MacBook Air A2179 - shorted trackpad, PPBUS_G3H stuck at 1,1v.
  • Gueric
    • Feb 2025
    • 72
    • France
    #41
    Before I do the measurements, I have to ask you about the markings on those mosfets because I’m very confused. If I remember correctly the 2 original ones that were dead had « Z340 øCP △T96K » written on them. I pulled the 2 same mosfets as replacement from another A2179 board but the markings were completely different (it says on it : T30 2024), and what’s even weirder is that those mosfets on the schematics are named SIZ342DT. Do you have any explanation? This is very confusing. Maybe you could send me a link to the exact model of those mosfets I could buy and replace them once for all? Because maybe that’s the actual issue.
    thanks
    • mon2
      • Dec 2019
      • 14261
      https://www.vishay.com/docs/62949/siz342dt.pdf
      https://www.digikey.ca/en/products/d...T1-GE3/6595020
      https://www.aliexpress.com/w/wholesa....home.search.0
      • Gueric
        • Feb 2025
        • 72
        • France
        #43
        thank you very much. I will order some SiZ342DT-T1-GE3 Mosfets, replace them both and give an update here.
        • Gueric
          • Feb 2025
          • 72
          • France
          #44
          Hey mon2 ! I'm back.
          So after replacing the 2 ISL mosfets, PPBUS is now fully back at 12.3. The issue is, board only draws 5,2v. When plugging the charger, small spike to 170mA for a fews seconds, then 70mA, and remains at that level, no matter how much time passes. Both USBC ports show the exact same readings. I tested some voltages, and 2 were no present at all, PMU_CLK32K_SOC and P5V3GS_EN.
          Otherwise every other line is present. I measured voltage readings that were lower than expected on those 2 lines (1st and 2nd picture) I basically got what OBData says is DFU mode voltage. The weird thing is nobody has put the laptop in DFU mode.
          is the T2's firmware just corrupt so do I try to put it back in its housing and to the keyboard combo, or is it dead, or is the PMU dead? Thanks
Name:	Screenshot 2025-04-18 at 12.21.00.png
ID:	3617886 Click image for larger version
Name:	Screenshot 2025-04-18 at 12.27.12.png
          • mon2
            • Dec 2019
            • 14261
            You are missing PMU_CLK32K_SOC? This clock is required. Review crystal @ Y8001 which is the base clock used by the PMU.
            • Gueric
              • Feb 2025
              • 72
              • France
              #46
              Ok my bad mon2 there were 2 test pads very close to each other and I was measuring the wrong one. PMU_CLK32K_SOC is 860mv as expected.
              I was making some measurements and realized PCH_RTC_RESET_L is 3v. from there, P5VG3S_EN is 0v, PP5V_G3S is around 50 to 100mv, and everything after is completely missing (P3V3G3S_EN, PP3V3_G3S etc) I attached the power sequence PDF is was following when measuring.
              • mon2
                • Dec 2019
                • 14261
                Remove all power. Meter in DIODE mode. Red meter probe to ground. Black meter probe onto R7613. Test each side of this resistor to be sure it is reaching U7610 input pin #1.
                What is the measurement? We are checking if this missing signal line is floating due to a broken trace or just not being driven by the PMU.
                • Gueric
                  • Feb 2025
                  • 72
                  • France
                  #48
                  mon2 each side of the resistor measure exactly the same, 0.634v
                  • mon2
                    • Dec 2019
                    • 14261
                    Try a DFU.
                    https://repair.wiki/w/MacBook_Air_A2...VG3S_EN_repair
                    • Gueric
                      • Feb 2025
                      • 72
                      • France
                      #50
                      mon2 thanks, will try that. Quick question tho. Since the board only draws around 80mA will the keyboard combo work at all?
                      • mon2
                        • Dec 2019
                        • 14261
                        TBD. In theory, only a small segment of the board needs to be powered to restore the assumed and corrupt firmware. That is the premise. Once the firmware is restored by this process, only then will the board power up to full potential and then consume much higher currents. Curious to learn if this works for you - I think I am in a similar position.
