[Macbook pro A1708] [Boot loop] [Trackpad ?]
  • No Lan
    • Apr 2025
    • 15
    • FRANCE
    Hey everyone,
    Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
    Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
    Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only with this motherboard (820-00840).
    Another weird thing I noticed: when the trackpad is plugged in, the fan doesn't spin. But when it's unplugged, the fan runs just fine.
    I checked with L4800 and C4800, no shorts. Also got 5V on PP5V_S4_TPAD_CONN.
    Honestly, I'm a bit stuck on what to do next to find the root cause.
    Oh, and important to mention: I did something I probably shouldn't have, but I wanted to test it out — I waited for the Mac to boot without the trackpad, then plugged the trackpad in hot.
    It worked for about 20 seconds before it rebooted again.
    So yeah, that's the situation! Looking forward to your bright ideas! Thanks a ton
  • mon2
    • Dec 2019
    • 14212
    Review the voltage to ground of the I2C lines on the trackpad connector. These are SCL / SDA.
    • No Lan
      • Apr 2025
      • 15
      • FRANCE
      Thanks you for your reply
      I found these 2 lines on the boardview for J4801 TRACKPAD
      SMBUS_SMC_3_S0_SCL --> 3.3V
      SMBUS_SMC_3_S0_SDA --> 3.3V
      Do i need to make furher test on it ?
      Click image for larger version  Name:	image.png Views:	0 Size:	127.8 KB ID:	3644891
      • mon2
        • Dec 2019
        • 14212
        Also, pins 8 and 12.
        Post the voltage measurements to ground of each TPAD_*** signal.
        • No Lan
          • Apr 2025
          • 15
          • FRANCE
          Okey,
          just to be sure, i'm taking measurement without Keyboard and trackpad connect. Is that good ?
          KBD_I2C_SDA --> just after connect USB-C it slowly going from 0 to 1,50v-1,84v --> not stable
          KBD_I2C_SCL --> just after connect USB-C it slowly going from 0 to 1,50v-1,84v --> not stable
          TPAD_SPI_INT_L --> 3,29v
          TPAD_SPI_MOSI --> 0v
          TPAD_SPI_CS_CONN_L --> 3,33v
          TPAD_SPI_MISO --> 0v
          TPAD_SPI_IF_EN --> 3,33v
          TPAD_SPI_CLK --> 0v
          TPAD_VIBE_L --> 0v
          i also noticed something strange. On PP5V_S4 (L4800) i measured 8-9v and sometimes strictly 5v
          Sometimes the Mac boot with trackpad sometimes bootloop..
          • No Lan
            • Apr 2025
            • 15
            • FRANCE
            Just because I measure 9V on PP5V_S4 one times, should I be concerned that U7650 might be malfunctioning sometimes? Or is it not handling the voltage as expected?
            • mon2
              • Dec 2019
              • 14212
              What is the current draw for this logic board? Are you at a stable 20v? If not stable 20v, review the article on the internet for the 'CD3215 and 20v'.
              • No Lan
                • Apr 2025
                • 15
                • FRANCE
                I'm fully stable 20v and between 0,4 and 0,8A without batterie connected.
                • mon2
                  • Dec 2019
                  • 14212
                  Do you ever see the Apple logo or hear the boot chime in any of these attempts?
                  What is the voltage to ground of PPBUS_G3H? ALL_SYS_PWRGD?
                  • No Lan
                    • Apr 2025
                    • 15
                    • FRANCE
                    Just to clarify
                    if trackpad is disconnected --> Mac boot with fan --> Logo Apple --> Screen for user authentication --> Stable
                    If trackpad is connected --> Mac boot without fan (fan work only for few second) --> Logo Apple --> Boot loop OR Mac boot without fan (fan work only for few second) --> Logo Apple --> Screen for user authentication crash and restart
                    for your question
                    PPBUS_G3H--> 13,2v
                    ALL_SYS_PWRGD --> 3,23v
                    • mon2
                      • Dec 2019
                      • 14212
                      What is the motherboard that works with this same trackpad with the same cable? Is it the 820-00840?
                      • No Lan
                        • Apr 2025
                        • 15
                        • FRANCE
                        Yes it is the exact same motherboard 820-00840
                        • mon2
                          • Dec 2019
                          • 14212
                          With the trackpad disconnected, you should have a high fan spin since the (trackpad) thermal sensors are not being detected. Is this correct? You can review the other working board for the expected high fan spin condition.
