la-h482p rev 1.0 not reacting to power button
This topic has been answered.
  • questore
    • Dec 2015
    • 485
    • csongrád
    Hi Everyone,
    I have a la-h482p rev 1.0 on my desk that is not reacting to power button.
    + Every ALW a LO are present when battery is plugged (11.7V)
    + Charger shows charging led orange when charging and white LED when done charging.
    + EC_ON also high 3.1V
    + power button has 3v and goes down to 0 when pressed.
    + BIOS does not have 3v on the 8th pin (+3V_SPI never rises only 0.07milivolt risen after battery plugged)
    + PCH hase 1.5V on one capacitor on top nothing on the others
    + nothing gets hot only SIO and 3V/5V regulators are 22 C
    Schematic can be found here: (LA-H492P same)
    https://www.badcaps.net/forum/troubl...atics-la-h492p
    What do you think Is that a PCH problem or should I try to reprogram the EC and BIOS?
  • Answer selected by questore at 04-13-2025, 08:54 AM.
    questore
    • Dec 2015
    • 485
    • csongrád
    + Reflashed the original BIOS (08600) with cleaned ME.
    + plugged in the battery (since CMOS battery is not exists on this machine)
    + changed RAM to my known good ram
    Laptop started then I have turned off and repeated it works. OK
    but..
    Then I have reinstalled both original ram and 5 long 3 short back
    after that reinstalled my known good ram...still 5 long 3 short. Tryed to remove battery and charger and holding down power button for1 minute but no luck and now when i try to turn it on it starts some weard loop on random caps flashes then reboot and another random flashes.
    SOLUTION. After changing the RAM it needs a clean ME BIOS again to work. I dont know if I have ever encountered a thing like this.
    • questore
      • Dec 2015
      • 485
      • csongrád
      I have asked the owner for the prehistory of the laptop couse seen some things that is odd.
      Here goes the prehistory
      Laptop charger died.
      Owner got a new charger that has lower wattage.
      Laptop only charged when it was turned off.
      Owner used it from battery for a while
      Battery started to wear off, only working half hour.
      Owner brought new battery from ebay.
      New Battery dischaged
      Laptop seems to charge cause amber led is on for 1 minute but in reality it is not charging. 0.027 amps drawn
      Starting to think this battery is not fully compatible with this laptop.
      I have seen it in other modells where battery can be used but newer charges.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Is the mb switching at all?
        I think it should turn on even without backup battery-so battery is unlikely the cause here.
        Post more details.
        • questore
          • Dec 2015
          • 485
          • csongrád
          Post more details.
          MB Not giving any sign of life and pressing power button does not make the amp draw os PSU change.
          This could also be because the charger is lower Wattage than it should (original 230amp and replacement is 90amp)
          • questore
            • Dec 2015
            • 485
            • csongrád
            Brought a normal power adapter, after connecting charger and battery. the laptop turns on when power button pressed, BUT...
            I have 5 long 3 short blinking on caps lock.
            Now at least the battery charges
            Tryed different rams and put it different sticks....no success.
            Next step is flash bios with clean me.
            • mon2
              • Dec 2019
              • 13994
              Try a hard reset.
              AI Overview
              Learn more
              A Caps Lock blinking with 5 long flashes followed by 3 short flashes on an HP laptop typically indicates a problem with the motherboard or CPU. This often means the computer doesn't detect the CPU. If you try to reset the BIOS by disconnecting the laptop from power, holding the power button for 30 seconds, and then attempting to power it on, it may resolve the issue​.
              • questore
                • Dec 2015
                • 485
                • csongrád
                Originally posted by mon2
                Try a hard reset.
                AI Overview
                Learn more
                No luck. Thx
                • questore
                  • Dec 2015
                  • 485
                  • csongrád
                  Downloaded BIOS-es from HP website:
                  https://support.hp.com/hu-hu/drivers...ber=CND94617GD
                  This modell has 4 different BIOS that has 16Mb size. I have backed up the current one and its version is "08600" but Since the laptop been in a repair store I cannot trust the BIOS version is correct.
