more, it is fixed
          if was fuse F7 ...
          • OsVard
            • Mar 2020
            • México
            Thanks a lot to both guys that share the fills. In my country (Mexico) Is impossible download form lenovo homepage
            • Gualdêncio
              • Jun 2021
              • Angola
              Re: ibm/lenovo t410 placa nzm1i-8 esquemas por favor
              Thank you very much partner, I am really grateful.
              Last edited by SMDFlea; 06-08-2021, 03:12 AM. Reason: https://translate.google.com
              • hussaka
                • Jan 2015
                • 154
                • italy
                thank you
                • gabodcrz
                  • Jun 2024
                  • Argentina
                  Thank you
                  • mrautom8
                    Samsung TV UN75H6350AFXZC main board schematics?
                    by mrautom8
                    Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                    Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                    While relay is on, all voltage rails are present and steady (scoped) on main board.
                    I love a good logic puzzle but getting lost without any schematics.
                    No shorts on ANY capacitor main board.
                    Thermal camera shows 3.3V inductor getting warm instantly but...
                    10-19-2025, 06:32 PM
                  • fonteene21
                    Lenovo ThinkPad L13 Gen3 board view and schematics
                    by fonteene21
                    Please help me. The lock on the 15p connector that connects to the keyboard of my Lenovo ThinkPad L13 Gen3 model 21B4-001XJP is broken and I would like to replace it.I would like to know the manufacturer and part number so that I can order the part. I would like a board view and schematic. Thank you for your cooperation.
                    02-27-2025, 08:13 AM
                  • badger707
                    Lenovo M920x board EQ370 NM-551 repair/circuit schematics
                    by badger707
                    Schematics please -- Lenovo M920x board EQ370 NM-551 repair/circuit schematics (thats the one with 2 slots for M.2 NVME storage)
                    M920Q have 1 slot for M.2 NVME storage (2nd slot is not soldered, some SMD components missing)
                    M920X have 2 slots for M.2 NVME storage.
                    both models shares same board but with different set of SMD components
                    03-02-2023, 03:31 PM
                  • ravi_1617
                    Lenovo B540 ,Starting Problem
                    by ravi_1617
                    Hello !
                    Model Lenovo B540
                    Board Details 09244-1
                    LA14 DIS MB
                    48.4DMO4.01.1
                    This Board has starting problem , when CMOS batter is removed ,it starts (turn ON) by itself fine, than if is short power switch once board turns OFF Fine.
                    when connected CMOS dont start.
                    3.3 volts present at power switch (it slight less 3.267-87) .there was slight liquid spill at around U53 (SL62872HR),when I clean that area . I mean when its little hot board warm , board starts few time ON and OFF by power switch
                    One more thing i want to mention ( by mistake i started at...
                    10-14-2025, 02:08 AM
                  • Rezendes
                    Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                    by Rezendes
                    Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                    I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                    The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                    05-10-2024, 02:18 PM
