MacBook Air A2179 - shorted trackpad, PPBUS_G3H stuck at 1,1v.
  • Gueric
    • Feb 2025
    • 72
    • France
    Hello people !
    I received an A2179 with a destroyed trackpad connector (all PPBUS_G3H_TPAD_FLT pads were destroyed). PPBUS_G3H was shorted to ground. I removed the trackpad connector, cleaned the area thoroughly, removed some bits of burnt copper, and short was gone. But PPBUS was stuck at 1,1v, even tho PPDCIN_G3H measured 5.2v So I replaced the 2 ISL's MOSFETs (Q7030, Q7040) in case they got killed by the short. Nothing changed.
    I then replaced the ISL, still nothing. measured all its pads, good. resistors around the chip are also good. resistance on PPBUS was good, diode reading was a bit high (.510 instead of .410) and resistance was perfect.
    Still nothing. absolutely no current draw, still 1v on PPBUS. so I removed the coil that connects PPBUS_G3H to these trackpad pads (PPBUS_G3H_TPAD_FLT), in case this mess was causing this, still nothing. I even replaced Q7680 and Q7660 just in case, absolutely nothing changed.
    I've included a picture of the connector.
    What should I do ? Maybe I've missed something? I'm out of ideas. Any help is appreciated.
  • mon2
    • Dec 2019
    • 14317
    Remove the fuse on PPBUS_G3H and test again. What is the voltage without the fuse on the isl side of this power rail? Is the voltage stable or cycling?
    • Gueric
      • Feb 2025
      • 72
      • France
      Sorry just to be sure, that fuse is F8400, one side PPBUS_G3H and the other side PPVIN_S0SW_LCDBKLT_F right? So just remove the fuse and measure its PPBUS_G3H pad?
      Thanks for you reply
      • mon2
        • Dec 2019
        • 14317
        I am out of the office so do not have the schematics at this time. Locate the isl charger ic in the schematics. The fuse will be to the right side of this part and is on the main ppbus_g3h rail. We want to isolate the producer and consumer sides of this main power rail by removing the fuse.
        • Gueric
          • Feb 2025
          • 72
          • France
          mon2 I just double checked, and there are no PPBUS fuses on the A2179 model. Only 2 fuses for the CD32s, one for the backlight circuit and one for the battery.
          • mon2
            • Dec 2019
            • 14317
            Test the vcore inductors L7210/L7220/L7230 in diode mode. Meter in diode mode. Remove all power. Red probe to ground. Black meter probe to the inductors. What are the measurements?
            • Gueric
              • Feb 2025
              • 72
              • France
              mon2 all exactly 0.371
              edit: if that helps, PPBUS_G3H reads 0.520 instead of 0.410 in diode mode
              • mon2
                • Dec 2019
                • 14317
                Cpu is not dead. Will post more once at the office.
                • Gueric
                  • Feb 2025
                  • 72
                  • France
                  mon2 thank you very much. Will wait for your input
                  • mon2
                    • Dec 2019
                    • 14317
                    There are 2 versions of logic boards for the A2179. Which is yours?
                    820-01958 or 820-01055?
                    Check the diode mode measurements of all inductors onboard. See attached. No power to the board when testing in diode mode.
                    Red meter lead to ground.
                    • Gueric
                      • Feb 2025
                      • 72
                      • France
                      Click image for larger version  Name:	Image.jpg Views:	0 Size:	188.3 KB ID:	3613052
                      Here is your picture with the measurements I just made. mon2
                      Also this board is a 820-01958
                      • mon2
                        • Dec 2019
                        • 14317
                        Remove all power. Meter in resistance mode. Measure the resistance to ground of each pin on the battery connector @ J6950.
                        Post each measurement in ohms (not diode mode). Color of the meter probes does not matter in resistance mode.
                        We are checking if the SMBUS lines (used by the ISL9240) are shorted or not due to a transient on the battery connector (have seen this in the past).
                        • Gueric
                          • Feb 2025
                          • 72
                          • France
                          mon2
                          Pin 1: 2.8 Mohms
                          Pin 2: 2.8 Mohms
                          Pin 3: around 60 Kohms
                          Pin 4: around 360 Kohms
                          Pin 5: 3.3 Mohms
                          Pin 6 and 7 are ground.
                          I also checked in diode mode and they all match the values from OpenBoardData.
