MacBook Pro A2141 820-01700 Boot loop
+ More Options
Posts
  • ACS-Repair
    • Feb 2021
    • 203
    Hello All,
    I was handed a 2019 MacBook Pro A2141 that is boot looping. There is never a display or backlight but there is a chime about every 8-10 seconds.
    I plugged in a USB-C meter and it see that it is negotiating 20 volts but there is no current draw at all. Voltage is stable, no resets.
    It appears that the battery has a charge but possibly is not charging.
    The following voltages are present:
    PPBUS_G3H = 12.61V
    PP3V3_G3H = 3.33V
    PP3V3_GH3HRTC = 3.33
    I haven't worked n one of these before so I have limited experience with it. I thought about doing a "revive" in DFU mode but I'm worried that there is more likely a board fault related to the lack of current draw.
    I'm curious as to whether anyone has experience with this model and has a recommendation.
  • mon2
    • 13981
    Check the voltage to ground of PP2V5_NAND_SSD0.
    reference:
    https://www.youtube.com/watch?v=7cNg_ifibCQ
    https://www.youtube.com/watch?v=7RRnqb_62u4
    • ACS-Repair
      • Feb 2021
      • 203
      Thanks mon2
      I have 2.51v on both PP2V5_NAND_SSD0 and PP2V5_NAND_SSD1. The board is very clean although I have not removed the board yet to check the other side. The customer did not mention any liquid spill
      and I am still trying to decide how far I want to go with this due to my lack of experience on this model.
      I checked those links but my issue is different.
      • ACS-Repair
        • Feb 2021
        • 203
        Just an update...
        I was able to put the computer into DFU mode but the "Revive" process kicked out after going only about 50% on step 4 of 4 without reporting any errors.
        I'm not sure whether my USB-C cables are good enough so I've order a quality data cable which will arrive tomorrow. I'll try again to see if this works any better.
        • ACS-Repair
          • Feb 2021
          • 203
          I received a proper Thunderbolt cable and was able to connect to the computer, but I wasn't able to "revive" the computer. I was able to put the computer in Target Disk Mode but I'm waiting on the customer to provide the proper password.
          I found that there is a definite backlight problem as well. There is 0v on the PPVOUT_S0_LCDBKLT. If I measure this to ground I get 42 ohms, which I believe means there is a short. I will disconnect the screen to make sure it is not a screen issue, but I see there are a number of faults like this with a shorted capacitor on that line.
          • ACS-Repair
            • Feb 2021
            • 203
            Just an update... the customer all of a sudden decided that they did not want to repair their computer or do a data recovery. I've given it back and that's the end of it. Thanks for your response mon2.
            • No Lan
              [Macbook pro A1708] [Boot loop] [Trackpad ?]
              by No Lan
              Hey everyone,
              Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
              Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
              Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
              05-24-2025, 03:09 PM
            • NolesFan
              Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
              by NolesFan
              Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
              10-24-2024, 06:36 PM
            • dellxps15
              macbook air 2020 A2179 boot loop cpu hot
              by dellxps15
              hi all, got this macbook that looks perfectly clean. no visible liquid damage or burned component that boot loop. if i try to enter diagnostic , it reboot too after a while.
              owner want to recover data, so im asking if i try a dfu (dunno ifi can do it in that model) do i loose all data ?
              what can cause cpu to get very hot from the beginning ?
              generally i fixed some boot loop by reprogram bios, of do a ssd SOS task from recovery menu, but before i start doing things, it's better listen to someone that had this problem on that model
              09-06-2023, 01:49 AM
            • sdogs
              Macbook Pro 16 A2141 stuck in network boot
              by sdogs
              Good evening guys ;-) In a moment of lucid madness I bought a macbook pro 16 A2141 on which they sat on it. Aside from the banana shape and obviously gone screen, the macbook turns on, sounds the initial gong.
              I disassembled the screen and connected it to an external display, using a usb-c adapter, but I can't reinstall the os.
              I tried SMC and PRAM reset but the result doesn't change, the recovery starts only from the network, I tried different USB pendrives with different operating systems but nothing, it sees the boot device for an instant and immediately goes looking for the network....
              02-25-2023, 11:27 AM
            • Takeatry
              Yet another Samsung QLED Boot Loop
              by Takeatry
              Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
              10-04-2024, 02:57 PM
