Latitude 3301 not charge battery
  • dclass-pro
    • Dec 2022
    • 157
    • Italy
    here are the measurements on Q4301
    D=0.2V
    G=0.1V
    S=0.6V
    If I try to bypass it, I think it doesn't work because on the PS_ID pin I still have a low voltage and therefore it doesn't work.
    Can I try to inject 3V and see what happens?​
    • mon2
      • Dec 2019
      • 14418
      Remove all power. Measure the resistance of the 33R ohms series resistor. This is another common point of failure. Is this resistor @ 33 ohms? If not, it needs to be replaced.
      What is the voltage to ground on the same trace but after this resistor? We are wanting to confirm the pull-up voltage on this EC trace. It is the EC that is the bus master and attempts to communicate with the power adapter.
      • Sephir0th
        • Oct 2020
        • 1283
        Did anyone brought the charger in question so far?
        FairRepair on YouTube
        • dclass-pro
          • Dec 2022
          • 157
          • Italy
          R4305 is present and is 33ohm
          R4605 is not mounted on the board
          The voltage I have on both sides of R4305 is 0.5V​
          • dclass-pro
            • Dec 2022
            • 157
            • Italy
            I also tried with another charger and bench power supply
            • mon2
              • Dec 2019
              • 14418
              Other chargers must be from the Dell brand. Bench power supply is not suitable because the power supply will not offer the 1-wire ID device that is implanted inside of the Dell (only) power adapter.
              At this time, the communication line under review (PS_ID) must be at ~3v when there are no loads on the line. Confirm the dual diode (D4302) that is on the same line to the right side of your posted schematic. Confirm the voltage on each pin of this dual diode.
              • dclass-pro
                • Dec 2022
                • 157
                • Italy
                #27
                Hi guys, I found the problem, one of these 2 resistors instead of being 1.2ohm was about 1k.
                I replaced it and everything worked great again!
                I want to point out that the 3v on the DC in connector does not come from the connector but from the mainboard.
                Thanks to everyone for the help!!​
                • techfreak9356
                  Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                  by techfreak9356
                  I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                  09-14-2023, 11:10 PM
                • razenxd
                  How can I charge that battery pack?
                  by razenxd
                  it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                  At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                  Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                  Now, I have noticed a few things.
                  The "dead" battery, while connected to charger and NOT Charging will...
                  12-05-2024, 06:11 AM
                • ruletero
                  Acer a515-43 low battery charge voltage
                  by ruletero
                  Hi
                  Acer A515-43
                  LA-H801P
                  Fail: Does not charge battery, has low voltaje on connector.
                  Laptop didn't want to turn on, only charge led blinked.
                  I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                  I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                  Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                  10-24-2022, 02:31 PM
                • Klevjetack
                  Charge a L19D3PDA battery externally from the laptop
                  by Klevjetack
                  Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                  03-05-2024, 07:26 AM
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
