Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
  • Acnologia
    • Dec 2016
    • 428
    • Poland
    Here is a pretty crazy one.
    Step 1.
    Laptop was brought to me as dead not working. Removed everything , cleared everything.
    Step 2.
    Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
    Step 3.
    Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
    Step 4.
    Lets ,dive into the board. I see the edp cable on the side of the FPC connector (40pin) is a little bit damaged in the last 3 lanes like, blown ... I'm ordering a brand new. Install it . Again no image internally but only externally.
    Step 5.
    FPC connector shows a little bit dodgy ... let's replace it also . Brand new one connected, and secured. 100% . Again , no image...
    Step 6.
    Let's check the fuse next to the FPC connector, what do i see? It's blown. Let's replace it with the same one (32V/3A 0402 SMD Fuse)... replaced ,and still no image but at the same time dead laptop . I'm like what the hell ? So i remove the SMD Fuse, and replace it with another one fuse. Again laptop dead.... i remove the fuse laptop turns on.... but no image again.
    Step 7.
    Go back and forth , when connecting the EDP Cable to the screen laptop remains dead. If you remove the cable laptop turns on , but again no image. If you remove the fuse BUT install the display cable (edp) laptop turns on without image.
    So something is going on ...with the "specific" place of the FUSE ,or anything..
    It's a little bit , confusing ?!I would say... if you plug edp cable (with fuse installed) laptop doesnt even turn on ,remains dead, you remove either SMD fuse OR the Edp Cable, laptop works and goes to diagnostic with external monitor.
    How the hell am i suppose to fix that ?
    Thanks!
  • m1ch43lzm
    • Mar 2019
    • 923
    • Peru
    Hi
    Schematics here on post #9:
    https://www.badcaps.net/forum/troubl...98#post1718498
    Measure for resistance to GND on both sides of the fuse, with and without the LCD cable plugged in, you should have a high value of several Kohm
    Check your soldering on the LCD connector
    From the schematics on page 40, only pins 1 and 2 are the backlight voltage +LEDVDD after the fuse FG1, pin 3 is not connected on the LCD connector on the board (should measure OL on resistance to GND without the cable plugged in)
    Please post close up pictures of the LCD connector area
    • Acnologia
      • Dec 2016
      • 428
      • Poland
      Originally posted by m1ch43lzm
      Hi
      4.92mΩ on one side , and similar to the other side, with it increasing per second. When it's not connected the edp cable.
      When it's connected , i get a beeping sound that it's connected to ground both sides.
      Attaching photos:
      • Acnologia
        • Dec 2016
        • 428
        • Poland
        When cable is connected all go beep to ground all pins of the FPC connector
        • Sephir0th
          • Oct 2020
          • 1289
          Is it so hard to believe that either the cable or (meanwhile) the panel is shorted to GND on this track?
          FairRepair on YouTube
          • Acnologia
            • Dec 2016
            • 428
            • Poland
            But both cable and screen got replaced.
            Plus as i wrote , they are both tested on the same model (another machine) which i had laying around.
            It's only being here ,the problem .
            • m1ch43lzm
              • Mar 2019
              • 923
              • Peru
              Could it be a very tiny solder bridge here?
              Add flux and touch the soldering iron to those pins, inspect carefully for solder bridges
              While the solder joints on the cap and fuse look questionable, right now they "work", you really need to use more flux when soldering
              From the schematics, pin 3 is not connected, pin 4 is GND, on the first picture, start counting the pins from right to left
              The only possibility i can think, is that pins 1.2.3 are connected on the LCD cable side, yet on the board side only pins 1,2 are connected and pin 3 is NC
              And you have shorted pins 3,4 on the board
              With a sharp probe on your multimeter, test continuity from pin 3 (counting from right to left) to GND, it should read OL
              Measure continuity of pin 1 to pin 3 on the cable to be sure
              So, while plugging in the cable, pin 3 (shorted to pin4 on the MB, gets connected to pins 1,2 (by the cable)
              • Acnologia
                • Dec 2016
                • 428
                • Poland
                explaining to this much detail i believe it can help me out a lot like instructions left to right, count etc.
                Thanks for taking the time, effort to write to me. I will try and report back what i see for sure.
                I have used a lot of flux AMTECH etc. just to be sure that i can touch it up , and be sure for the connection , under the microscope also it 'doesn't show as not connected. But for sure i will try it out , i will remove it totally and start the ground up slowly .
                • Acnologia
                  • Dec 2016
                  • 428
                  • Poland
                  Okay so without the cable 4 pin is short to ground ,but 3 pin is NOT shorted to groud.
                  When i plug in either another screen or the old cable again it shows 3 + 4 pin short to ground.
                  So maybe there is another error somewhere else?
