a2251 820-01949 usb c amp meter malfunction when battery is plugged
  • alfredposadas09
    • Aug 2020
    • 342
    • Philippines
    a2251 820-01949 usb c amp meter malfunction when battery is plugged, can someone help me to troubleshoot this? no short on sda and scl lines and 3.3 voltage on both lines
  • mon2
    • 14631
    Test with another known good battery. Perhaps this battery pack has the bms locked or is not compatible for this chassis.
    Is the battery pack the original OEM or a replacement?
    Review the level shifters that may be onboard between the smbus lines between the battery connector and the smbus master.
    • alfredposadas09
      • Aug 2020
      • 342
      • Philippines
      i try to replace the battery with battery replacement.. laptop now working fine .. after 3days laptop doesnt power again.. i am waiting for my customer to return it to me
      • chth96
        by chth96
        03-09-2024, 10:03 PM
      • MikoMiko
        MacBook Pro A2251 - 820-01949-A not charging
        by MikoMiko
        Hello everyone, I have a MacBook Pro 13” 2020 (Four ports) (Model A2251 with the 820-01949-A logicboard). It had some minor liquid damage but I carefully cleaned the logic board with alcohol and let it dry as needed. Now I encounter following situation: The MacBook does start but the Battery is not charging when a cable is plugged in any of the ports (I use the powerbrick and cable that came with the device). It had some charge left, so I could safe some data, but I was limited my the 13% and the speed of airdrop. The liquid-damage is almost only limited to the side of the logic board where...
        03-24-2025, 11:09 AM
      • Shinju
        Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
        by Shinju
        Hey All!
        Long time forum member here with a problematic laptop issue!
        I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
        The laptop would not power on with the new battery installed without the power supply being plugged in.
        When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
        TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
        10-20-2021, 04:58 PM
        12-31-2023, 06:04 AM
      • jorpec
        by jorpec
        Hi
        Thnaks
        01-23-2023, 10:37 AM