                        If in a pinch, I think I may have the T2 dump for this unit but need to confirm it. That is, you can then hot air off the flash device used by the T2 directly and reflash it without the DFU process. Try the front door method first and we can explore this alternate idea if needed. Be sure to follow the many YT articles and use quality USB cables, etc.
                        • Gueric
                          • Feb 2025
                          • 72
                          • France
                          #52
                          mon2 interesting thanks man. Just realized that the trackpad connector and the keyboard connector seem to be the same, so I will have to wait for the replacement TPAD connector to arrive, replace it and try the combo. will update here maybe this weekend.
                          • mon2
                            • Dec 2019
                            • 14261
                            If this is an ongoing interest to service these devices then suggest to invest into the kinky footprint sockets and PCBs to mate with the 8 pin SOIC programmer. Highly recommended. I would even pull the trigger today from Aliexpress.
                            Review the T2 flash device which are 2x3 or 4x3 - order support materials for both footprints.
                            https://www.aliexpress.com/item/1005...675918024jRs92
                            This vendor has affordable zero force sockets for both.
                            Also suggest to order the 'purple' board:
                            https://www.aliexpress.com/item/1005...75551802R6X1hR
                            * has support for soldering down the 2x3 or 4x3 USON8 packages
                            Finally - order a few of the exact flash device(s) used on these boards. Perhaps none of the above will be immediately required if the DFU works as expected but are a good fall back plan.
                            Here in Canada - they are all rare as the dodo bird.
                            • reessi
                              Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                              by reessi
                              Hello:
                              I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                              I started on the ACER:
                              Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                              All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                              I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                              10-29-2024, 11:31 AM
                            • mferna14
                              MacBook Air A2179 stuck on Apple Logo
                              by mferna14
                              Hi all, working on a MacBook Air A2179 EMC 3302 stuck on Apple Logo. Came in dead. There was spillage on both of the USB-C Charge port connector. I replaced the cap 4.7UF 25V near the speaker connector as it was corroded. Replaced USB-C connector with a new one & now I get display. The problem is that gets stuck on the Apple logo & sometimes it even boots up into OS after a very long time & the CPU fan spins fast. Kindly any repair tips will be appreciated. Do these logic board have BIOS, so that I could do a clean up or load a new dump. Thanks in advance.
                              04-06-2023, 03:45 PM
                            • eastcoastcomputing
                              Macbook Air A2179 - Mobo 820-01958 stuck at 15.2V
                              by eastcoastcomputing
                              Hi there,
                              I've got this case that puzzles me and I couldn't find any similar case to explain it. Maybe you guys can help?
                              The computer went to black screen while being used and fan started to rev full speed. It had to be forced shut down. Since then, fires up but no display, no chime and not in DFU.
                              I took the board out and inspected it with microscope: no visible damage to chips, no liquid damage. I checked all coils: no short.
                              The board goes to 3.5V, then 5V, then gets stuck at 15.2V.
                              L7030, L7400 and CPU (with its cooler on)...
                              07-23-2024, 03:31 AM
                            • larrysito111
                              a2141 820-20237-A stuck on apple logo no trackpad or keyboard reaction not even external
                              by larrysito111
                              it was liquid damage and after cleaning i got to this stage
                              i tested external screen that is ok
                              but external mice nor kb
                              so i m asking if anyone had similar issue so no time waste
                              or if not then just where to start
                              yest it is charging and ruing from battery and running same as on internal LCD and on external LCD
                              kb got the 1.8v and 3v3 present
                              there was liquid damage only on the area of the GPU wing just till the speaker amps
                              any ideas please
                              thank you ....
                              03-28-2025, 07:47 AM
                            • Yanleb
                              Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                              by Yanleb
                              Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                              I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                              D608, good
                              D618 RF101L4S, good (See warning 1 below)
                              D619 RF101L4S, good (See warning 1 below)
                              D865 RF101L4S, shorted (See warning 1 below)
                              IC464 Inverter HA MC74HC1G14, shorted...
                              03-09-2020, 12:00 AM
