Apple MacBook Pro 16-Inch 2019 - A2141 - stuck at 5V
  • martyjelen
    • Mar 2023
    • 127
    • Czech republic
    #41
    Yes. 1.1V, stable.
    • mon2
      • Dec 2019
      • 14667
      From post #24.
      P5V_3V3G3H_EN -0V
      PP3V3_G3H_T -3,3V ; this voltage is enabled so the _EN signal must be a '1' (not 0v)
      P3V3MAIN_PGOOD - 0V ; this should be '1' if the output voltage rail is stable
      P5VG3S_EN - 0V
      PP5V_G3S - 3,3V ; this voltage is enabled so the _EN signal must be a '1' (not 0v)
      P5VG3S_PGOOD - 0V ; this should be '1' if the output voltage rail is stable
      Confirm that you are measuring the proper pins for the 0V signals. The _PGOOD signals are open drain pins so there must be an external pull-up resistor to a pull-up power rail to park the _PGOOD lines.​
      • martyjelen
        • Mar 2023
        • 127
        • Czech republic
        #43
        I think I don't understand. Should I measure voltage or not?
        • mon2
          • Dec 2019
          • 14667
          Yes, measure the voltage to ground again of the following:
          P5V_3V3G3H_EN -0V
          P5VG3S_EN - 0V​
          That is, the above cannot be 0V since the output voltage rails are active and stable. This implies the enable signals (above) are '1' = 3v3. Confirm it.
          • martyjelen
            • Mar 2023
            • 127
            • Czech republic
            #45
            I can confirm that P5V_3V3G3H_EN is 0V. P5VG3S_EN​ is also 0V.
            • martyjelen
              • Mar 2023
              • 127
              • Czech republic
              #46
              It seems the board definitely died. Suddenly the current draw drops to zero. Now PPBUS_G3H is missing....
              • mon2
                • Dec 2019
                • 14667
                What is the voltage to ground now of ppbus_g3h?
                Remove all power. What is the exact resistance in ohms to ground of this rail?
                • martyjelen
                  • Mar 2023
                  • 127
                  • Czech republic
                  #48
                  I removed both fuses. PPBUS_G3H is shorted to ground
                  • martyjelen
                    • Mar 2023
                    • 127
                    • Czech republic
                    #49
                    0V 0Ω​
                    • mon2
                      • Dec 2019
                      • 14667
                      Which side? Is it the isl or other downstream side that is shorted?
                      The cpu may be the root cause but suggest to inject 1 volt (max) onto the shorted side and hunt for the part that is heating up. Remove the heatsink off the cpu for inspection.
                      • martyjelen
                        • Mar 2023
                        • 127
                        • Czech republic
                        #51
                        Pin no. 2 on both F7000 +F7001 is shorted.
                        • martyjelen
                          • Mar 2023
                          • 127
                          • Czech republic
                          #52
                          C6525 was cracked. I removed it and now we are back. #45
                          Yesterday, 08:38 AM
                          • mon2
                            • Dec 2019
                            • 14667
                            What is the resistance to ground of the signals listed in post #45?
                            Very strange that the rails are enabled yet the enable lines are logic low = disable state.
                            • martyjelen
                              • Mar 2023
                              • 127
                              • Czech republic
                              #54
                              P5V_3V3G3H_EN -50kΩ
                              P5VG3S_EN​ - 50kΩ
                              • mon2
                                • Dec 2019
                                • 14667
                                Measure the voltage to ground on each leg of
                                R7652
                                R7691
                                Voltage to ground on pin # VREG5 (pin 29) on U7650.
                                Voltage to ground on pin # VREG3 (pin 22) on U7650.​
                                • martyjelen
                                  • Mar 2023
                                  • 127
                                  • Czech republic
                                  #56
                                  R7652 - 0V on both sides
                                  R7691​ - 0V on both sides
                                  pin29 on U7650 is PP5V_S5_LDO - 2.5V
                                  pin22 on U7650 is P5VP3V3_VREG3 - 3.3V
                                  did you mean these ?
