MacBook Air A2179 - shorted trackpad, PPBUS_G3H stuck at 1,1v.
  • Gueric
    • Feb 2025
    • 37
    • France
    mon2 yup. exactly like what's on the ampmeter. 5.2v, stable.
    • mon2
      • Dec 2019
      • 13862
      Remove all power. Meter in resistance mode. What is the resistance across C7020?
      • Gueric
        • Feb 2025
        • 37
        • France
        mon2 Same, 2,5 ohms.
        • mon2
          • Dec 2019
          • 13862
          What is the voltage to ground of CHGR_AUX_DET @ C7016 pad (part is not stuffed)?
          What is the voltage @ PPCHGR_VDDA (C7075)? PPCHGR_VDDP (C7077)?
          Test the replaced mosfets in resistance mode to be sure the replaced parts are not shorted.
          Do you have a stable PP1V8_SLPS2R @ C7080? Needed to power U7000.
          Then, suggest to reflow U7000 if the above check out ok.
          • Gueric
            • Feb 2025
            • 37
            • France
            CHGR_AUX_DET : 1,3v
            PPCHGR_VDDA : 5v
            PPCHGR_VDDP : 5v
            PP1V8_SLPS2R: 0v. I think that's the culprit. diode mode from C7080: 0.430 resistance mode is at least 300Kohms.
            • mon2
              • Dec 2019
              • 13862
              So this rail is created by U3200. Measure the resistance to ground first to see if there is a short on this rail or not. If not, then U3200 is defective or not soldered correctly.
              • Gueric
                • Feb 2025
                • 37
                • France
                #27
                Will do some measurements tomorrow, it’s pretty late here. Thanks for you help so far
                • Gueric
                  • Feb 2025
                  • 37
                  • France
                  #28
                  mon2 So as the resistance on the 1,8v line was fine, I decided to replace U3200 and now It went from 0v flat to a few milivolts, unstable. sometimes 10mv, sometimes 50mv. Is this bad soldering/bad chip or could it be something else? maybe the other CD3217 has to be replaced aswell?
                  Also I reflowed the ISL just in case, but at that point I replaced it twice already so I'm definitely sure the chip is not at fault. Also diode readings have improved on PPBUS after the CD3217 replacement and this reflow, going from .530 to .500
                  • mon2
                    • Dec 2019
                    • 13862
                    https://logi.wiki/images/6/6a/820-01...iagram_LO2.pdf
                    • Gueric
                      • Feb 2025
                      • 37
                      • France
                      #30
                      measured PMU_CLK32_SOC on a test pad. I'm getting 100mv.
                      PP1V8_SLPS2R: 20mv
                      PP1V8_AWAKE measures 0v.
                      • mon2
                        • Dec 2019
                        • 13862
                        My bad, U7800 is creating the PP1V8_SLPS2R rail.
                        https://repair.wiki/w/MacBook_Air_A2...VG3S_EN_repair
                        Check the details for:
                        Check output voltages of U7800
                        • Gueric
                          • Feb 2025
                          • 37
                          • France
                          #32
                          Are you sure U7800 can output anything without PPBUS_G3H being fully present ? I’ll test all these voltages regardless.
                          • mon2
                            • Dec 2019
                            • 13862
                            Confirm the first 3 primary rails in the power up sequence. The ISL9240 is a buck-boost regulator. When a stable 5v is present, the part should boost to ~12v. When 20v is negotiated by the CD321x PD controllers, then the ISL9240 will enter buck mode and lower the 20v to ~13v to operate the logic board. As a power up default, each PD controller must be able to pass a stable ~5v onto the logic board else something is wrong here.
                            • Gueric
                              • Feb 2025
                              • 37
                              • France
                              #34
                              mon2 the 2 CD3217 are outputting a stable 5,2v signal (PPDCIN_G3H) but the ISL is not boosting it. even with the 5,2v signal, PPBUS_G3H is still 1,1v, PP1V8_SLPS2R is 30mv, and PP3V3_G3H is completely absent of course. I know for sure the ISL chip itself is not the issue. replaced it twice and reflowed it once and problem was still the exact same.
                              Also there is absolutely ZERO current draw.
                              I also double checked R7021, R7022, R7061 and R7062 and they're all 1 ohm as expected. even with PP1V8 not being present, should I replace the ISL again?
                              At this point the only things I think might be defective would either be Q7030 or Q7040 (which I’ve replaced twice) or the ISL itself (replaced twice also), some internal damage caused by the trackpad short, or something else that we’ve missed.