                          • No Lan
                            • Apr 2025
                            • 15
                            • FRANCE
                            I agree with you.
                            with the 2 motherboard (the one for this post and the other working well) i have a high fan speed when trackpad disconnected !
                            • mon2
                              • Dec 2019
                              • 14212
                              Boot into SAFEMODE with the trackpad connected.
                              To start an A1708 MacBook Pro in safe mode, you need to restart the computer and press and hold the Shift key until the login window appears. Once logged in, you can verify safe mode by checking the System Information app.
                              Does this trackpad with the same cable function with this (non-working) logic board?
                              Review the mating connectors for possible dry solder or lifted pin on the SMD joints.
                              • No Lan
                                • Apr 2025
                                • 15
                                • FRANCE
                                I cannot connect as the system keep restarting before or during login windows :/
                                even when starting in safe mode
                                • mon2
                                  • Dec 2019
                                  • 14212
                                  Remove all power. Meter in resistance mode. Mate the trackpad to this board.
                                  Measure the resistance to ground of:
                                  PP5V_S0_FAN
                                  FAN_LT_PWM
                                  FAN_LT_TACH
                                  • No Lan
                                    • Apr 2025
                                    • 15
                                    • FRANCE
                                    Here the result
                                    PP5V_S0_FAN --> 1,8
                                    FAN_LT_PWM --> OL
                                    FAN_LT_TACH -->OL
                                    • mon2
                                      • Dec 2019
                                      • 14212
                                      What are the units of measurement?
                                      PP5V_S0_FAN --> 1,8
                                      1R8 ohms to ground?
                                      • No Lan
                                        • Apr 2025
                                        • 15
                                        • FRANCE
                                        Sorry i was in diode mode.
                                        Multimeter on 2000K ohms and i observe between 220 and 240 on PP5V_S0_FAN. took on C4870
                                        FAN_LT_PWM --> OL
                                        FAN_LT_TACH -->OL
                                        • cyber47
                                          Macbook Pro A1706 (820-00923) no boot if display or Trackpad connected
                                          by cyber47
                                          i have used the search function but i doesnt found my problem.
                                          I am reparing a MacBook Pro A1706 with the Boardnumber 820-00923-A.
                                          If i have the display and/or the trackpad installed the Macbook does not boot, i have 20V and 0.03 Amps at the charger (without the battery connected), i can post a video of the Amperemeter if this helps.
                                          The board has PPBUS_G3H and it seems it is in the S5 state (i have the voltage on the S5 rails but not on the S4 rails).
                                          If i connect the charger without die display and the trackpad installed...
                                          12-20-2022, 02:57 PM
                                        • NolesFan
                                          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                          by NolesFan
                                          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                          10-24-2024, 06:36 PM
                                        • dellxps15
                                          macbook air 2020 A2179 boot loop cpu hot
                                          by dellxps15
                                          hi all, got this macbook that looks perfectly clean. no visible liquid damage or burned component that boot loop. if i try to enter diagnostic , it reboot too after a while.
                                          owner want to recover data, so im asking if i try a dfu (dunno ifi can do it in that model) do i loose all data ?
                                          what can cause cpu to get very hot from the beginning ?
                                          generally i fixed some boot loop by reprogram bios, of do a ssd SOS task from recovery menu, but before i start doing things, it's better listen to someone that had this problem on that model
                                          09-06-2023, 01:49 AM
                                        • ACS-Repair
                                          MacBook Pro A2141 820-01700 Boot loop
                                          by ACS-Repair
                                          Hello All,
                                          I was handed a 2019 MacBook Pro A2141 that is boot looping. There is never a display or backlight but there is a chime about every 8-10 seconds.
                                          I plugged in a USB-C meter and it see that it is negotiating 20 volts but there is no current draw at all. Voltage is stable, no resets.
                                          It appears that the battery has a charge but possibly is not charging.
                                          The following voltages are present:
                                          PPBUS_G3H = 12.61V
                                          PP3V3_G3H = 3.33V
                                          PP3V3_GH3HRTC = 3.33
                                          I haven't worked n one of these before so I have limited experience with...
                                          02-04-2025, 07:48 PM
                                        • Takeatry
                                          Yet another Samsung QLED Boot Loop
                                          by Takeatry
                                          Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                          10-04-2024, 02:57 PM