                          • mon2
                            • Dec 2019
                            • 14317
                            Measure the voltage to ground of pins 3 & 4 on the battery connector.
                            These are:
                            SMBUS_3V3_BATT_SCL
                            SMBUS_3V3_BATT_SDA
                            • Gueric
                              • Feb 2025
                              • 72
                              • France
                              Pin 3: 0V
                              Pin 4: 0V aswell
                              In case it's needed, Pin 1 and 2 read 1,1v (same as PPBUS) and Pin 5 reads 2,5v. mon2
                              Edit : left the board plugged for a minute, and Pin 5 reached 3,3v, and hovers around 3,1v to 3.3v.
                              • mon2
                                • Dec 2019
                                • 14317
                                Remove all power. Still in resistance mode. Measure the resistance to ground at L7690 = PP3V3_G3H.
                                • Gueric
                                  • Feb 2025
                                  • 72
                                  • France
                                  mon2 1 Mohms. slowly goes down
                                  • mon2
                                    • Dec 2019
                                    • 14317
                                    So not shorted but not on. In tracing this rail, the VIN for this rail @ pin 23 on U7650 and is fed from the missing PPBUS_G3H.
                                    Measure the resistance across C7023.
                                    • Gueric
                                      • Feb 2025
                                      • 72
                                      • France
                                      mon2 So across pin 1 and 2 of C7023 I get 2,50 ohm. To ground I get around 100 Kohms on both pins.
                                      • mon2
                                        • Dec 2019
                                        • 14317
                                        The input current sense resistance is ok and also not shorted.
                                        What is the voltage to ground of PPDCIN_G3H? Is it stable?
                                        • reessi
                                          Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                          by reessi
                                          Hello:
                                          I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                          I started on the ACER:
                                          Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                          All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                          I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                          10-29-2024, 11:31 AM
                                        • mferna14
                                          MacBook Air A2179 stuck on Apple Logo
                                          by mferna14
                                          Hi all, working on a MacBook Air A2179 EMC 3302 stuck on Apple Logo. Came in dead. There was spillage on both of the USB-C Charge port connector. I replaced the cap 4.7UF 25V near the speaker connector as it was corroded. Replaced USB-C connector with a new one & now I get display. The problem is that gets stuck on the Apple logo & sometimes it even boots up into OS after a very long time & the CPU fan spins fast. Kindly any repair tips will be appreciated. Do these logic board have BIOS, so that I could do a clean up or load a new dump. Thanks in advance.
                                          04-06-2023, 03:45 PM
                                        • eastcoastcomputing
                                          Macbook Air A2179 - Mobo 820-01958 stuck at 15.2V
                                          by eastcoastcomputing
                                          Hi there,
                                          I've got this case that puzzles me and I couldn't find any similar case to explain it. Maybe you guys can help?
                                          The computer went to black screen while being used and fan started to rev full speed. It had to be forced shut down. Since then, fires up but no display, no chime and not in DFU.
                                          I took the board out and inspected it with microscope: no visible damage to chips, no liquid damage. I checked all coils: no short.
                                          The board goes to 3.5V, then 5V, then gets stuck at 15.2V.
                                          L7030, L7400 and CPU (with its cooler on)...
                                          07-23-2024, 03:31 AM
                                        • larrysito111
                                          a2141 820-20237-A stuck on apple logo no trackpad or keyboard reaction not even external
                                          by larrysito111
                                          it was liquid damage and after cleaning i got to this stage
                                          i tested external screen that is ok
                                          but external mice nor kb
                                          so i m asking if anyone had similar issue so no time waste
                                          or if not then just where to start
                                          yest it is charging and ruing from battery and running same as on internal LCD and on external LCD
                                          kb got the 1.8v and 3v3 present
                                          there was liquid damage only on the area of the GPU wing just till the speaker amps
                                          any ideas please
                                          thank you ....
                                          03-28-2025, 07:47 AM
                                        • Yanleb
                                          Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                                          by Yanleb
                                          Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                                          I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                                          D608, good
                                          D618 RF101L4S, good (See warning 1 below)
                                          D619 RF101L4S, good (See warning 1 below)
                                          D865 RF101L4S, shorted (See warning 1 below)
                                          IC464 Inverter HA MC74HC1G14, shorted...
                                          03-09-2020, 12:00 AM