                              • mon2
                                • Dec 2019
                                • 13862
                                What is the exact voltage to ground of PP3V3_G3H? The missing PP1V8_SLPS2R rail is created once PP3V3_G3H is present and stable. If this PP3V3_G3H is absent, measure the resistance to ground of this power rail.
                                • Gueric
                                  • Feb 2025
                                  • 37
                                  • France
                                  #36
                                  mon2 PP3V3_G3H is still absent because PPBUS_G3H is still at 1,1v. PPDCIN_G3H reads 5,2v like on the ampmeter but the ISL is still not functioning properly
                                  the PPBUS_G3H issue is not solved yet
                                  • mon2
                                    • Dec 2019
                                    • 13862
                                    What is the voltage to ground of CHGR_AUX_DET @ C7016 (not stuffed) with the power adapter connected? Still @ ~1v3?
                                    Also check:
                                    CHGR_AMON
                                    CHGR_BMON
                                    • Gueric
                                      • Feb 2025
                                      • 37
                                      • France
                                      #38
                                      mon2. yes. C7016 to ground is 1,357v.
                                      CHGR_BMON reads 0V, and CHGR_AMON is too hard to get to, it's only 1 tiny resistor hiding under the T2 metal shield. if you meant PPDCIN_G3H_CHGR_AMON, it reads 5,2v.
                                      • Gueric
                                        • Feb 2025
                                        • 37
                                        • France
                                        #39
                                        The only 2 potentials culprit for this low PPBUS_G3H voltage are only Q7030, Q7040 and the ISL right? or did I miss something somewhere. one of those 3 chips being defective would also be unfortunate since I've already replaced them twice. maybe I've been unlucky.
                                        • mon2
                                          • Dec 2019
                                          • 13862
                                          Had to put up some curtains. Fun.
                                          Confirm the details of the replaced mosfets. Note that there are 2 inside of each package. With no power, measure the mosfet pins:
                                          source / drain
                                          source / gate
                                          gate / drain
                                          For both, Q7030, Q7040. Be sure to test each permutation of each mosfet inside the single package.
                                          • reessi
                                            Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                            by reessi
                                            Hello:
                                            I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                            I started on the ACER:
                                            Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                            All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                            I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                            10-29-2024, 11:31 AM
                                          • mferna14
                                            MacBook Air A2179 stuck on Apple Logo
                                            by mferna14
                                            Hi all, working on a MacBook Air A2179 EMC 3302 stuck on Apple Logo. Came in dead. There was spillage on both of the USB-C Charge port connector. I replaced the cap 4.7UF 25V near the speaker connector as it was corroded. Replaced USB-C connector with a new one & now I get display. The problem is that gets stuck on the Apple logo & sometimes it even boots up into OS after a very long time & the CPU fan spins fast. Kindly any repair tips will be appreciated. Do these logic board have BIOS, so that I could do a clean up or load a new dump. Thanks in advance.
                                            04-06-2023, 03:45 PM
                                          • eastcoastcomputing
                                            Macbook Air A2179 - Mobo 820-01958 stuck at 15.2V
                                            by eastcoastcomputing
                                            Hi there,
                                            I've got this case that puzzles me and I couldn't find any similar case to explain it. Maybe you guys can help?
                                            The computer went to black screen while being used and fan started to rev full speed. It had to be forced shut down. Since then, fires up but no display, no chime and not in DFU.
                                            I took the board out and inspected it with microscope: no visible damage to chips, no liquid damage. I checked all coils: no short.
                                            The board goes to 3.5V, then 5V, then gets stuck at 15.2V.
                                            L7030, L7400 and CPU (with its cooler on)...
                                            07-23-2024, 03:31 AM
                                          • larrysito111
                                            a2141 820-20237-A stuck on apple logo no trackpad or keyboard reaction not even external
                                            by larrysito111
                                            it was liquid damage and after cleaning i got to this stage
                                            i tested external screen that is ok
                                            but external mice nor kb
                                            so i m asking if anyone had similar issue so no time waste
                                            or if not then just where to start
                                            yest it is charging and ruing from battery and running same as on internal LCD and on external LCD
                                            kb got the 1.8v and 3v3 present
                                            there was liquid damage only on the area of the GPU wing just till the speaker amps
                                            any ideas please
                                            thank you ....
                                            03-28-2025, 07:47 AM
                                          • Yanleb
                                            Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                                            by Yanleb
                                            Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                                            I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                                            D608, good
                                            D618 RF101L4S, good (See warning 1 below)
                                            D619 RF101L4S, good (See warning 1 below)
                                            D865 RF101L4S, shorted (See warning 1 below)
                                            IC464 Inverter HA MC74HC1G14, shorted...
                                            03-09-2020, 12:00 AM