                                  • mon2
                                    • Dec 2019
                                    • 14667
                                    Yes. Attempt a DFU on this unit. You may have corrupt T2 firmware.
                                    reference:
                                    https://www.badcaps.net/forum/troubl...g3s_en-missing
                                    • martyjelen
                                      • Mar 2023
                                      • 127
                                      • Czech republic
                                      #58
                                      Mabook is not in DFU. Is this method working for A2141 ?
                                      "Press the power button for about half a second, then also press and hold Left Control + Left Option + Right Shift for 10 seconds, then release all keys except power and hold power until the Target Mac shows up in Apple Configurator on the Host Mac"
                                      • mon2
                                        • Dec 2019
                                        • 14667
                                        Try the switch method:
                                        SWK003
                                        reference:
                                        https://logi.wiki/index.php/DFU_Mode_Restore_(Macs)
                                        • martyjelen
                                          • Mar 2023
                                          • 127
                                          • Czech republic
                                          #60
                                          I tried it. It doesn¨t detect in DFU. I tried both left ports.
                                          • platinumsteel
                                            Macbook Air 2015 Booting Very Slow and Stuck on apple Logo 99%
                                            by platinumsteel
                                            Hi guys i have my personal MacBook Pro 2015 820-00165 board that was working fine for more than a year and one day stopped working on my original Magsafe charger. It was turning on with my bench power supply. Opened it up and while diagnosing that somehow i ended up with a shorted smc.The line which was shorted was SMC_PM_G2_EN. I removed the SMC and short was gone. So all I had was another working donor board 820-3435 which i used to program it's SMC to 820-00165 using the SMCTOOL By MuertoGB.Took that SMC and use it on my 820-00165 board .And my board started working again. PPBUS_G3H 8.56V....
                                            03-18-2024, 05:16 PM
                                            Apple MacBook Pro A2141 X970 820-01700 Schematic & Board View
                                            Apple MacBook Pro A2141 X970 820-01700 Schematic & Board View...
                                            10-02-2024, 02:57 PM
                                          • ApplePie14
                                            MacBook Pro 2019 16inch A2141 no power
                                            by ApplePie14
                                            My Macbook, which had been working fine until two weeks ago, now has unstable power and won't turn on.
                                            When I took it apart, I found a lot of dust, so I think that might be what caused the damage.
                                            I checked with a USB meter and found that the voltage is 20V, and the current consumes a maximum of about 150mA, then fluctuates between 4 and 70mA.
                                            The same thing happens when the battery is removed.
                                            There were no short circuits in the PPBUS_G3H or NAND.
                                            08-25-2025, 12:17 AM
                                          • mferna14
                                            MacBook Air A2179 stuck on Apple Logo
                                            by mferna14
                                            Hi all, working on a MacBook Air A2179 EMC 3302 stuck on Apple Logo. Came in dead. There was spillage on both of the USB-C Charge port connector. I replaced the cap 4.7UF 25V near the speaker connector as it was corroded. Replaced USB-C connector with a new one & now I get display. The problem is that gets stuck on the Apple logo & sometimes it even boots up into OS after a very long time & the CPU fan spins fast. Kindly any repair tips will be appreciated. Do these logic board have BIOS, so that I could do a clean up or load a new dump. Thanks in advance.
                                            04-06-2023, 03:45 PM
                                          • sdogs
                                            Macbook Pro 15 A2141 820-01700-A stuck at 5V
                                            by sdogs
                                            Happy Sunday everyone,
                                            I have this Macbook Pro 15 A2141 820-01700-A stuck at 5V, it doesn't have any liquid marks or burn marks, I have carefully inspected the logic with the microscope and have not found any anomalies.
                                            By connecting the usb-c tester I could see that it is blocked at 5v, and as a first measurement I checked PPBUS_G3H which has a voltage value of 0.8v and measured in 0.06 ohm diode mode.
                                            I read a bit in the forum and I tried to inject 1v on the F7000 not having any current absorption, I then went up to 1.5v and I had a light current absorption (0.10Amp) and...
                                            09-03-2023, 09:52 AM
