A1990 820-01326 stuck at 5v and 0.19A
This topic has been answered.
  • mon2
    • Dec 2019
    • 14673
    The 2 caps in parallel should be fine to use. When you parallel the caps, the capacitance adds up but an added benefit is that the ESR (equivalent series resistance) decreases to allow for higher currents to be supported by the cluster of caps. In your travels, when you order parts, consider to source more of the 22uf caps to service the machine but as noted, you will not miss out by using the 2 x 10uf caps in parallel.
    • ahoonid
      CapsLOCK
      • Jun 2023
      • 52
      Noted. Thanks again. So the 2 uF difference is not a problem at all?
      • m1ch43lzm
        • Mar 2019
        • 942
        • Peru
        For decoupling caps on a power supply rail, it usually doesn't matter, it's within 20% tolerance anyways (20uF vs 22uF)
        • ahoonid
          CapsLOCK
          • Jun 2023
          • 52
          Thanks man.
          • mon2
            • Dec 2019
            • 14673
            Correct. Tolerance and other factors impact the true capacitance.
            Review this great article originally from Maxim Semiconductor:
            https://www.analog.com/en/resources/...capacitor.html
            • Fisher8865
              MacBook Pro A1990 stuck at 5v .592 amps
              by Fisher8865
              Hi guys
              I have a MacBook Pro A1990 that takes 4.9 Volts and .592 to .615 amps on one port. The other port on the left side power cycles with about the same amount of volts an amps but quickly power cycles. The same thing happens on the other side but opposite. So on the left side the bottom port stays on and on the right side it's the top one. I think it is a CD3215 chip but I am not sure how to test it or where to get one. I have checked for voltage at ppbus_g3h and it has 12.6 V which is also on fuses f7000 and f7001 I checked pp1v2_s3 and it has 1.2 V then...
              05-30-2024, 07:36 PM
            • Stunt
              Hp Laptop Stuck on Hp protected by hp sure start screen
              by Stunt
              Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
              I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
              I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
              Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
              screen that's it and stuck there. I left it until the following day and i still...
              09-02-2025, 01:51 PM
            • mr.Data
              Macbook A1990 stuck on logo
              by mr.Data
              This Macbook Pro 2018 boots up and then gets stuck on the logo.
              All the normal methods of resetting this Macbook have been tried but do not work.
              I cannot get into recovery mode and there is no bar displaying, it's just the white logo on a black background.
              Any help would be greatly appriciated....
              04-18-2024, 11:51 PM
            • pcash0007
              Dead 2018 Macbook Pro A1990 820-01041-07 stuck at 5V 0A
              by pcash0007
              First time looking at a logic board this closely, learnt enough from videos and forums here to be dangerous
              I was doing a OS update when the screen went blank at some point. Does not seem to be in DFU mode (checked using apple configurator).
              PPDCIN_G3H is 5.16V​
              PPBUS_G3H is 0.045V
              Resistance between TP_PPBUS_G3H and ground is 23.8 Ohms (which seems low)
              F7000 and F7001 seems fine.
              From what I learnt seems like there might be short on the down side on PPBUS_G3H.
              Is injecting low voltage and see what...
              03-07-2024, 06:19 PM
            • oemelectronic
              820-01700 macbook a2141 stuck 5v. But PPbus 12.29volt without fuse
              by oemelectronic
              hi Friend
              MACBOOK A2141
              stuck 5.16v. 0.40amp con tester type c
              but have
              PPBUS_3GH :12.28 volt - 7.89volt aleatorio
              PP3V3_G3H:3.2 Volt
              PP5V_G3S : Missing
              disconnected fuse : PPBUS_3GH : 12.30volt
              where did you continue friends
              01-26-2023, 06:09 PM