                  Tryed all 4 of them and only the 08601 is doing different caps lock LED codes on start, every other is giving 5 long 3 short.
                  08601 starts with the following. symptom:
                  Lptop starts 3 long caps lock LED flash, then restarts, 2 long CAPS LOCK flash then restarts. 1 long CAPS LOCK LED flash then resarts..then 1 short flash and resart 1 short flash restart forever loop.
                  What do you think? maybe EC flash?
                  • questore
                    • Dec 2015
                    • 485
                    • csongrád
                    Let go back to square 1.
                    costumer states that laptop worked from battery befor 5 long 3 short LED error code.
                    inspecting RAM voltages 1.2VDDQ is present and pullup resistor on DRAM_RESET is correct 470 ohms BUT DRAM_RESET has only 0,111 voltage.
                    • questore
                      • Dec 2015
                      • 485
                      • csongrád
                      but..
                      • questore
                        • Dec 2015
                        • 485
                        • csongrád
                        Thank you for all the help for everyone
                        • questore
                          • Dec 2015
                          • 485
                          • csongrád
                          Afterinfo.
                          5 long 3 short was back several times and looking closely at the board i found that on the back PUH1 was carbonized so 0.95v was randomly on and off making CPU line instable on start. Now trying to fix it and get back it the problem is resolved or not. Maybe others will learn from this.
                          • questore
                            • Dec 2015
                            • 485
                            • csongrád
                            Originally posted by questore
                            Afterinfo.
                            No luck on this, nothing to do maybe a bad CPU because of original heatsink was not properly contacted and fied CPU
                            • themosttogain
                              HP Envy 13-BA1565na with intermittent power button
                              by themosttogain
                              Hope someone can give me some suggestions on this because i'm at my wits end with it...
                              I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
                              Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
                              07-12-2024, 03:03 AM
                            • TimeRabbit07
                              Asus FX517ZC charges but power button does nothing
                              by TimeRabbit07
                              Hi all!
                              I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
                              Here are its various numbers and identifiers:
                              Model short: FX517Z
                              Model long: FX517ZC-HN114W
                              SN: NANRCX01S57842E
                              CN: 3SDB 12M
                              MFD: 2022-10
                              Motherboard model: DA0NJLMBAE0 REV E
                              Symptoms:
                              The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
                              History so far:
                              The...
                              09-04-2024, 05:48 PM
                            • reessi
                              Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
                              by reessi
                              With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
                              No corrosion any where!
                              Tried a replacement power button off ebay and the same.
                              Very occasionally it will work with the power button connected!
                              Same results with or without the battery.
                              Can it be a fault with the Audio board or the mainboard?
                              The touch Id assembly connects through the Audio board first then to the Mainboard.
                              Flex...
                              06-26-2024, 03:31 PM
                            • questore
                              MSI GE62 6QF MS-16J41 not reacting to power button
                              by questore
                              Hi Guys,
                              This laptop came to me as a gift, and know nothing about it. I would like to fix it.
                              When plugged in without battery nothing happens.
                              If I plug the battery then connect the power supply, blue LED lits up in the front.
                              After cleaning the DCIN mosfet area (black burn residue was present near the first 2 mosfet)
                              + 3.3v is present on the power button and when pressed it goees 0v for a second, but no other reaction on the laptop.
                              + Measured 5.1v some places
                              + Board Taking 0.010mA when charger plugged in.
                              + Flashed...
                              04-24-2023, 10:29 AM
                            • x_orange90_x
                              Seven Leagues Slot Machine stop button issues
                              by x_orange90_x
                              I don't know if anyone here has experience with Japanese slot (pachislo) machines, but I sure hope so. I bought this machine last week in semi-working order. It would play and the reels would spin, but the stop buttons would not stop them at all. I found that the high-frequency filtering tantalum capacitor was bad on the reel stop board, along with the fuse being blown. I replaced the fuse and removed the capacitor. I haven't replaced the cap yet because I didn't have one on hand, but it's not necessary for the operation of the machine.
                              The issue now is the Stop buttons are intermittently...
                              02-12-2025, 10:01 AM