                  • m1ch43lzm
                    • Mar 2019
                    • 923
                    • Peru
                    Maybe you got the wrong cable for your laptop? Unless you can check with another laptop of the same model/type/same board number
                    I checked the schematics of another board NM-C421 (E14/E15 gen1), while the FPC connector is the same 40 pins, the pinout is completely different, starting with the first 4 pins are connected to the backlight voltage, that could explain it
                    You mentioned the old cable was burnt at the end, I wouldn't use it
                    I suggest visually checking the ends of both original and replacement cables under a microscope
                    • Acnologia
                      • Dec 2016
                      • 428
                      • Poland
                      Yes, it's direct original replacement.
                      Yes, i already did that, until you wrote the message because i didn't know what to do .
                      It's Gen 2.This laptop.
                      Yes, the old one had a burn mark in the pin 1-2-3-4.
                      Yes,i tried the original also from the other laptop but again does the same, thing when the secondary laptop doesn't short.
                      My question to you ...
                      I have removed the screen and also checked the cable to the other laptop , and again turns on just fine.
                      Only to this laptop is the problem .
                      So i have pin pointed down the problem to the bridge...what i mean ? If i connect the cable then it becomes short to ground. If not, then it doesn't .. i mean if i dont' install the cable, even without the fuse it remains the same.
                      What could speak with 1-2-3-4 ,which controller that does that? Maybe the controller of the pins 1,2,3,4 is burned and problematic. So when you plug the cable, then it makes the chip to go short...
                      • m1ch43lzm
                        • Mar 2019
                        • 923
                        • Peru
                        There's 2 versions of the E15 gen2
                        According to Lenovo parts search
                        https://pcsupport.lenovo.com/us/en/p...isplay/buy-now
                        The models with Intel CPU (the one you have) (Type 20TD/20TE) uses display cable FRU: 5C10Z23917
                        The models with AMD CPU (type 20T8, 20T9) use a different display cable FRU: 5C10Z23842
                        They're not interchangeable, and that could explain it
                        I checked the schematics for NM-C771 (E15 gen2 AMD) and the pin out of the LCD connector is different, with pins 1-4 connected together
                        That's why I mentioned the "machine type" also needs to match, it's printed on the back cover
                        So I'm guessing you have an E15 gen2 AMD (the working laptop), and this one you are repairing E15 gen2 Intel and you're trying the screen/cable from the AMD laptop on the Intel one...
                        It's the first time I saw that a manufacturer uses different display cables but using the same chassis for the Intel/AMD versions, so you can't easily swap an Intel board with an AMD board or vice versa
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Post#12 should be seriously checked.Seems convincing answer for the problem being faced.
                          • m1ch43lzm
                            • Mar 2019
                            • 923
                            • Peru
                            I checked again the Lenovo parts website, and got this
                            Search for "edp" and I get 3 different cables for type 20TD (Intel)
                            CABLE FRU CABLE EDP CABLE RGB
                            Part No: 5C10Z23918
                            FRU CABLE EDP CABLE RGB TOUCH
                            Part No: 5C10Z23919
                            Mars1.0INTELFRUCABLEMars1.0IntelEDPCABLEIR
                            Part No: 5C10Z23917
                            The one with "touch" looks like it's for a laptop equipped with a touch screen, but the other 2 the difference is in "IR" or "RGB", whatever that means (and this one says Intel EDP cable)
                            But for the type 20T8 (AMD) i get this
                            FRU CABLE EDP RGB Cable
                            Part No: 5C10Z23842
                            CABLE FRU CABLE EDP IR Cable
                            Part No: 5C10Z23841
                            No touch screen option for the AMD version, again, different part numbers than the cables for the Intel version
                            Lenovo sure makes things confusing
                            • Acnologia
                              • Dec 2016
                              • 428
                              • Poland
                              Part No: 5C10Z23918
                              Part No: 5C10Z23919
                              Part No: 5C10Z23917
                              Part No: 5C10Z23842
                              Part No: 5C10Z23841
                              I am not sure. hahahah!
                              Both laptops are Intel ones. Both laptops are non-touch versions.
                              My cable the new that i have in front of me: Lenovo Thinkpad E15 Gen 2 LCD Video Cable DC02C00LD00
                              But i keep believing that something is wrong with the "pins all together" i mean the 4 pins that are getting their signals most probably from another controller chip ?
                              • Acnologia
                                • Dec 2016
                                • 428
                                • Poland
                                my laptop (The broken ) exact details are:
                                PF-3JCYGJ 20TD-00GNUK 2022/01
                                • m1ch43lzm
                                  • Mar 2019
                                  • 923
                                  • Peru
                                  Google search brings me this Ebay listing
                                  Screen Display Cable IR For Lenovo ThinkPad E15 Gen 2 5C10Z23841 DC02C00LD00
                                  According to part number, that cable is for the AMD version...
                                  You got the wrong cable, you need to get one suitable for type 20TD that would be:
                                  5C10Z23917
                                  Click image for larger version  Name:	IMG_20250512_092701.jpg Views:	0 Size:	87.4 KB ID:	3635535
                                  (Image taken from Lenovo parts site, cropped the relevant portion)
                                  It says "GE5B0 EDP CABLE IR INTEL DC02C00MF10"
                                  Perhaps the IR means for an IR camera? (As in, for face id/windows hello)
                                  The other cable 5C10Z23918 I guess is for a regular webcam
                                  The pins are connected together on the cable itself, so plugging in the cable without the screen attached to it would cause the short
                                  Could it be, that your customer (or someone else) replaced the LCD cable with the wrong type, causing the burn on the cable and a possible short on main rail, then brought the laptop to you for repair and the liquid damage on the usb-c port was a secondary fault?
                                  • Acnologia
                                    • Dec 2016
                                    • 428
                                    • Poland
                                    5C10Z23917
                                    Yes, you are right most probably it was changed, before it came to my hands and that's why it was burned those lines.
                                    I have just placed an order from eBay (China} so it will take 2-3 weeks to arrive , the correct part number as shown from lenovo (yours) .
                                    So i believe this time it will just be fixed.
                                    If not, i will just jump out of the window...
                                    • Acnologia
                                      • Dec 2016
                                      • 428
                                      • Poland
                                      5C10Z23917
                                      The camera of the laptop is not IR i believe this is the part number :
                                      sc20f27116
                                      fw6624-222 1aec
                                      • m1ch43lzm
                                        • Mar 2019
                                        • 923
                                        • Peru
                                        https://pcsupport.lenovo.com/id/en/p.../display/model
                                        According to the full model 20TD00GNUK i get only these options, you can enter the serial number at that web site to get the exact parts used
                                        Part No: 5C10Z23917
                                        Camera,HD-IR,Front,2MIC,ZIF,Azw
                                        Part No: 5C20W42992
                                        Substitutes: 5C20W42993 and 5C20W42994
                                        Click image for larger version  Name:	5C20W42993_A.jpg Views:	0 Size:	36.2 KB ID:	3635821
                                        And it says exactly what you posted SC20F27116 (for 5C20W42993), so it's an IR webcam, on the regular 720p cameras if i select only 20TD the number on the sticker is completely different
                                        You can click on the images on the lenovo parts site and check
                                        • Coguar
                                          HP ProOne 23.8 inch G9 ALL-in-One Desktop PC - Working when plugged to an external monitor, no image otherwise
                                          by Coguar
                                          In the device manager there is no built-in display located. The Intel UHD Graphics are displayed and only the external display is visible. The AiO turns on and works but is only showing a black screen on the monitor.
                                          I checked the voltage on the backlight connector and it reads ~20V. I tried reseating the LVDS and Backlight connector, yet the image still does not show.
                                          Does anyone have ideas whether or not this is a BIOS related issue? The only visible log in the BIOS logs is that the firmware was updated around a month ago.
                                          We already tried to fix it by resetting the...
                                          06-23-2025, 07:14 AM
                                        • Madoy104
                                          Macbook Pro A1989 - No image, working fine with external monitor
                                          by Madoy104
                                          I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
                                          08-15-2024, 10:01 AM
                                        • larrysito111
                                          dell alienware m17 r5 LA-L761P liquid damage no image on lcd 2red 7blue runs on external
                                          by larrysito111
                                          got here a liquid damaged alienware
                                          the laptop had damage in the area of the kb9542qf2 all sorted and now laptop working and turns on but i have no display
                                          so if i start and connect usb-c display it works otherwise it is giving me the 2red and 7blue
                                          so with the usb-c external monitor is getting to bios and OS
                                          otherwise not
                                          so if it is in the os and i connect another lcd via onboard hdmi it is working no problem 2 lcds (1 usb-c + 1 hdmi)
                                          but still not the internal monitor
                                          (tested 3V and 5V going to the...
                                          06-12-2025, 04:16 PM
                                        • f-bone
                                          dell la-b843p image only on external
                                          by f-bone
                                          Hi guys,
                                          this one seems to work except that there is no image on LCD, only on external via HDMI. I have flashed the bios with a cleanME one and measured voltages at GPU (0.9V) and LVDS connector (LCDVDD_LCD is 19V and DCBATOUT_LCD is 3.3V). I can see the LCD going black after power on but no image. I shed some light with a torch but there is no image or activity at EDP_TX0/1 using the oscilloscope. I also tried a different panel.
                                          any ideas are welcome.
                                          br,
                                          george
                                          12-19-2022, 06:59 AM
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
